Why does it hang so low
Discussion in '5th Gen 4Runners (2010-2024)' started by Pavo, Sep 5, 2024.
  1. Sep 12, 2024 at 10:57 AM
    #61
    3JOH22A Toyota Gigolo
    Portals are fine to daily :notsure: I have seen a few G500 4x4^2 models stuck in traffic in my daily commute. May not make sense economically, but driveability is fine.
    On the Toyota platform, because of the reduction at the hubs, portals is the only solution that reduces stress on the front diff intermediate shaft. That is, if you keep the vehicle IFS.
  2. Sep 12, 2024 at 10:59 AM
    #62
    Should've gone to the stronger Tundra rack, but whatever...
  3. Sep 12, 2024 at 11:02 AM
    #63
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    That's the rack that marlin paired with the RCLT. Tacomas have blown thru Tundra racks also, but the Tundra is much stronger. LC ram is hollow, Tundra is solid.
    3JOH22A[QUOTED] likes this.
  4. Sep 12, 2024 at 11:38 AM
    #64
    Bah! That’s not what I want to hear.
    I’m sure the required upsizing on the tires is also a huge contributor to blowing racks. I thought I remembered both kits out there require 35” tires?
  5. Sep 12, 2024 at 11:59 AM
    #65
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Isnt the service interval low? That kind of additional maintenance seems like a beating for daily. It's already a pain dropping my skids every oil change to grease the zerks.
  6. Sep 12, 2024 at 12:10 PM
    #66
    BLKNBLU
    BLKNBLU New Member
    2019 TRD OR Nauti Blue
  7. Sep 12, 2024 at 12:10 PM
    #67
    MI-FL off roader
    Brett
    Merritt Island, FL
    The 35" tires and the portals would be heavy. Incidentally, the Sherpa Racing 4th gen has the RCLT without portals and an LC 200 rack that has held up just fine. Sidebar: those kids have done well in their class. First ever Vegas to Reno desert race they finished 3rd in class. Helluva an accomplishment.
    McSpazatron[QUOTED] and 3JOH22A like this.
  8. Sep 12, 2024 at 1:05 PM
    #68
    What zerks require grease at every oil change? Or are you running 12 mo / 10k oil change intervals?
  9. Sep 12, 2024 at 1:11 PM
    #69
    2021venture
    Todd
    2021 Venture
    I do my driveshafts every 5k. Probably overkill but what I have always done.
  10. Sep 13, 2024 at 9:42 AM
    #70
    Acesandeights
    Acesandeights #34
    2024 ORP
    What does this mean?
  11. Sep 13, 2024 at 10:50 AM
    #71
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    I haven't seen any stand alone brackets, but with the sides being welded up, I'm sure this one is the strongest tank skid on the market. I wish it would've been in stock when I bought an RCI tank skid.
    https://www.4xinnovations.com/2010-2022-4runner-gas-tank-skid-plate.html
  12. Sep 13, 2024 at 11:32 AM
    #72
    Pavo
    Pavo [OP] New Member
    On my last 5th gen 4Runner I hit a recent size rock (had to drive over it as it was blocking the way on a narrow mountain road and no way to turn back) I dented the fuel tank skid and it did dent my fuel tank and changed the reading for my estimated fuel mileage from that day on
    3JOH22A likes this.
  13. Sep 13, 2024 at 11:58 AM
    #73
    Triangulated 4-link is the ideal rear axle link arrangement, two upper links and two lower links. Side-to-side motion is controlled by the links arranged in triangles:
    This is common in rock buggies but is hard to package in a production vehicle due to things like a fuel tank and cargo compartment getting in the way. Most SUVs compromise by arranging the links longitudinally and adding a panhard bar, which causes binding at higher articulation angles.
  14. Sep 13, 2024 at 1:36 PM
    #74
    Acesandeights
    Acesandeights #34
    2024 ORP
    Haha, sorry, I meant about the gas tank. I was actually ASE certified in suspension (A4), so I understand the different configurations pretty well. I've only owned a few Jeeps, but they all had the gas tank in the rear, behind the axle.
    ETA: I think I misunderstood your post. I thought you were saying that only dedicated crawlers/rock-buggies had the tank behind the axle, but most Jeeps (TJ, JL, JT, JK, XJ) do, as well as have four-link suspension. Although, a dedicated rock-buggy probably doesn't, as they will typically have a very small "fuel cell" located a little higher and forward slightly (in what would be the passenger compartment (if there was one) so the weight transfer/COG doesn't throw things off as much.
  15. Sep 13, 2024 at 1:48 PM
    #75
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    4runner sharing platforms and they are trying to satisfy to many different people. Should just have an SR5, LIMITED and PRO models with available options the way you want it. I had to remove all the car parts from my limited to be a normal 4wd again.
  16. Sep 13, 2024 at 3:41 PM
    #76
    MI-FL off roader
    Brett
    Merritt Island, FL
    The images I posted above are from a 2011, maybe the gauge of metal is thinner now? Wouldn't surprise me. He didn't daily that truck so maybe he didn't care about fuel readings. He ended up building his own fuel tank skid and attached a lexan bottom to it for sliding on the rocks. I recently put an FJ tank in my 4th gen and whats crazy is they came stock with a plastic skid. I won't ever take it in the rocks though.
  17. Sep 17, 2024 at 12:12 AM
    #77
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    THAT is a roger, and i wasnt going to get into all that, when 99.999999% dont when they think they "lifted" their rig. Big 10-4 boss. Big 10-4.
    edit- https://www.youtube.com/watch?v=47aat1tc6zw
  18. Sep 17, 2024 at 12:16 AM
    #78
    Kyblack76
    Layton, Utah
    18 TRD O.R
    I havent in 110k. Meh.... I just drive mine. I feel like itll be fine....
  19. Sep 17, 2024 at 12:38 AM
    #79
    Kyblack76
    Layton, Utah
    18 TRD O.R
    That RCLT kit (if you want to keep the ifs) is soooo awesome, and if i had unlimited funds would do on a 4runner/taco rig. So well thought out, and damn near bullet proof. For me, i carry spare tie rod ends. If im froading or not. Ive only had to swap em twice in my adventures. Shits so weak. Going to mcdonalds and wallmart, the rig is fine, do anything evey remotely silly, and you can watch the rack/rod ends bend. Most dont even know or notice. And for the 1% that actually beat on their rig, .... carry spare rod ends. If you dont really froad (offroad) then dont worry about it, and go get your coffee in the morning and be happy. Hell, 99.999% on here, dont even use 4wd, let alone the locker, nor care, and thats fine. (Toyota reliability)
  20. Sep 18, 2024 at 10:11 AM
    #80
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Yeah I've seen that video.
    I believe at the end of that video he says they likely don't hurt anything and do provide marginally better CV angles. He also recommended to just stay under 2" of lift height.
    So for the people that don't listen to that lift height recommendation I think a diff drop is a good idea.
    (Provided you have compatible skids and don't lose your ground clearance advantage)
    When I contacted Dobinsons they recommended the diff drop if I went with their long travel front shocks. So I installed it.
    It did help with the CV angles on my rig quite a bit.
    Since I already had the RCI skids everything works together nicely.
