Woolwax over Fluid Film, but not there yet?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Apr 15, 2023.
  1. Apr 23, 2023 at 11:48 AM
    Woolwax definitely attracts dust and mud. Despite it’s name, It never really sets into a wax, it stays wet until enough dirt/dust builds up on it. Eventually it takes on enough that the woolwax becomes a “crust” that keeps everything protected. Although I wash off chunky mud really well after a trip, it will still hold on to a thin layer of it.
    Not sure about some other products. I would imagine thinner products that set up like an actual wax will attract dirt less.
  2. Apr 23, 2023 at 12:27 PM
    Matt83
    Matt83 New Member
    Northeast
    After a winter of sand put down on local roads, the undercarriage of my Wool Wax treated trucks looks pretty dirty. But if I take my finger and wipe it away I have a rust free frame underneath. Once the winter ends here I will normally do a pressure washing of the undercarriage to get the built up dirt off and then reapply before next winter. Wool Wax does not recommend any pressure washing of the underside during the winter season.
    Because Woolwax® is non-drying, Woolwax® will attract an initial coating of sand/dirt. Anything that may adhere can easily be rinsed off with a low pressure garden hose. Because Woolwax® contains no solvents, it will not become tacky or sticky and create a dirt buildup. Many of our professional Undercoaters advise their customers to drive down a dirt road after Woolwax® application. They say that the outer coating of sand gives the coating an extra layer of protection, and stops salt from sticking to it.. Years ago when they used to undercoat with motor oil most people were always advised to drive on a dirt road as soon as possible. There must be something to this strategy, as it is still recommended by many professionals today.
    Woolwax® is very thick and does not wash off easily. Anything dirt or salt that may adhere can easily be rinsed off with a low pressure garden hose.
    djwantke[OP] likes this.
  3. Apr 23, 2023 at 1:55 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  4. Apr 23, 2023 at 5:31 PM
  5. Apr 23, 2023 at 10:01 PM
    That one looks like it might be like a traditional non-drying chain lube. The Maxima brand Chainwax has paraffin in it. It actually seems to dry and set after after a few minutes.
    It has really good capillary action to get sucked into tight crannies. Regular chainlubes will that too, but my experience is that chainwax does it better.
    Like I mentioned before, the solvents in it will give you a headache pretty quick, so I use it for spot treatment.
    djwantke[QUOTED][OP] likes this.
  6. Apr 27, 2023 at 8:13 PM
    let's go
    McSpazatron likes this.
