Why are chase lights so important while off-roading?
Discussion in 'Lighting' started by bajadesigns, Feb 28, 2025.
  1. Mar 3, 2025 at 12:45 PM
    bajadesigns
    bajadesigns [OP] New Member
    Chase lights aren’t for everyone, and whether you need them depends on where you're located and the type of off-roading you do. If you're in a controlled environment with people you trust, you're likely following certain rules about speed and maintaining a safe distance. The more isolated you are, the lower the chance of something going wrong. Our company is based in Southern California, which is a hub for desert racing and off-roading. Our local spots—like Ocotillo, Glamis, Johnson Valley, and Pismo—are often packed with off-road enthusiasts, with thousands more showing up on holiday weekends. More people means more room for error, especially in shared spaces with strangers. Personally, I’m not willing to compromise the safety of my friends and family by relying on others. Whether it's a chase light, flag, or whip, these tools help reduce the risk of potential accidents. In a shared space, some people use it for its intended purpose, while others may not, the underlying goal remains the same: safety.
    The main purpose of this post is to educate on why chase lights are important and to showcase our solutions. The goal of being on this forum is to offer support and present our offerings. If you believe that chase lights aren’t necessary for your style of off-roading, that’s completely fair. However, it's important not to overlook the fact that others may genuinely need them. Ultimately, whether you choose our solution, someone else’s, or none at all, the intention here is to raise awareness about adding an extra layer of safety, whether you're on a trail or in the desert. The decision is yours—whether you need it or not.
    Best,
    Brahian Herrera | Forum Sales & Support
    Email: brahianh@bajadesigns.com | Phone: (760) 560-2252 Ext 201
  2. Mar 3, 2025 at 12:55 PM
    Looks like a "great" "active" solution for high beam users behind you too (of course results may vary)
    As for the escape, it's one of many CGI videos by this guy: https://www.instagram.com/ndm_electric/
    Ripper238[QUOTED] likes this.
  3. Mar 3, 2025 at 2:03 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Right!? God help the eyeballs of the road ragers behind me.
  4. Mar 4, 2025 at 6:56 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    And in front of me:
  5. Mar 4, 2025 at 10:08 AM
    TRDSD
    2019 TRD Off Road Premium
    Do some people use their BD and other aftermarket lights in the wrong places and the wrong times? Absolutely. I see it all the time here in Southern California. A little bit of rain and all the amber lights start going. That being said, the gist of this post is correct. There's a time and a place where chase lights are useful. In San Diego, I'm between the desert, mountains and Baja as part of my regular off roading - all these environments are within 2 hours or less. From the dust to the snow, they're an added margin of safety and visibility on my rig and in larger group runs. It's area and conditions dependent, but they shouldn't be dismissed just because they're not relevant to your part of the country or use case.
    Ripper238 likes this.
  6. Mar 4, 2025 at 10:24 AM
    Ripper238
    2019 TRD OR
    BD has cover options for their lights. They are great for those who may not be able to control them selves or for states that require auxiliary light covers.
    There may be a rare instance where chase lights are needed, but that doesn't mean they are not useful for others. Even in my case i never run the desert, or with anyone else. lol But i do back down dense forest trails by my self and the added visibility is huge. Even for setting up camp at night.
    TRDSD[QUOTED] likes this.
  7. Mar 21, 2025 at 6:31 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    This was the day we all realized we needed to get chase lights. Yeah, there's a vehicle in that mess.... somewhere. The factory red tail lights just don't cut through the dust as well as amber or yellow.
