Why a front locker?
Discussion in '5th Gen 4Runners (2010-2024)' started by like2lean, Aug 26, 2023.
  1. Mar 22, 2024 at 2:20 PM
    #91
    On the 4wd 24/7 Rubicon episode, the guy with the Tacoma on huge tires pulled his front diff mount out of the frame. Worth the watch!
    3JOH22A and Yotaholic like this.
  2. Mar 22, 2024 at 2:26 PM
    #92
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Lol. Honestly, we don't need a front Locker. With great tires this truck is amazing. I got the front Locker because they tore the axle, so it was a good time to throw a locker in there too. I'm not going to abuse it, I cannot afford to abuse it. We have a weak front end
  3. Mar 22, 2024 at 5:54 PM
    #93
    You’re probably safe, that guy had something like 38 inch tires lol
    Yotaholic[QUOTED] likes this.
  4. Mar 22, 2024 at 6:00 PM
    #94
    Yotaholic
    Olympia, WA
    The shop was putting Dana 80s and 44 inch Super Swampers on this truck. You need strength for going absolutely crazy lol
  5. Mar 23, 2024 at 4:42 PM
    #95
  6. Mar 23, 2024 at 4:55 PM
    #96
    Yotaholic
    Olympia, WA
    Waiting for my boy at Valvoline to change the diff oil. One more breakin gear oil change at 2000 miles a good idea?
    akakaiser likes this.
  7. Mar 23, 2024 at 5:27 PM
    #97
    How do you get home if a rock slices your driveshaft open like a pipe cutter on the trail?
    Quoting the guy in my off-road club that broke his:
    He removed the driveshaft and drove 300 kms home in FWD, getting normal gas mileage.
    djwantke[QUOTED] likes this.
  8. Mar 23, 2024 at 5:29 PM
    #98
    Yotaholic
    Olympia, WA
    I tried to follow your advice, but ended up with no more than 100 miles of 4Hi for the breakin
    3JOH22A[QUOTED] likes this.
  9. Mar 23, 2024 at 5:38 PM
    #99
    Yotaholic
    Olympia, WA
    And I broke some rules too. Not driving straight on dry highway is not a good idea.
  10. Mar 23, 2024 at 6:12 PM
    #100
    backpacker
    backpacker New Member
    2023 TRD ORP
    I mentioned this once before, but it seems appropriate here. We were riding in my brother-in-law's Class A motor home when, with no warning, the driveshaft broke. We were on I-10 just west of Tucson, late at night. Among the debris on the shoulder, I found an aluminum vacuum cleaner tube and a wire clothes hanger. We rigged up the vacuum cleaner tube as drive shaft, attaching it with the hanger using a pair of pliers, then drove the 100 miles to his home in Phoenix at highway speed. I expected it to break at any moment the whole way back. Our wives were oblivious to how precarious the situation was. They're used to us fixing things, but it wasn't anywhere near fixed.
    Ironguy and HuskyMike like this.
  11. Mar 23, 2024 at 6:13 PM
    #101
    Yotaholic
    Olympia, WA
    Promised them $50 cash tip, just to make them use their brain for once lol. Hope I don't have to yell at them.
    jdm-v35 likes this.
  12. Mar 23, 2024 at 7:10 PM
    #102
    Yotaholic
    Olympia, WA
    75 mph
    jdm-v35 likes this.
  13. Mar 23, 2024 at 7:31 PM
    #103
    Yotaholic
    Olympia, WA
    80 mph on an incline, a little over 2500 RPMs.
    jdm-v35 and 3JOH22A like this.
  14. Mar 24, 2024 at 1:36 AM
    #104
    Yotaholic
    Olympia, WA
    Blame that 4Runner's lame tires. Watch me with a rear locker and KO2s at 15 psi. Walked right up. I am sure it could have done it with just A-Trac too.
    https://youtu.be/qlbxNb5LjO0?feature=shared
    CygnusX-4 and Yamahamer like this.
  15. Mar 25, 2024 at 5:36 AM
    #105
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    Thanks for posting those speed pics. I also notice as the speed increased your mpg went down quite a bit LOL. I am guessing it didn't take long either for it to drop like that. 3000rpm's seems quite high to run for a long period of time.
  16. Mar 25, 2024 at 7:36 AM
    #106
    After watching many videos of ATRAC in action, I can’t help but wonder if lockers are really necessary. I’m not knocking lockers at all, but with modern electronic traction aids such as ATRAC and MTS, seems unnecessary.
    Ironguy and Yotaholic like this.
