When to Regear??
Discussion in 'Performance' started by 1SilverRunner, Jan 17, 2024.
  1. Jan 22, 2024 at 10:15 AM
    #121
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I have more faith in Toyota 4Runner build quality then the Jeep Wranglers. And my Wrangler was perfectly fine rolling on 37s. And I'm just running tiny 34s on the 4Runner
  2. Jan 22, 2024 at 11:02 AM
    #122
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Yotaholic dude eat a slice of humble pie for once, 34's aren't crazy on a Jeep but 34'd aren't tiny on 5th Gen 4R, look around.
    I have some clunking I don't know which bushing(s) or connection(s) are being worn out. I get suspicious humming like my wheel bearings are being worn, I've had bellows and boots fail, I had my passenger tie rods fail and come apart at the threads (drivers side jam nut had began loosening itself as well). And I don't know what else I don't know yet.
    Big tires, added weight, mods, KDSS, then wheeling and highway trips have a different effect on 4R's compared to wheeling and highway running a factory 4R.
  3. Jan 22, 2024 at 11:06 AM
    #123
    Yotaholic
    Olympia, WA
    Tiny, no? Looks a stock 4Runner to me
  4. Jan 22, 2024 at 11:07 AM
    #124
    You have small 34's to begin with
    Yotaholic[QUOTED] likes this.
  5. Jan 22, 2024 at 11:07 AM
    #125
    What's your diameter
  6. Jan 22, 2024 at 11:07 AM
    #126
    Load E is nice and thick tho
    Yotaholic likes this.
  7. Jan 22, 2024 at 11:10 AM
    #127
    Yotaholic
    Olympia, WA
    5
    A measly 33.8, probably pressed to like 32 underneath the truck.
  8. Jan 22, 2024 at 11:14 AM
    #128
    Yotaholic
    Olympia, WA
    Drove on a horrible trail yesterday, and I was fully prepared for a flat tire or two, but the Load E did its job :bowdown:
  9. Jan 22, 2024 at 11:20 AM
    #129
    Nice I agree, I have never got as much as even a leak. and I have 2 nails and a legit lag bolt in them, right now.
    See attached thread screenshot from yesterday.
    I have read in research lately that load E's have their drawbacks when wheeling as well which I didn't fully consider but ya
  10. Jan 22, 2024 at 11:28 AM
    #130
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Simple solution: If the road is too rough, then you just need to drive faster to get on top of it.
  11. Jan 22, 2024 at 11:43 AM
    #131
    Yotaholic
    Olympia, WA
    Then you risk breaking other things :D
  12. Jan 22, 2024 at 11:47 AM
    #132
    Is this opposite day?
    Regearing will absolutely improve performance. And, It can actually improve fuel economy by allowing the transmission to operate in overdrive with less downshifting required.
    semprenissart, Rob41 and djwantke like this.
  13. Jan 22, 2024 at 11:49 AM
    #133
    Not gunna do that with my 5100's! :p
  14. Jan 22, 2024 at 11:51 AM
    #134
    Yotaholic
    Olympia, WA
    Not a big deal unless absolutely necessary in case of 37s
  15. Jan 22, 2024 at 11:57 AM
    #135
    I think it depends on the specific tire. My load range E 295 MT's ride like pillows compared to my load range C 285 AT's.
    djwantke[QUOTED] likes this.
  16. Jan 22, 2024 at 11:58 AM
    #136
    Ya @Thatbassguy, not a big deal bud :p
  17. Jan 22, 2024 at 11:58 AM
    #137
    Great to know hmm
  18. Jan 22, 2024 at 12:04 PM
    #138
    Did I just help you rationalize a set of mud tires? :D
  19. Jan 22, 2024 at 12:05 PM
    #139
    Yotaholic
    Olympia, WA
    Load e ko2s are not too terrible on the road
  20. Jan 22, 2024 at 12:10 PM
    #140
    Right, I'm talking about their drawbacks wheeling I think
  21. Jan 22, 2024 at 12:10 PM
    #141
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    I feel sorry for anyone googling re-gearing at 4runner forums and finds this thread. No way to salvage it at this point IMHO.
  22. Jan 22, 2024 at 12:20 PM
    #142
    Yotaholic
    Olympia, WA
  23. Jan 22, 2024 at 12:20 PM
    #143
    :threadjacked:
  24. Jan 23, 2024 at 8:26 AM
    #144
    flight
    flight New Member
    Plenty of options to really send things sideways here.
    On my 5th tank of gas since the last reset and its in the high 19s now on 33s. But I have nitro 4.88s in storage
    djwantke likes this.
  25. Jan 23, 2024 at 9:21 AM
    #145
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Are your supercharged? Only guessing since you have a afr gauge.
    djwantke and Thatbassguy like this.
  26. Jan 23, 2024 at 11:26 AM
    #146
    flight
    flight New Member
    Yeah, waiting for my mpg to drop but it wants to stay at 19.8. It’ll be a couple months until i get the 4.88 installed and probably 34’s
    hossler1788[QUOTED] and djwantke like this.
  27. Jan 23, 2024 at 1:36 PM
    #147
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Final two cents. Looks like regearing is beneficial to anyone running a 33" tire and up.
    If you normally have a heavy payload, you're towing, or you live in a mountainous area and want to run anything above 33" tires, regearing is damn near mandatory IF you want to maintain some decent performance.
    When I make the move to 34s, a regear to 4.56s will be following shortly.
    This thread was a damn mess but I'm still glad I asked. Thank you guys for contributing.
    If you're reading this in the future. I'm sorry. :rofl:
    *Final note: Power adders aside, I think we should fix the problem at it's source. If the car is slow because you've effectively geared the car out of it's efficiency range; REGEAR IT. Tunes and superchargers help with the lack of power. But If you're going to be running a 34s or 35s moving to 4.56 gears will correct your ratios and improve your driving experience in almost every way.
    :nuclear::nuclear::nuclear::nuclear::nuclear::nuclear::nuclear::nuclear::nuclear::nuclear:
  28. Jan 23, 2024 at 1:57 PM
    #148
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    I'm glad you were able to get some good info. You have drawn the right conclusion.
  29. Jan 23, 2024 at 1:59 PM
    #149
    flight
    flight New Member
    Nitro doesn't even seem to list 4.56 as a recommendation. 5.29 and 32's sounds fun
  30. Jan 23, 2024 at 2:06 PM
    #150
    1SilverRunner
    Tejas
    That is why you go with East Coast Gear Supply.
    Now for the love of everything that is holy let this thread die
    :deadhorse:
    Thatbassguy and Rob41 like this.
