Why don't many forum members put their location in their profile?
Discussion in '5th Gen 4Runners (2010-2024)' started by FatChance, Mar 22, 2025.
  1. Mar 26, 2025 at 5:06 PM
    #91
    Imdav2u
    23 TRD PRO
    Shut your mouth when you're talking to me. :)
  2. Mar 26, 2025 at 5:08 PM
    #92
    Imdav2u
    23 TRD PRO
    Did you Google most hated state? I'll give you another hint, 3 of our last 5 governor's spent time in jail.
    3JOH22A likes this.
  3. Mar 26, 2025 at 5:13 PM
    #93
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    :eek:
  4. Mar 26, 2025 at 5:16 PM
    #94
    This thread reminds me of the one people are all worried about removing tracking from their 4runner.
    But yet they carry cell phones, use credit card etc.
  5. Mar 26, 2025 at 5:30 PM
    #95
    Beachguy
    2024 TRP ORP
    Not to mention flock cameras everywhere.
  6. Mar 26, 2025 at 5:49 PM
    #96
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Then there’s me, perhaps foolishly nice Canadian, one of the only blokes on here to list their age and birthday and location, and license plate front and center. I don’t mind if y’all know my age and birthday don’t be a sketch. I’m not worried about it man, someone who wants to steal your identity can easily do it without this website guys.
  7. Mar 26, 2025 at 5:53 PM
    #97
    So good :laugh:
  8. Mar 26, 2025 at 5:55 PM
    #98
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I put my plate on yesterday when I showed new plate holder , birthday two weeks from yesterday to be 65
  9. Mar 26, 2025 at 6:29 PM
    #99
  10. Mar 26, 2025 at 6:40 PM
    #100
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    3JOH22A[QUOTED] and LCJ77 like this.
  11. Mar 26, 2025 at 6:51 PM
    #101
    Nobody should be ashamed of where they live. If you are, it's time to move.
    :rofl:
    Slopemaster and djwantke like this.
  12. Mar 26, 2025 at 6:53 PM
    #102
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Believe me I want to, but if I do I go to federal prison.
  13. Mar 26, 2025 at 8:01 PM
    #103
    UncleShorty
    UncleShorty New Member
    DJ, I have been in contact with a Nigerian prince who needs a Canadian bank into which he can transfer a large sum of funds to pay for some Nigerian stuff. Please send me your banking info and Prince Linux Ubuntu will deposit an extra $11.39MM (Canadian), in your account. Please send your info forthwith. Thank you for your assistance in this matter...
    djwantke[QUOTED] likes this.
  14. Mar 26, 2025 at 10:10 PM
    #104
    R1200Jedi
    2022 4Runner ORP
    "Once every hour, someone is involved in an internet scam. That man is Michael Scott."
    Thacrow likes this.
  15. Mar 26, 2025 at 10:49 PM
    #105
    T92
    T92 New Member
    2023 Black Tacoma SR5 SX
    Do you want talk to the manager ?
  16. Mar 27, 2025 at 4:28 AM
    #106
    for NJ’ers, why do you guys camp out in the fast lane doing the speed limit or slower and when a car comes up behind you going faster, you move over then come right back in the fast lane to do it over and over. Why not just stay right per the law? I never understood that..
  17. Mar 27, 2025 at 4:32 AM
    #107
    sometimes i just leave my doors open to my house at night so I can practice some CQB drills. Im not that lucky though. :-(
    Thacrow likes this.
  18. Mar 27, 2025 at 4:34 AM
    #108
    “click”, sound of deadbolt locking
  19. Mar 27, 2025 at 4:36 AM
    #109
    i just laughed out loud and my wife looked at me weird. Lol!!
    Imdav2u[QUOTED] likes this.
  20. Mar 27, 2025 at 5:40 AM
    #110
    jkenn6
    jkenn6 New Member
    NJ
    Just added mine!
  21. Mar 27, 2025 at 5:58 AM
    #111
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    NY'ers seem to do it too @ least when in Pa. :frustrated:
  22. Mar 27, 2025 at 6:54 AM
    #112
    Or why not just do the speed limit , "per the law" ? LOL (i had to)
  23. Mar 27, 2025 at 6:59 AM
    #113
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Those are just "recommended":anonymous::gossip::rofl:
    Steely123[QUOTED] likes this.
  24. Mar 27, 2025 at 7:32 AM
    #114
    UncleShorty
    George Carlin did a bit about driving. Went something like this...
    People who drive faster than you are maniacs. People who drive slower are idiots...
    3JOH22A, TrailSpecial22 and LCJ77 like this.
  25. Mar 27, 2025 at 8:44 AM
    #115
    they can do the speed limit in the slow lane not the passing lane per the law. Lol
    Steely123[QUOTED], LCJ77 and Imdav2u like this.
  26. Mar 27, 2025 at 9:00 AM
    #116
    T92
    T92 New Member
    I don't know why they do that. Not all of us are same. Its just NJ is most crowded state with small territory , with lots of different people and not all speak English or Spanish, some don't even read signs. Its just easy to notice compared to larger states. Ive known people who get their license in Brooklyn in non English then swap it to NJ driver license. Makes sense why they can't read signs or know anything about some laws. Also weed is legal here, so some people lack braincells.
    This is just my take, its not all bad obviously but drivers are in rush always or just plain bad. I was in TX while ago and being new and using GPS, i didn't get single honk even after missing exits etc, i was surprised how calm people were there, same for Virginia
    LCJ77 and TrailSpecial22[QUOTED] like this.
  27. Mar 27, 2025 at 9:13 AM
    #117
    Imdav2u
    23 TRD PRO
    They wouldn't survive driving around Atlanta , everyone there thinks they drive in a NASCAR race.
  28. Mar 27, 2025 at 9:48 AM
    #118
    LOL, you didn't get it.
    You're trying to point out the law of not passing only in the passing lane, while advocating for breaking a separate law of speeding yourself. My jokes seem funnier in my head sometimes.
    But I do get you trying to mainly point out the fact of New Jersey to begin with. LOL
  29. Mar 27, 2025 at 10:08 AM
    #119
    I’m going to post a link to this thread in New Member Introductions so the new folks know what they’re getting into.
    TrailSpecial22, R1200Jedi and Thacrow like this.
  30. Mar 27, 2025 at 10:38 AM
    #120
    Welcome the new members in becoming a part of the 4Runner statistic :thumbsup:
