Wireless Android Auto
Discussion in '5th Gen 4Runners (2010-2024)' started by remoguy55, Jan 24, 2022.
  1. Feb 7, 2022 at 1:04 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    For those of us who have to spin a USB 16 times to get it in.. .. is this the upward or downward version?
  2. Feb 10, 2022 at 11:06 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    From their site.....more availability in late Feb.
  3. Feb 10, 2022 at 11:59 AM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    This is an "insert joke" insert joke. Carry on, fellow members.
    MeefZah[QUOTED] likes this.
  4. Feb 10, 2022 at 3:36 PM
    remoguy55
    remoguy55 [OP] New Member
    2020 SR5 Premium 4WD
    Just got mine yesterday. So easy to install and connect with my phone. Takes about 15 or so seconds for AA to pop up on the infotainment screen. Since my 4R is the SR5, I tuck it behind the 4wd selector and it sits just fine without the adhesive.
    MeefZah likes this.
  5. Feb 10, 2022 at 10:05 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Downward
  6. Jun 12, 2022 at 11:25 PM
    H_Jons
    H_Jons New Member
  7. Jun 14, 2022 at 7:04 AM
    Dohc97
    Dohc97 New Member
    Does it cost 89 as per Motorola's site or 108 from Amazon?
  8. Jun 14, 2022 at 8:03 AM
    2020 4Runner
    Fl
    $89 on Amazon....they currently have them.
  9. Jun 14, 2022 at 8:20 AM
    Dohc97
    Dohc97 New Member
    I just ordered it from Amazon.
    With a long USB extension cord, can this be put anywhere else inside the car?
  10. Jun 14, 2022 at 8:23 AM
    Brandonium
    Brandonium New Member
    I use AAWireless and it has been flawless once I figured out which cable it liked and which settings to use. Typically 25 seconds from cold start to AA auto loading on the unit. I placed my dongle in the cubby so I could see connectivity status.
    ladebakk and PJSnow like this.
  11. Jun 14, 2022 at 9:27 AM
    Dohc97
    Dohc97 New Member
    Anyone have a DIY on how I can take out this cubby to drill a hole in the back? I am thinking of running a long usb extension cord to mount the wireless car adapter somewhere else in the car.
  12. Jun 14, 2022 at 9:30 AM
    Brandonium
    Pull two side panels, the center shifter/console top, climate control assembly and the small plastic strip at the very bottom of the center stack. After that two phillips screws and pop top then bottom out (4 retaining clips) and associated connectors for wiring.
  13. Jun 15, 2022 at 11:09 AM
    2020 4Runner
    Fl
    You should be able to and still connect fine.
  14. Aug 15, 2022 at 8:29 AM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    Doglover2003 likes this.
  15. Jan 19, 2023 at 5:50 PM
    TXAG TRAIL
    TXAG TRAIL New Member
    2021 Trail Edition
    Did you have any trouble setting it up? I have the same phone and can't get it connected to Bluetooth. All the device does is blink green immediately. Waited 10min for it to turn blue.
  16. Jan 19, 2023 at 5:58 PM
    HazOpRed
    HazOpRed 22' TRDOR
    I have seen some devices do this. Main drawback is significant lag
  17. Feb 8, 2023 at 1:41 PM
    Lou
    Lou New Member
    This has ZERO lag. I've been using it for months with no problems.
  18. Feb 8, 2023 at 3:20 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Just curious - when using Android Auto on the screen, does it lock you out when in motion? I'm looking to do this but wanted to know how it works first. Thanks!
  19. Feb 8, 2023 at 4:45 PM
    #49
    RkyMtnMan
    RkyMtnMan New Member
    '22 ORP LR
    I have wireless AA with the Motorola part and this is app specific. Google Maps locks you off your phone and makes you use the on screen app. Spotify let's you still use the phone for control.
  20. Feb 8, 2023 at 4:45 PM
    #50
    TrueTexas
    The Woodlands, TX
    Works just like if you had the phone plugged in.
    For the other posts regarding lag, the only lag I get is during the initial connection. Can take anywhere from 5 seconds to one minute. After that it works well.
    Only other issue I have had is it losing connectivity on long drives. Throws up an Android Auto discounted message on the display but reconnects within 30 seconds or so by itself.
  21. Feb 10, 2023 at 7:40 AM
    #51
    Shaunnj007
    Shaunnj007 New Member
    Shaun
    2023 Lunar Rock TRD ORP 4Runner
    I also have the Motorola unit and as much as I like the convience of not having to plug my LG V60 in everytime I get in to my 4runner it always disconnects with the same error above "Android Auto Disconnected" at least 3-5 times in a 45 min drive. I have tried everything that the forums and Motorola say for TS'ing but still no luck. The other thing that is super annoying is that every once and awhile when I go to make a call or receive a call it does not go through the cars BT. Its almost like the Toyota headunit is fighting with the Motorola unit and doesnt know to take the call through the cars BT or through Android Auto. The other downside is that the Motorola unit is not updatable and if they do realize there is bugs with it there is no way to fix it. Hope this helps
  22. Feb 10, 2023 at 7:59 AM
    #52
    Kfish
    Kfish New Member
    2020 4Runner SR5
    I had the Motorola unit before for close to a year and switched over to AAWireless device (2.5Ghz mode) with a short 3 inch cable. The reason was that the Motorola uses only 5G band but AAWireless has both 5G and 2.5Ghz, with 2.5Ghz I have yet to experience a disconnect state. With 5G in downtown Seattle area or other big cities Auto Android got disconnected consistently many many times, almost a guarantee. AAWireless comes default as 5G so you have to go to the app and change to 2.5Ghz and its been great ever since. Both units does have a same amount of music stutter/lag once in a while though.
  23. Apr 15, 2023 at 11:25 PM
    #53
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    erfer1 likes this.
  24. Apr 17, 2023 at 6:38 AM
    #54
    Lou
    Lou New Member
    After 8 months, I have zero regrets. I love not having to plug the phone in every time.
    Doglover2003[QUOTED] likes this.
  25. Apr 17, 2023 at 6:50 AM
    #55
    Doglover2003
    '18 ORP w/KDSS
    Good to hear :thumbsup:
  26. Jul 8, 2023 at 5:30 PM
    #56
    KA1OTE
    KA1OTE Just a KA1OTE drivin' a 4Runner
    Kai
    Southern Wyoming
    2021 NBM Venture SE
    How and where did you connect the dongle to the dash? I've just tore my dash apart trying to find a way to hide my cable behind the dash but I have come up with nothing but blanks so far. From your picture, it looks like you have hidden your cable connection and I'd really love to know how! If you wouldn't mind sharing :D
  27. Feb 6, 2024 at 1:29 PM
    #57
    Lou
    Lou New Member
    TrueTexas likes this.
  28. Nov 27, 2024 at 2:33 PM
    #58
    bri_ola
    bri_ola New Member
    2005 4runner Limited
    Had the Motorola now for a few months. Worked great at first, but now I cannot connect it to my phone. Every time i try, it says "Cannot Connect" or something like that. Any suggestions? Is there a master reset on the AA unit?
    Also, I noticed that my battery drain was obscene when I had it working. Anyone else experiencing this while using the Motorola dongle?
  29. Nov 27, 2024 at 3:10 PM
    #59
    TrueTexas
    The Woodlands, TX
    I have had 2 of them fail over the past 3.5 years. One was replaced under warranty and one was just a little bit out of warranty. There is a way to reset them. Can't remember exactly how but if that doesn't work and you are within a year, just call them and gave them troubleshoot / replace it.
    When you say battery drain? Do you mean on your phone? If so, BT has always been notorious for battery consumption. For long drives, i plug in the phone to charge.
  30. Nov 27, 2024 at 3:23 PM
    #60
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    I realize that this is out-of-stock at the moment. But it's worth waiting for it to come back. $19.00!!!!
    I've bought 3, one for my 4R, one for my son's Tacoma and one for my DIL's Rav4. All work perfectly. All the apps, including maps show up and can be used on your screen. Simple to install.
    https://www.ebay.com/itm/305654732427
    They are in-stock from other sellers
    #60
