Why I believe the 4Runner line will die in 2023.
Discussion in '6th Gen 4Runners (2025+)' started by AJRUNNERPRO, Dec 30, 2022.
  1. May 21, 2023 at 8:57 AM
    #241
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  2. May 21, 2023 at 8:59 AM
    #242
    And next is the Toyota non-stalling manual transmission lol killing stick shift for kids once and for all
  3. May 21, 2023 at 9:17 AM
    #243
    Look back in this thread and check out the 6th gen speculation thread. About half of the post are people complaining about it.
    I'll repeat what I keep saying.. We don't know for sure how reliable they will be. But, we do know that it's going to be a huge improvement in power.
    Superdave1.0 and nimby like this.
  4. May 21, 2023 at 9:23 AM
    #244
    4R777
    4R777 New Member
    You can thank the EPA for this trend. But if we get same/more power, and better fuel economy, i'll be happy.
  5. May 21, 2023 at 9:25 AM
    #245
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Um... reliability?
    Captain Spalding likes this.
  6. May 21, 2023 at 9:29 AM
    #246
    More power is already known. Reliability is the only question.
  7. May 21, 2023 at 9:29 AM
    #247
    Um - capability?
  8. May 21, 2023 at 9:30 AM
    #248
    Are we just going around in circles?
    Spare Parts and Thatbassguy like this.
  9. May 21, 2023 at 9:31 AM
    #249
    For about 9 pages now.
  10. May 21, 2023 at 9:51 AM
    #250
    Evidently, the specs for the 2.4 turbo haven't been repeated often enough, because every day or so someone seems worried that it won't have enough power. o_O
    Also, based on some of the comments, it's going to be a real shocker if every engine doesn't grenade within 15 minutes of driving off the dealer lot.
    TexasFunRunner and nimby[QUOTED] like this.
  11. May 21, 2023 at 9:59 AM
    #251
    For me capability and reliability are very closely ranked. I picked the 4Runner over the Wrangler, but just barely. If the 6th Gen isn’t as reliable as the 5th Gen I’ll slide into a Jeep in a heartbeat.
    That’ll be good for about 9 more pages of pointless bickering.
    TN_TRAIL, nimby and Thatbassguy like this.
  12. May 21, 2023 at 10:09 AM
    #252
    I remember 1 week old Tundra with 300 or so miles at the dealership for Turbo waste gate issue. With the part delays the ownerwas talking about lemon law and he was also concerned about cab removal for the repair with the design of the turbo. I wonder if Tacoma needs similar cab out procedure for turbo repair. I think Toyota is taking time to test the Tacoma this time I guess..
  13. May 21, 2023 at 10:43 AM
    #253
    Haha, it looks about half as bad as the Bronco’s plumbing.
    I’m betting this motor is the one that makes it into the 4runner. Hopefully the turbo’s location is in better spot than in the tundra’s case. It would suck if the body needs to get lifted off to service the turbo or turbo-related-breakable-things.
    djwantke[QUOTED] and Thatbassguy like this.
  14. May 21, 2023 at 10:52 AM
    #254
    I test drove a corolla before buying my 4runner. It was a MT with anti-stall and auto rev-matching. Yeah, it’s all computer controlled throttling, just like how throttle gets manipulated with traction control. It shifted all right, no intrusive computer throttle inputs. In fact, If you know how to drive a stick, you’d never notice, because it would never intervene.
    The rev matching was neat, but a little gimmicky. I think you could turn that off in the corollo.
  15. May 21, 2023 at 10:56 AM
    #255
    Nobody is talking about the sway bar disconnect! Somebody needs to figure out how we can retrofit it into our current 4runners!
    semprenissart and Thatbassguy like this.
  16. May 21, 2023 at 11:06 AM
    #256
    4runningMan
    4runningMan New Member
    New Mexico
    But is the power gonna be where you need it. In the Tacoma it is not.
  17. May 21, 2023 at 11:21 AM
    #257
    The 2.4 Turbo makes peak torque at 1700 RPMs. That's way better than anything the 4Runner has ever had, with the only exception being the V8.
    Are you referring to the 2GR FKS?
    Edit: this is just what I was talking about a few posts back. Nobody looks up the specs, and then they worry about how it's not going to have enough power.
    nimby and 4runningMan[QUOTED] like this.
  18. May 21, 2023 at 11:22 AM
    #258
    Is the new Tacoma getting a sway bar disconnect? Or, are you referring to the one in the Jeep?
    Maybe the next version of KDSS will be so good that everybody will want it.
  19. May 21, 2023 at 12:12 PM
    #259
    4R777
    4R777 New Member
    Like previous guy said, reliability is untested. Will be interesting to see see how this plays out, esp in 8yrs or so, they have to redesign again to go completely EV.
  20. May 21, 2023 at 12:42 PM
    #260
    Well that's just awesome! Thank you!
    McSpazatron likes this.
  21. May 21, 2023 at 12:53 PM
    #261
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    For some reason, this reminded me of the vehicles with front wheel drive with V-6 engines horizontal mounted. Trying to replace the three spark plugs near the firewall with only about 2" of space to work.
  22. May 21, 2023 at 12:56 PM
    #262
    4R777
    4R777 New Member
    2024 Tacoma Trailhunter
    2400W inverter
    Option built-in Air Compressor
    Recovery hooks
  23. May 21, 2023 at 2:14 PM
    #263
    I briefly owned a ‘78 Chevy Monza with a 5 liter V8. Changing the #8 spark plug involved unbolting the engine from the motor mounts and jacking it up. Needless to say that plug never got changed.
    Emblematic of the glory days of American automobile manufacturing. (/sarc)
    rickystl[QUOTED] likes this.
  24. May 22, 2023 at 5:49 AM
    #264
    broken-giver
    broken-giver BFD
    My other vehicle is Tesla and I agree. I have not had any issues with it, however when I close the door it feels like its very "light". It sounds like its gonna break. The feeling of something well made that you get from toyota is just isn't there. The build quality is way low compared to toyota.
    I am a toyota fanboy so I may be biased. But I will wait till toyota has more than a single vehicle in the area, and tesla has opened up its network to everyone so charging isn't a concern anymore on non-tesla vehicles.
    Plus there is something about the sound of ICE engine that makes me happy. No fast EV can bring me that.
  25. May 22, 2023 at 6:47 AM
    #265
    mac1usa
    mac1usa New Member
    Did anyone listen to the video of the new taco start up.
    Being a V6 fan and against change I am truly trying to be unbiased.
    When one crew started up the new Pro with the red interior I would have thought it was my 1985 Ford Tempo (first car).
    The engine sounded awful and like some POS, lots of knocking. You have this beautiful looking truck super sharp and this loud ass engine that sound like a small diesel in POS van in a third world country.
  26. May 22, 2023 at 6:50 AM
    #266
    Lol, have you ever listened to a 1GR?
    Which video was it in?
  27. May 22, 2023 at 6:55 AM
    #267
    mac1usa
    mac1usa New Member
    I am trying to find that video ugh. I watched too many last night.
    Agreed our 4Rs are a bit loud at start up for sure but I guess it’s preference. But I think it sounds much better after 30 seconds or so. I’ll try to find that video again and post a link if I find. There is obviously a ton of new videos the last few days :)
  28. May 22, 2023 at 6:59 AM
    #268
    broken-giver
    broken-giver BFD
    I happen to like the loud sound at the startup! Lets everyone in my household know, I am UP!
  29. May 23, 2023 at 6:08 AM
    #269
    Lol, I have to admit, weirdly, I love the big cooling fan sound. I think it’s because I was imprinted on big american body on frame cars as a child, but only drove imports as a teen. Heck, I’ve only ever bought mitsubishis toyotas or hondas.
    Big ass belt driven fan with clutch attached with a big ass wooosh at startup is so 1990s Crown Victoria lol. Love it!
  30. May 27, 2023 at 7:51 PM
    #270
    Taco4R
    Taco4R New Member
    2022 TRD ORP Classic Silver Metallic
    Has Toyota not run the turbo 4 cylinder in other models for years now, like some Lexus SUVs? How has reliability been there?
