Which bump stops? (so many options)
Discussion in '5th Gen 4Runners (2010-2024)' started by SLIVER, Jan 31, 2024.
  1. Feb 8, 2024 at 11:39 AM
    4R Florida
    4R Florida New Member
    Northeast Florida
    2024 4R Off Road
    Now why didn't I think of that? LOL. :)
    Of course, I do not own this truck yet. I should in a month or so. :bananadance:
  2. Feb 8, 2024 at 11:41 AM
    CRasch505
    CRasch505 New Member
    Chris
    5th Gen 4Runner ORP
    Fifteen52 Analog HD's, Nitto Terragrapplers, 1" spacer lift front, ceramic on all glass.
    If you want, I'll shoot you some photos of what I find today if I can get the time and that should give you an idea of what you can look for.
    4R Florida[QUOTED] likes this.
  3. Feb 8, 2024 at 11:42 AM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Please do. I'm making my pre-purchase decisions so I will have everything ready. I'm going to try to measure a 2023 today (the only one I can find on a lot) to see how much rake it actually has.
  4. Feb 8, 2024 at 11:50 AM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    This video shows spacers that appear to be a 2-1/2 or 3" lift where the bump stops were not hitting. I'm only planning to do about 1" with much smaller spacers. The results with these bigger spacers and non-functioning bump stops were not good:
    https://www.youtube.com/watch?v=4-uodQ2GMQg
    djwantke and Stoney Ranger like this.
  5. Feb 8, 2024 at 1:00 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    This is a good simple video thx for sharing
    Anyone know what is the safest method for me to test my max uptravel / bump stop distance in my garage? What do I jack up, and from where?
    Thx
  6. Feb 8, 2024 at 1:03 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
  7. Feb 8, 2024 at 3:12 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    djwantke likes this.
  8. Feb 8, 2024 at 3:19 PM
    Looking for a simple test method,
    "in my garage"
  9. Feb 8, 2024 at 4:03 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Ok, I just got back from the dealership, and I don't think my shim plan is going to do the job. The 4Runner is even worse than my FJ Cruiser was!
    Measurements to the top of the fender opening on a 2024 4Runner TRD Offroad with an almost full tank of gas:
    No driver
    LF 34.75"
    RF 34.875"
    LR 37"
    RR 37"
    With driver weighing 80 pounds less than me:
    LF 34.25"
    RF 35.25"
    LR 37"
    RR 37"
    That's a full inch of front left sag!
    So to get 0.75" rake, I need (roughly) 2" lift on the driver front (a 1" spacer), and 1" lift on the passenger front (a 1/2" spacer). Two of the 0.25" Ekstrom Design spacers handles the right side. They can't be stacked more than two high though according to their website. So that either leaves the 1" left front sag or I need to find a different solution. Maybe Ekstrom has a bolt kit with longer bolts to allow 3 spacers. Three on the driver side and two on the passenger side would be about right.
    Why Toyota hasn't corrected the sag over the years I have no idea. I have always suspected that the 4Runner and FJ Cruiser were engineered for right hand drive so the driver's weight wouldn't be on the same side as the fuel tank and battery. In the USA we get the left hand drive and they don't move the fuel tank for us. Just a theory.
  10. Feb 8, 2024 at 4:17 PM
    I wouldn’t stack spacers on top of the shocks, sounds sketchier than it needs to be. Just find a single spacer the height you want.
    But if you do end up going high then getting extended bump stops are probably necessary to protect from getting smashed into an L shape lol. Dont go too high, or else your cv joints might bind at full droop.
    Also, keep in mind that the 4runner has less rake than it actually has. If you level based on cues from the body, your frame could be negative rake.
  11. Feb 8, 2024 at 4:17 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    I suppose the approach would be to jack one front wheel until the shock bottoms out and make sure the bump stop makes contact and stops compressing before that. Someone correct me if I'm wrong because until yesterday I didn't even know what a bump stop was. If I understand correctly, at the point when the shock bottoms out, the bump stop should be absorbing 100% of the load to prevent damage to the shock. Otherwise, load is being placed on a bottom out shock.
  12. Feb 8, 2024 at 4:18 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Who makes a metal 1" spacer for 2" driver side lift? I'll look online.
  13. Feb 8, 2024 at 4:23 PM
    Try cornfed spacers.
  14. Feb 8, 2024 at 4:23 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Just add small single spacers. Such as 3/8" or 1/2". And call it good enough.
    4runners are just heavy on the driver side. So id add 1/2" on the driver side and 3/8"(or 1/4") on pass. Side
  15. Feb 8, 2024 at 4:24 PM
    4R Florida
    Northeast Florida
    2024 4R Off Road
    They are plastic.
    Bilstein 5100 might be the answer, but installation costs more.
    .85 passenger and 1.75 driver
    Anyway, now off topic. Back to the bump stops.
  16. Feb 8, 2024 at 4:24 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Amazon has metal top hat spacers
  17. Feb 8, 2024 at 4:28 PM
    @djwantke . Check out tinkerers articulation video. Chances are you wont be able to articulate enough for the bumpstops to touch ..,. Unless maybe if you run without a swaybar.
    As far as I understand, exteded bumpstops are only necessary if you run spacers, to protect the stock shock. Or if you like to run through rough trails at high speeds and just want to help the springs.
  18. Feb 8, 2024 at 4:30 PM
    Bilsteins and setting ride height with the springs is the safer bet.
  19. Feb 8, 2024 at 4:32 PM
    #49
    4R Florida
    Northeast Florida
    2024 4R Off Road
    I'll have to find out what the cost is to install them. Labor has gotten so expensive that I am afraid to ask, but I'll call the shop that did my FJ Cruiser tomorrow to ask.
