Wifey Doesn’t Like My Raptor Lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Rick G., Jun 10, 2024.
  1. Jun 10, 2024 at 4:05 PM
    If you keep those lights on your rig, we're gonna have to pull your man-card and evict you from the United States of Texas.
    Ironguy and scottiezilla like this.
  2. Jun 10, 2024 at 4:08 PM
    TheGreekFreak
    TheGreekFreak New Member
    Meh, I’m indifferent to them. If they were smaller and integrated nicer, I think I’d like them more. But they seem to be either too large looking (to fill the diamond grill mesh) or small but held on with cheap ass zipties.
    Between that and all the issues I’ve heard of with them burning out, I’d probably pass.
  3. Jun 10, 2024 at 5:16 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    On a positive note, he'll never be plagued by the knowledge that only some of them work.
    2Toys, djwantke and MeefZah[QUOTED] like this.
  4. Jun 10, 2024 at 5:20 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Hate raptor lights and that name.
    They look cheap, out of place and mostly run by people that are deficient in other areas .
  5. Jun 10, 2024 at 6:22 PM
    RunningBear
    RunningBear New Member
    2023 TRD ORP, Lunar Rock, KDSS
    You're in Texas. Just look at your wife with your best loving look, say "Well, bless your heart", then do whatever the hell you want.
    BenC and Borracho Loco like this.
  6. Jun 10, 2024 at 7:46 PM
    Your wife has great instincts. Yes, Raptor lights are dumb.
    They're so played out, one night a while back I had what I was certain was a Tacoma or 4R coming at me, when we passed I was shocked to see that it was an actual Raptor.
    I actually wanted to get a heritage style grill for my 2013, however I refuse to because they all have Raptor lights built in.
    2016Pro likes this.
  7. Jun 10, 2024 at 8:30 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Your wife has great taste. Raptor lights on non raptor vehicles are pure trash
    2016Pro and Nevin like this.
  8. Jun 10, 2024 at 9:20 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I'm surprised that we're this deep into page 2 and no one so far has asked for pictures of this guy's wife.
  9. Jun 10, 2024 at 9:41 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    :rimshot:
    2Toys likes this.
  10. Jun 10, 2024 at 9:44 PM
    wax poetic[QUOTED] likes this.
  11. Jun 10, 2024 at 10:17 PM
    What about lights in the hood skewp? Do they trigger you too?
    How about raptor lights on the tailgate? :boink:
    LCJ77 and Acesandeights[QUOTED] like this.
  12. Jun 10, 2024 at 10:23 PM
    I lost my vanity years ago, now I get excited about an oil change. There are a few advantages to getting older. ;)
    garoto, gptoy and Ironguy like this.
  13. Jun 10, 2024 at 10:28 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Wow, a lot of responses. After reading through them later Monday afternoon, I decided to remove the lights. Here’s the new pics, post Raptor light removal.
    The thing that really tripped my trigger was learning here that this is a Ford thing. Lol…. OK well so much for that idea.
    I have all the parts, good as new. The wire harness was never installed. If anyone wants this kit, let me know here and we can make arrangements to get it to you. You can have it for the cost of the postage. Here’s a couple pics of all the parts together Monday afternoon after I removed the lights from the grill. There’s 6 small Phillips head screws included, just not pictured here, but they will come in the package.
  14. Jun 10, 2024 at 10:36 PM
    You know the yellow, orange and red color scheme is from a Renegade CJ7, right? I believe the Bronco of the time also offered it.:bananadead:
  15. Jun 10, 2024 at 10:47 PM
    legend1011
    legend1011 New Member
    2024 White 4Runner TRD Offroad Premium (No KDSS)
    As a new owner to a 5th gen, I'm beginning to adopt a less is more approach to our truck. Before I purchased, I wanted Raptor lights, black out emblems, Toyota TRD Pro Grille, TRD Wheels, etc... For some reason, I'm liking the chrome on our TRD ORP as I find it is more unique in my area. I also am happy with our TRD ORP wheels more than I thought I would. The irony is I don't have to do a single thing and I save money.
    I tinted the windows, installed cool white leds (Dynamic Diodes) all around, and did the center console glove box organizer setup... At only 815 miles now, about the only other mods I'm interested in now are electronics:
    - All Around Cam Mod
    - Speaker Upgrade
    - Remote Start
    - Dash Cam (factory location version)
    I'm completely content with the looks and the mechanical parts of the vehicle for now.
    Ironguy likes this.
  16. Jun 10, 2024 at 10:49 PM
    Rick G.
    Well, TOYOTA also uses the yellow, orange, and red colors. I don't know who started doing it first, Jeep, or TOYOTA. I'm going to keep that badge on my grill.
  17. Jun 10, 2024 at 11:07 PM
    Rick G.
    Nope, no ladder on my T4R, lol. I also actually wish it didn't have those roof rack rails up there on the roof.
    catbrown357[QUOTED] likes this.
  18. Jun 10, 2024 at 11:34 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
    This guy’s 4R, in motion looks 100x better than every 4R that has checked off every superficial “mod” - heritage grill, black everything, 20 add on lights
    https://youtu.be/w5OAPmy5Qeg?si=t3zrMsmFosoAJIaT
    djwantke, Spare Parts and garoto like this.
  19. Jun 11, 2024 at 3:42 AM
    #49
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Hope you feel better now, complains about folks stating they don’t like something, then name calls. :facepalm:
  20. Jun 11, 2024 at 6:48 AM
    #50
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    You gotta do what you like. I don’t even care what my wife thinks about me. I certainly wouldn’t care what she thinks about an accessory I installed on my vehicle.
    djwantke likes this.
  21. Jun 11, 2024 at 8:07 AM
    #51
    Manhattan
    Manhattan New Member
    When you're considering buying something for your truck, ask yourself, "Is this a modification... or a decoration?"
  22. Jun 11, 2024 at 8:10 AM
    #52
    Good advice , at least to my personal thought process. I got raptor lights as a modification, not decoration. :cheers:
    LCJ77 likes this.
  23. Jun 11, 2024 at 8:47 AM
    #53
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    This thread is hilarious lol
    Looks clean without the raptor lights man!
  24. Jun 11, 2024 at 9:44 AM
    #54
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    She's a keeper.
    Here is an idea for that empty Grill, @Bob will love it.
    Thatbassguy, MeefZah and Bob like this.
  25. Jun 11, 2024 at 10:04 AM
    #55
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    My wife didn't like them on my 2018 TRD OR & not on my 2023 TRD Pro, but guess what, it's mine & I do what mods I want. Don't care what anyone else likes unless they're paying for it.
    She's keeping her BMW 230i stock & I don't care., although she has recently asked about window tinting. :yes::cool:
    Her's is white too & I told her i : 1. for security that dirt bags don't know who's sitting behind that door, 2.what's inside when sitting out in public & 3. keeps the dam sun out when driving & not parked in our garage too.
  26. Jun 11, 2024 at 11:04 AM
    #56
    Wow what a thread! Keep the wife,lose the lights. Things will be better all around.
    FastEddie6 likes this.
  27. Jun 11, 2024 at 11:33 AM
    #57
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    :rofl: She doesn't NOT like them that much :D.:cheers:
  28. Jun 11, 2024 at 11:40 AM
    #58
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    The yellow, orange, and red TOYOTA badge is enough.
    But if you want to break up the black get some white pinstriping and experiment on the black trim bar.
    HuskerRunner likes this.
  29. Jun 11, 2024 at 11:41 AM
    #59
    Acesandeights
    Acesandeights #34
    2024 ORP
    What about a Raptor sticker, or a blue oval on the grill?
  30. Jun 11, 2024 at 11:49 AM
    #60
    HuskerRunner
    O,NE
    2023 SR5P
    @Rick G. What about topo-ing the bar? Much finer lines than my fat finger but you get the idea
