Wildpeak Shimmy!!!!!
Discussion in '5th Gen 4Runners (2010-2024)' started by Mitch65, Dec 14, 2020.
  1. Dec 15, 2020 at 6:15 AM
    AG4RN8
    AG4RN8 New Member
    Nate
    2020 AG Pro
    Wow, I run mine at 30 cold. More coosh for my toosh.
  2. Dec 15, 2020 at 9:20 AM
    Construction
    Construction New Member
    Tony
    4Runner TRD Off Road
    stage one bumper mod, Herculiner fender flares & bumpers, Falken Wild Peaks, Spidertrax 1.25 spacers, Raptor lights, Sealight LEDs
    A little over a year ago I replaced the stock tires and wheels with Falken Wild Peaks and TRD Pro Wheels. BAD BAD BAD shimmy at 60-65mph. I aligned and then I ended up balancing them 3 times. Two different shops and two of those times road force balance and still a shimmy...not as bad but still there.
    I swapped the front for the rear tires and that helped a bit more.
    I then contacted tirebuyer.com and used the return warranty. Apparently the return and replace warranty only covers two of four tires. Tirebuyer delivered two new tires.
    Balanced them and installed them in the rear. This fixed 90% of the issue and i would only occasionally get shimmy. The weather hot cold conditions determined the severity.
    Last week I took the rig to get 4 wheel balancing, 4 wheel alignment, and tire rotation and added wheel spacers. It been a year and change since the tires were first installed and ive lived with some sort of slight shimmy.
    After last weeks service.....ALL GONE.. POOF GONE
  3. Dec 15, 2020 at 9:23 AM
    It's tough when one replaces wheels and tires at the same time...when you encounter a balance issue, you don't know if it's the wheels or the tires, and can end up chasing your tail, so to speak...glad you finally got it fixed.
    Construction[QUOTED] likes this.
  4. Dec 15, 2020 at 10:30 AM
    Construction
    Tony
    In my case I originally installed the tires on my factory rims. Same shimmy.
    Then I bought the TRD rims. Same issue. It was the tires.
    Next time I'll go for a different brand tire (BF's). I bought the Falkens because I found them on sale and I found a great discount code for tirebuyer.com. The additional $$ I paid in added balancing and driving around town to different shops ate away at the sale price savings. I could have, for the added cost, gotten the BF's and had money left over. Ohhhh well.
    SlvrSlug likes this.
  5. Dec 15, 2020 at 10:40 AM
    Mitch65
    Mitch65 [OP] New Member
    Mitch
  6. Dec 19, 2020 at 6:25 AM
    Mitch65
    Mitch
    UPDATE: So i went back to the tire shop and they re balanced the tires for me and they swear they are dead on! I get shaking when tires are cold for about the first 10-12 miles on the highway and then after that it settles down to almost nothing. WTF??
  7. Dec 19, 2020 at 7:12 AM
    Joekader
    Joekader New Member
    Joe
    Yes have the same experience I’ve learned to live with it after a few months it’s doesn’t even register part of my trucks quirks
  8. Dec 19, 2020 at 7:26 AM
    What tire pressure are you at?
  9. Dec 19, 2020 at 10:24 AM
    Mitch65
    Mitch
    35ish cold and 39ish once all warmed up
  10. Dec 19, 2020 at 10:25 AM
    Mitch65
    Mitch
    I guess these things are just super sensitive to tires lol
  11. Dec 19, 2020 at 1:22 PM
    I would say not really, i have found it to be the balance is out, and the people balancing them are also out.
    koukimonster likes this.
  12. Dec 20, 2020 at 4:30 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Are your Wildpeaks made in Thailand or the USA?
    My 1st set (265/70R17 SL) were made in Thailand and were perfect - no shimmy.
    I had pretty deep cut on one of the sidewalls and wanted another matching 265/70R17 SL on my spare. Went to Discount Tire and got 2 more tires. They replaced the cut tire for free, since I paid for the insurance. They then put both new tires (made in the USA) on the rear and swapped one of the older ones onto the spare.
    I now have some tire shimmy at 60mph that goes away after a few minutes. PSI = 32 per the door sticker. I may try 38 psi.
    I just ignore it.
    I have a road trip coming up in January - SW Missouri to Key West Florida. Plan is to drive it as is for the trip then go up a couple sizes with the addition of SPC UCA's. Haven't decided on replacement brand yet - but probably will not go with Wildpeaks again, as their taller sizes are heavier than the competition.
  13. Dec 21, 2020 at 1:34 PM
    Mitch65
    Mitch
    Mine are all made in Thailand I just checked. They are road force balanced It’s so strange. When I first jump on the highway the wheel shakes and jiggles but after about 10 miles of 60mph+ they stop and they are very smooth. If a tire is out of balance wouldn’t it always be out of balance? Wouldn’t an out of balance tire remain out of balance once it warmed up on the highway? I’m at a loss on this one and I think I’ll have to just live with it
    DRobs[QUOTED] likes this.
  14. Dec 21, 2020 at 2:42 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    i think that they are not so much out of balance more that the tires are not completely round they have high or heavy spot so at a certain speed they produce a shimmy that's why it goes away at a lower speed or higher speed only shimmy at a certain speed only
    at first i thought it was because of Trd Pro wheels but no its the tires none of us had this issue with the Dunlaps did we?
  15. Dec 21, 2020 at 4:45 PM
    Joekader
    Joekader New Member
    Joe
    It’s really tire pressure sensitive I’ve adjusted to it after a year plus and as the tires wear the adjustment is quicker
    Much less shimmy then when they were new
  16. Dec 22, 2020 at 2:17 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I'm enjoying early retirement (sounds better than unemployment) - so I don't drive my vehicle everyday.
    I think it might just be a flat spot on the tire from the vehicle sitting for a couple days.
    I'm still impressed with them. Went through a muddy field to get to one of my favorite spots over the weekend, no issues there and back.
    They are getting loud though.
  17. Dec 22, 2020 at 8:50 AM
    Mitch65
    Mitch
    What PSI you at?
  18. Dec 22, 2020 at 11:52 AM
    Joekader
    Joekader New Member
    Joe
    38 on road 28 off-road
    Mitch65[OP] likes this.
  19. Dec 22, 2020 at 4:22 PM
    #49
    Joekader
    Joekader New Member
    Joe
    I just replaced from my set fifteen52 turbo macs with stock size wildpeaks to a set of Trd with brand new Bridgestone blizzak stock sized for winter and road force balance and guess what I’m getting a shimmy at 60 LOL guess I have to deal with it
    DRobs likes this.
  20. Dec 25, 2020 at 9:00 AM
    #50
    Mitch65
    Mitch
    I had my tires balanced twice but I think I’m done messing with it for now. I’ll just live with it I guess. I can’t take it to Toyota for warranty bc they are wildpeaks and not the OEM tires
  21. Dec 25, 2020 at 9:07 AM
    #51
    Joekader
    Joekader New Member
    Joe
    It’s not just the wildpeaks I had a set of blizzaks added to my Trd rims and I have shimmy
  22. Dec 25, 2020 at 6:00 PM
    #52
    Mitch65
    Mitch
    So strange. I may try one more road force balance and if that doesn’t fix it then Forget about it. My 4Runner is a 2021 with 1500 miles on it! It has to be the tires! It’s literally brand new!
  23. Dec 25, 2020 at 6:50 PM
    #53
    Joekader
    Joekader New Member
    Joe
    Play with the tire pressures higher the better
  24. Dec 25, 2020 at 10:08 PM
    #54
    MountainMan
    MountainMan New Member
    Pacific Northwest
    I put on a set of 285 Cooper Evolution MTs a few months ago and on the trip home from the shop, they had a vibration at 45-60 mph. Crap. Going to have to get them re-balanced. Got home, adjusted tire pressure from 35 to 45 psi, then went back on the highway to town to get them re-balanced. Smooth as glass on the highway. No idea why. They've been perfect ever since.
  25. Dec 28, 2020 at 10:37 AM
    #55
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    What tire pressure? LT tires should be run at ~40 PSI (COLD) on the 4Runner. 32 PSI for Passenger rated tires.