  20. Feb 8, 2024 at 4:50 PM
    #50
    If you have a few basic tools (or need an excuse to buy them), and if you have bones that don’t punish you for crawling around, the job is definitely doable yourself with a bit of research here or on youtube university. It can be fun to wrench on your new rig where you can, just ask @djwantke ! It also makes it easier to track down problems once they come up. Just be aware, any suspension mods will void warrantee on any problem even remotely related or theoretically caused by that mod, even if a professional installs it.
    Since needle bearing noises from the front diff are not a rare problem, you might want to drive yours for a bit to make sure you don’t need to do a warranty claim on it, before you start modding.
  21. Feb 8, 2024 at 4:54 PM
    #51
    4R Florida
    Northeast Florida
    2024 4R Off Road
    I learned today that I'm getting too old to be underneath a truck. I crawled under the new 4Runner on the lot a number of times today to look around. Changing oil is about my limit these days. No undercoating under the 4Runner just like the FJ Cruiser! :mad::mad::mad: Yet another expense to add to purchase price.
    The Toyota dealer said they could install them as part of the sale. I'd have to ask them about the warranty issue. I'm not too concerned about it. 13 years on my FJ Cruiser and nothing ever broke until last week when the alternator died. Never needed a warranty. I totally voided it anyway by doing a full suspension swap from another FJ to mine in the 1st year.
  22. Feb 8, 2024 at 4:55 PM
    #52
    Thanks everyone!
    So hold on guys
    I've watched the tinkerers vids
    I really wanna test my bumpstops, at home, because I can see they have not made contact with the LCA theres no markings whatsoever
    1. Where do I jack from to lift up one wheel? LCA?
    2 . I have KDSS and sway is "disconnected" while parked or under 12mph. But I'm def not interested in un-bolting the sucker
    3 . If I jack up one wheel, won't it go untill the shock bottoms out, whereby then that corner of the truck will start lifting as I go last that point as it's bottomed out?
    Or
    Are you saying max articulation won't bottom out the Bilstein 5100 shock, AND, won't touch bumpstop?
    THANKS
  23. Feb 8, 2024 at 4:59 PM
    #53
    4R Florida
    Northeast Florida
    2024 4R Off Road
    This was my question when I came to the thread. How do we know and what do we do about it. Sorry for hijacking the thread. :eek:
    djwantke[QUOTED] likes this.
  24. Feb 8, 2024 at 5:15 PM
    #54
    If you are running shocks that have stock travel range, and you have a swaybar on, you probably wont be able to flex it to maximum compression in a “static” test based on what I remember seeing.
    Wait!!! You have kdss right? Hmm, watch that video, maybe he could get the bumps to touch on a kdss rig.
  25. Feb 8, 2024 at 5:22 PM
    #55
    Thank you yes sir I will tonight
    @Yotaholic perhaps you have some wisdom you could share regarding Max articulation and bottom out/bump stops
  26. Feb 8, 2024 at 5:26 PM
    #56
    The way you can guarantee your setup is safe is by ensuring that the compressed and extended length of your shock is the same as the stock shock. Once you go beyond that, you’re kinda on your own with regard to finding out if full droop of the new setup will pop out the upper ball joint, or if it will make the cv joint bind…or if full compression will mash your shock.
    A tophat spacer is Ok, up to a point, but you have to keep in mind that it effectively makes the shock’s compressed length longer than stock, as well as it’s extended length. Which is why most people say that it’s safer to run a suspension lift, since the correct aftermarket shocks will have the correct extended and compressed lengths (the ride height is then basically set by running longer or heavier springs, or by adjustments to pre-load).
  27. Feb 8, 2024 at 5:30 PM
    #57
    Make sure to have your pen, notepad and pocket protector ready. Tinkerer is a mile a minute with the info he throws out. Almost wore out the pause button on youtube because I constantly had to stop to think about what he just said and showed.
  28. Feb 8, 2024 at 5:42 PM
    #58
    I have 5100s and old man emu lift springs (same spring rate as factory 600 lb)
    *5100's perch on lowest groove, set to 0", stock ride height.
    Are 5100 longer travel than factory?
    I think the OMEs are longer spring length..
    My shop made no mention of bump stops so I hope that's because they're not needed in my equation.
    But
    They didn't mention I might benefit from some KDSS correction after a 3/2 lift.
    Nor did they mention that the diff drop kit they sold me will lower my ground clearance and perhaps wasn't needed in the first place. But I mean whatever, it happened, at least it was cheap
    Chances are there's more I'm still going to find out that they likely knew but didn't mention
  29. Feb 8, 2024 at 5:58 PM
    #59
    4R Florida
    Northeast Florida
    2024 4R Off Road
    1) I'm trying to figure out suspension geometry and travel and how all of this works with, say, front Bilstein 5100's set to the .85" notch, which appears to be the most popular option. I'm not getting how that change affects the issue of the bump stops. I'm not overly concerned, but I am overly curious! :D
    2) Now I feel absolutely compelled to crawl underneath my 2011 FJ Cruiser tomorrow and see what's going on under there. I bought the base 2WD and then took the four Toyota-Bilstein upgrade shocks and the four springs from a 4WD offroad and put them on mine. I didn't know what a bump stop was then, and nobody on the FJ Cruiser forum mentioned it. It sure did the trick. Lifted the front to a perfect level and a thin shim on the driver side removed the sag. I have no idea what might have been going on under there over the years. I'd like to see it with the wheels off to see if there is any damage.
  30. Feb 8, 2024 at 6:00 PM
    #60
    I wanna say I remember in one of his vids he mentioned one of the bilstein models was slightly “extended” length, but I think compressed length was the same. I think he showed on his FJ that the little bit of the extended length wasn’t enough to bind the CV joint or over extend the UCA ball joint.