  17. Mar 25, 2024 at 7:43 AM
    #107
    Yotaholic
    Olympia, WA
    Front locker is not needed. But when there is a regear surgery going on on the diff, you might as well just throw a locker in there
    djwantke and Trail Runnah like this.
  18. Mar 25, 2024 at 7:43 AM
    #108
    Yotaholic
    Olympia, WA
    Highway wasn't flat
    jdm-v35[QUOTED] likes this.
  19. Mar 25, 2024 at 11:07 AM
    #109
    jdm-v35
    jdm-v35 New Member
    CO
    I would consider that as realistic as it gets then! Most highways people to take to get to offroading spots are through the mountains, so I appreciate that real life, non-"calculcated on paper" rpm to speed example.
  20. Mar 25, 2024 at 11:28 AM
    #110
    Yotaholic
    Olympia, WA
    That was around 2800 rpms. On flat highway it shouldn't be more 2500 rpms. The cool thing about 4.88 is that going from 65 to 80 is not a lot of work, you hardly feel it
    Trail Runnah likes this.
  21. Mar 25, 2024 at 11:33 AM
    #111
    Yotaholic
    Olympia, WA
    And not abuse it. This should be the sequence of steeps when you get stuck, A-Trac -> Rear Locker -> Front locker. Front locker as a last resort
  22. Mar 25, 2024 at 11:36 AM
    #112
    Yotaholic
    Olympia, WA
    There are 3 safety procedures for my Eaton locker. 1) Engages in 4WD only 2) Gets power when headlights are on 3) The switch needs some work and won't turn on accidently.
    Old Tanker likes this.
  23. Mar 25, 2024 at 11:37 AM
    #113
    Yotaholic
    Olympia, WA
    I turn on A-Trac after I switch to 4Lo. Never got stuck
  24. Mar 25, 2024 at 11:46 AM
    #114
    Yotaholic
    Olympia, WA
    I am not sure why it would. It just applies brakes. My JK's BLD turned on automatically in 4Lo, never had any issues. BLD is slow and needs a lot of spinning, A-Trac is pretty quick.
  25. Mar 25, 2024 at 12:16 PM
    #115
    Yotaholic
    Olympia, WA
    Watch A-Trac Vs. Front Locker. A-Trac is doing fine, so why bother with the front locker for the most part. A-Trac is instant too, locker requires one revolution(Not the ARB air locker).
    https://youtu.be/y-txV1NTMP8?feature=shared
  26. Mar 26, 2024 at 7:39 PM
    #116
    Yotaholic
    Olympia, WA
    It can and it has happened.
  27. Mar 27, 2024 at 11:18 AM
    #117
    Yotaholic
    Olympia, WA
    Forget about Sub 2000 RPMs with 4.88, it's not gonna to happen. But, but, the truck can get from 60 to 70 at a moment's notice without any work
  28. May 26, 2024 at 7:51 PM
    #118
    Forever
    Forever New Member
    Alex
    5th gen SR5
    Eibach Pro stage 1 suspension. Kenda Klever R/T 33x10.5r17 TRD wheels blacked out Freedom off road UCAs Cornfed 1/2” rear spacer Bodyarmor4x4 Hiline bumper Smittybilt X20 10k winch Roadshock LED light bar Badlands D ring shackles TrailGear roof rack Raptor lights, amber fogs, pro grill, etc.
    Bit of a thread revival here…
    My current truck is an SR5 on 33s. I’ve been wanting to upgrade to 4.88s, lockers, and 35s for a while now. Besides the additional price, I’ve been debating between a front locker vs a front torsen LSD, or just leaving the front open. Reliability being the main concern.
    Realistically, ATRAC alone has gotten me through every rock crawling scenario I’ve encountered. Yeah it’s a little clunky, but it just works. The only time I’ve ever wanted a locker is when I’ve been buried in the snow.
    just spent all yesterday recovering my friends rig who snapped up his front end, and after that whole ordeal, having a reliable front end setup seems way more appealing to me now.
    have you ever felt the need to use your front locker because everything else was letting you down?
  29. May 26, 2024 at 8:11 PM
    #119
    Years ago there was an early Runner Trail that took some wheeling trip. The Runner overheated the traction control system many times through the trip but it did make it through. When it overheats it will drop any wheel control and throw a light until it cools down. I believe the owner installed a front locker and never had the issue again.
    Captain Spalding likes this.
  30. May 26, 2024 at 9:35 PM
    #120
    If reliability is your main concern, then leave it alone. You’ve already stated that ATRAC did its job.
    Schlappesepple likes this.
