Winch/Bumper Setup
Discussion in '5th Gen 4Runners (2010-2024)' started by wing2, Apr 30, 2024.
  1. May 12, 2024 at 12:33 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    There's the hidden winches which incorporate into your stock bumper for a stock look. The thing is, even doing this, you're putting 100+ lbs out there in front of your front tires. This acts like a lever multiplying the weight.
    So then if you do an aftermarket bumper that's even more weight replacing the plastic stock with metal, again, in front of your tires. The front will sag. You will need to upgrade springs. You might need to get the smallest lift possible in order to look as stock as possible regarding lift.
    Just food for thought.
    It's an SUV so the springs are saggy. It's not like an f250 where you can add a winch and the truck has no idea.
  2. May 12, 2024 at 12:36 PM
    wing2
    wing2 [OP] New Member
    Richard
    2024 SR5 Premium
    Indeed. Looking stock, or hiding anything isn't important to me. I will have to go somewhere that installs this stuff, and certainly address the weight issue. Thanks.
  3. May 12, 2024 at 2:33 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I had a lift with medium duty springs and steel skid plates. When I added the lo pro bumper with 12k warn winch I sagged comically int he front and upgraded to heavy duty coils.
    The other thing to tho is even if you upgrade springs you might not get the right look you want and may even need coil overs to get the exact ride height for you.
    Here's C4 lo pro with full bull bar, C4 skids, and a warn winch with side winder hook.
  4. May 12, 2024 at 2:38 PM
    wing2
    Richard
    2024 SR5 Premium
    Very sharp.
    Thacrow likes this.
  5. May 16, 2024 at 11:43 AM
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    hossler1788, Harringbr99 and Thacrow like this.
  6. May 16, 2024 at 12:16 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    wow that's quite the setup. Looks awesome. That bumper screams - you don't wanna mess with me. what lights are you running underneath?
    Kyle11863[QUOTED] likes this.
  7. May 16, 2024 at 12:54 PM
    Kyle11863
    Big Bear California
    They fit most standard 3 inch pods as well as some of the smaller pods if you have it set up for them. In these pictures there are some Baja Designs Squadrons and Diode Dynamic SS3's
  8. May 16, 2024 at 1:22 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    what about the rock lights?
  9. May 16, 2024 at 10:31 PM
    Kyle11863
    Big Bear California
    Those might be Lasfit rock lights. Color temp looks about right. We actually have a discount code for those too if you want
  10. May 28, 2024 at 6:59 AM
    Charlievee
    Charlievee Not new member.
    Any pix of the winch install? Everything i have read said the badlands would not fit.
  11. May 28, 2024 at 11:46 AM
    DangitDad
    DangitDad New Member
    Ken
    2023 White 4Runner
    3"/2" Ironman lift, Method 703 wheels, K02's, Pedal Commander, more to come
    I don't have many pics of the winch install, just the one below. No, the Badlands doesn't fit a 2023 without a control unit relocate. Hard to imagine many brands would fit without a relocate. There's an aluminum tube that runs across the front, smack dab in the way. I didn't do any research to see if that could be moved. I probably would have looked into that if I had known the relocate would be such a pain.
    If you don't care about cutting off most of the cooling fins of your passenger fog light, you could put it behind that like I did. The bottom holes are bolted in through the body and the top bolts through a piece of angle aluminum that spans over the body hole behind the headlight. I could get more pics if you'd like.
    BTW - the yellow and black is reversed in this picture. It has since been fixed...
    jake long15 and wing2[OP] like this.
  12. May 30, 2024 at 6:57 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    C4 lo pro bumper w/ high clearance extensions and Warn eco s-12 winch. Also add factor55 fairlead and ultra hook.
    Spare Parts, wing2[OP] and Gripster like this.
  13. May 30, 2024 at 9:46 PM
    OdyRunner
    OdyRunner New Member
    I just installed a CBI Covert front bumper with bull bar, Bajadesigns S8 driving/combo amber light bar, Factor 55 fairlead and ultra hook, a DV8 fairlead flip-up license plate holder and a 12k smittybilt X20 Gen 3 winch, in addition to a full set of CBI skid plates. I like the covert bumper as it still leaves the rig looking fairly stock and I like the wireless remote that comes with the smittybilt winch. I did use the winch this past weekend and no complaints there.
    wing2[OP] and Daytonaviolet like this.
  14. May 30, 2024 at 10:00 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    Greenlane aluminum with wings, Evo 10 was a snug fit.
    Yankum fairlead, TRD skid, custom plate mount, and Victory washer bottle cover.
    dgrenier15 and wing2[OP] like this.
  15. May 31, 2024 at 5:59 AM
    Charlievee
    Nice clean look. Didn't see an option for the bullbar, but can get it with t shirt.
  16. May 31, 2024 at 11:29 AM
    OdyRunner
    CBI calls it a "Baja" front bumper and it does work with the radar cruise control, front facing camera and doesn't interfere with the multi-terrain monitor.
    Charlievee[QUOTED] likes this.
