Which 2020 4 runner is best for a build platform?
Discussion in '5th Gen Builds (2010-2024)' started by Randy H., Jun 16, 2020.
  1. Jun 17, 2020 at 9:40 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Assuming you will actually use it offroad and will flex/stuff/droop to the limit and not just put in a stiff hockey puck lift for looks, yes. You will need the body mount chop and even more clearancing in the wheel well is needed. You'll also want to re-gear.
    Going with larger tires is exponentially more involving on these IFS Toyotas than it is on the Wrangler. Sorry it sucks.
  2. Jun 17, 2020 at 9:51 AM
    So true! This is one real advantage of the Wrangler.
  3. Jun 17, 2020 at 10:01 AM
    Let the Mad Modders get after it! Meanwhile I'm trying to sit on Credit Card:amen:
  4. Jun 17, 2020 at 10:56 AM
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    I believe so. TRD trims I believe have them blacked out where as SR5, limiteds, and nightshades are painted to match. SOmeone correct me if im wrong.
  5. Jun 17, 2020 at 10:57 AM
    flyinhoot
    Nor Cal
    Thats where I run into the problem.
  6. Jun 17, 2020 at 11:12 AM
    Something I didn't see mentioned is that if you go with a KDSS equipped Off Road and extended travel coilovers, KDSS will become your limiting factor. In this scenario, you'll have to modify the KDSS as well with some spacers.
    Also, 3 1/2" of lift is pretty big for a 4Runner. You'll need to address CV angles with that much lift. You can still fit 35's (with trimming of course) in the 2.5" to 3" lift range.
    Rakcam76 and Thatbassguy like this.
  7. Jun 17, 2020 at 12:30 PM
    4runningMan
    4runningMan New Member
    New Mexico
    If I was lifting and expected ongoing suspension maintenance/mods due to actual off-roading over the years of ownership, I’d skip the KDSS. One less variable to worry about. The runner is plenty capable without the kdss.
    nimby, Rakcam76 and Randy H.[OP] like this.
  8. Jun 17, 2020 at 1:18 PM
    This is true. At stock height, or close to stock height, you benefit from better articulation. With significant lift or extended travel, ANY sway bar becomes a limiting factor. This it probably why many people eliminate the sway bars altogether.
  9. Jun 18, 2020 at 12:59 AM
    flyinhoot
    Nor Cal
    See. Thats why I like the pro, Suspension is capable and simple...Six year plan when the kid (hopefully kids) are older I gut the suspension and go big or go home. Till then the Fox stuff will work great, with a warranty.
    Broncobroke likes this.
  10. Jun 18, 2020 at 4:57 AM
    Are you going to eliminate your sway bars?
    Keep in mind that KDSS actually improves off road capability until you add a big lift.
    If you're planning on going big, then non-KDSS makes the most sense. But, at that rate, you could have bought an off-road and saved money in the long run.
    nimby likes this.
  11. Jun 18, 2020 at 7:36 AM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
    Lightly built and extremely capable: TRDOR + KDSS
    Heavily built/customized/long travel: SR5
    Influencer: Pro
  12. Jun 18, 2020 at 7:42 AM
    Toffees
    Micah
    LA
    16 LE
    Others may be able to answer with more specifics, but 3.5" lift isn't common, and anything 3" or more requires UCAs.
    BMC is required for tire fit, not lift. To fit 35s you'll be doing a lot more than simple BMC, and I'm not certain all size increases will give you linear returns.
    SlvrSlug and Thatbassguy like this.
  13. Jun 18, 2020 at 12:26 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    You might want to try KDSS before deciding against it. There’s a couple of you tube videos about it, also. Most guys going for big lifts and 35” tires are doing it for aesthetics, and it does look cool, for sure. But KDSS brings some on pavement performance advantages that are pretty good too. Life is about choices.
  14. Jun 18, 2020 at 12:31 PM
    flyinhoot
    Nor Cal
    I feel like me and you have already covered this. mine is better and thats fact. Remember we agreed.
  15. Jun 18, 2020 at 12:46 PM
    Randy H.
    Randy H. [OP] New Member
    Crew Chief
    Nevada and Utah
    I had Fox 2.5 with remote res. and Camburg UCA's on my FJ Crusier, and it was fantastic. Did Moab many times, and high speed
    off road was plush. AND it was much better on the highway. That is why I like IFS, the better you make it for off road, it also gets
    better on road. Not so with solid axle.
    El General***** likes this.
  16. Jun 18, 2020 at 12:48 PM
    You can, or at least could before 2020, so not sure about those, get an Off Road without KDSS, if you're so minded.
    Randy H.[OP] likes this.
  17. Jun 18, 2020 at 12:49 PM
    Randy H.
    Crew Chief
    Nevada and Utah
    Do they offer quick disconnect sway bar links?
  18. Jun 18, 2020 at 12:51 PM
    Not sure about quick disconnects for a T4R sway bar...I've only heard of spacers offered for KDSS equipped vehicles to allow more lift and keep the benefits of KDSS.
    Randy H.[QUOTED][OP] likes this.
  19. Jun 18, 2020 at 12:53 PM
    #49
    Randy H.
    Crew Chief
    Nevada and Utah
    I guess I'll be ok with 33's. I had 35's on my FJ cruiser. It gave me a little more clearance under the pumpkin, but it may have limited my articulation a little.
  20. Jun 18, 2020 at 12:56 PM
    #50
    Randy H.
    Crew Chief
    Nevada and Utah
    I have them on my Jeep and they make a huge difference when disconnected. But it may be different with IFS
  21. Jun 18, 2020 at 3:12 PM
    #51
    Right. But, not because it doesn't have KDSS.
    It does have better tires and shocks.
    The PRO has the same sway bars as the off-road and SR5. KDSS is an upgrade from that. It only becomes a limitation in situations where you'd probably remove the sway bars anyway.
  22. Jun 18, 2020 at 7:20 PM
    #52
    Randy H.
    Crew Chief
    Nevada and Utah
    So, no sway bar disconnect links available?
  23. Jun 18, 2020 at 7:29 PM
    #53
    I haven't looked. The KDSS has a similar effect, but it still limits travel eventually.
    I think most hardcore off-road guys just remove them altogether. This is why I would start with a non-KDSS 4runner if I was going really big with lift.
    EDIT: A guy on another forum makes them..
    Randy H.[QUOTED][OP] and Toffees like this.
  24. Jun 19, 2020 at 9:59 AM
    #54
    Randy H.
    Crew Chief
    Nevada and Utah
    That's what I need. Quick disconnects, :yes: thank you.
