XREAS to Bilstein 5100
Discussion in '5th Gen 4Runners (2010-2024)' started by DrewF, Aug 19, 2024.
  1. Aug 22, 2024 at 1:36 PM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    I dunno I think its almost undoable without popping off the tie rod bolt with a bearing puller. I tried a few years ago without removing it.. ended up having an accident, got my hand pinched under the Coilover bottom, got worse during struggle to free my crushed hand, knocked it off the jackstand, it fell... then things got broken..then things got worse.. then I waited 5 months or so.. Seems when I told the tow truck driver not to drive it onto the flatbed or turn the wheel, he figured it was just.. I dunno
    So
    1 new front diff
    1 new axle shaft
    1 crushed hand
    $9K later
    I would remove the lower bolt... and not skip this step. I found it doesnt offer enough clearance, with Kings at least to install without removal.
  2. Aug 22, 2024 at 5:01 PM
    DrewF
    DrewF [OP] New Member
    2014 4Runner limited
    The shop that did the install is going to swap them. I was also debating if I should have them set the shocks to #2 setting, or would that require spacers in rear? I saw a thread that said #2 setting is better than stock and didn't require any spacers, though. Not sure if I should even go that route. My off roading consists of annual trip to OBX 4x4 and my truck performs fine. Just looking for a little more sporty look
  3. Aug 22, 2024 at 5:53 PM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    If you move both shocks to the .85 settings you will be basically the same as a Pro. You can go to 1.75 and not be negative rake ( until you load the back up)
    DrewF[OP] likes this.
  4. Aug 22, 2024 at 5:59 PM
    DrewF
    @HarrisNC will it look okay with Michelin Defenders stock size (20's)
  5. Aug 22, 2024 at 6:24 PM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    I don’t think it will look bad at the .85 setting. The nittos that come on a pro are not aggressive and are only a little wider. I would probably want something a little bigger eventually. I switched my 20s to 17s and have the stock 2675/70/17. Same thing I had on my 17 with 1.75F/1”R
  6. Aug 23, 2024 at 8:57 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    I have mine at 1.75" and no spacer in the rear. Looks good to me.
    DrewF[QUOTED][OP] likes this.
  7. Aug 23, 2024 at 10:15 AM
    I'm fairly sure @nimby has the same, albeit with Eibach shocks; same effect.
  8. Aug 23, 2024 at 4:32 PM
    I had that set-up for quite a while. The fender height front and back were dead level.
    However, when I put a heavy roof rack on, it eventually caused the rear to settle slightly and became a little nose high.
    I've since added a 0.5" rear spacer.
    Now I have the stance of a Pro, but a little higher all around.
    I do like my current stance better......so I recommend adding a 0.5" rear spacer if you go 1.75" up front.
    Rocko9999 and DrewF[QUOTED][OP] like this.
  9. Aug 25, 2024 at 11:00 AM
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    I nstalled bilstein 6112s up front. The c clip settings are staggered in order to remove the lean and you get the ride of a 2.5 diameter damper..
  10. Aug 26, 2024 at 3:48 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    IMG_1898.jpg FWIW, Here’s a pic of my 2021 TRD OR with Bilstein 5100’s with the front set at .85 on stock front and rear springs.
    I’ve added more weight (winch, bumper and skids) since and have changed springs but hope the attached pic helps the OP get a feel of the stance at the .85 setting
    Cheers,
    Bob
  11. Aug 26, 2024 at 9:28 AM
    Rocko9999
    2011 Limited
    The lean is from incorrect front spring orientation.
  12. Aug 26, 2024 at 9:29 AM
    Rocko9999
    2011 Limited
    I have considered adding 0.5 spacer to the rear as when I have some weight in the back, it sags a tiny bit. Did you do this yourself or have a shop do it?
  13. Aug 27, 2024 at 11:33 AM
    I did it myself. It's pretty easy.
  14. Aug 29, 2024 at 4:30 PM
    DrewF
    The shop swapped my springs. Now the longer one with more coils is on driver. Also, had the shocks moved up to #2 clip. I'm now within a 1/4 inch side to side and I think the front end height is perfect! Next stop is Garden State Undercoating in New Jersey for undercarriage rust remediation and woolwax.
    Rocko9999 and backpacker like this.
  15. Aug 29, 2024 at 4:52 PM
    Rocko9999
    2011 Limited
    Very nice. So that's 1.75" up front, no spacer in the rear?
  16. Aug 29, 2024 at 4:55 PM
    DrewF
    0.85. They did install small spacer rear driver to help compensate for lean, but not sure what size
  17. Aug 29, 2024 at 5:00 PM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    Looks good. Glad swapping the springs did the trick.
