When to Regear??
Discussion in 'Performance' started by 1SilverRunner, Jan 17, 2024.
  1. Jan 19, 2024 at 10:18 PM
    #91
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Watch me when I roll on 37s :cool:
  2. Jan 19, 2024 at 10:21 PM
    #92
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Nice. I was comparing specs the other day and their weight surprised me. Truth be told that’s why I started this thread. Curious about people’s opinions after I realized my 33” ridge grappler weighs as much as a 34” at3.
    Considered making the switch.
  3. Jan 19, 2024 at 10:34 PM
    #93
    1SilverRunner
    Tejas
    @Yotaholic
    If you’re curious about some of the work it take to make a rig reliable and drivable on 37’s the owner of Sandy Cats has a YouTube channel and posts a lot of stuff on his 4Runner.
    It’s very heavily modified but it’s a beast for sure. I believe it’s regeared to 4.88 to run 37s. Dana 60 rear end.
    Edit: added an older video from this guy talking about running 34s.
    https://youtu.be/tyR78T2FyMk?si=3XK7S6ruvHL7WAUe
  4. Jan 19, 2024 at 10:49 PM
    #94
    Yotaholic
    Olympia, WA
    Dana 60 is not needed for 37s, Dana 60 is for 40 and above
  5. Jan 19, 2024 at 10:49 PM
    #95
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I mean, I will. Lol
    Get chopping
    1SilverRunner[OP] likes this.
  6. Jan 19, 2024 at 10:52 PM
    #96
    1SilverRunner
    Tejas
    I think it really depends on your use case. If you’re gonna cruise around town all day, sure. Maybe even do some light trails. Sure. But this thing is a hard core rock crawler that can bomb through the desert at 65-70 mph and be fine.
    Pretty gnarly machine
    Trail Runnah and Thatbassguy like this.
  7. Jan 20, 2024 at 6:14 AM
    #97
    This. I think the only way to go that crazy on a 4Runner is if you have a near endless supply of money and want to be different, or you have a shop or channel that you are using it to promote. Otherwise it's just not the right tool for the job.
    It would not make sense to me to spend all the time and money on that and have it be a constant project when I can go down to the Jeep dealer, and for the same approximate money as a TRD Pro, get a Rubicon JL or JT that with ~2K in suspension mods can run a 38" tire more reliably AND effectively. (If you shop right, you can even get a Rubicon gladiator right now for 4R SR5 money)
    I think if you need that size tire, the 4Runner is just not the right vehicle for what you're trying to do. For milder off-roading and overlanding stuff, I think it's a terrific platform, and I think a 33 to 34 inch tire should be plenty.
    And don't forget about the 80 series, you can run a 37-in tire on those fairly easily, and they're very capable. IMO the 80 series is the GOAT, it's the best Toyota 4x4 that was/will be ever offered in the US.
    If I WERE going to go crazy and do all those mods to a IFS Toyota anyway, it would not be a 4Runner. I'd do a 200 series Land Cruiser, to at least get a good engine and nice interior.
    ChessGuy and Thatbassguy like this.
  8. Jan 20, 2024 at 6:54 AM
    #98
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    This guy.... I don't even know what to say.....I guess he's an expert.
    semprenissart and Trail Runnah like this.
  9. Jan 20, 2024 at 11:48 AM
    #99
    Do it! No regear necessary. Don’t let anyone harsh your buzz.
    And if your mechanic tells your transmission is slipping, just tell him it’s in his mind lol
    :boink:
  10. Jan 20, 2024 at 11:57 AM
    #100
    Lol
    I dunno what to say either
    But I think Yotaholic was trying to get a rise out of us with his comments, half joking. and it worked
    Behind the talk, I gotta hand it to him, he's using and pushing his 4R 4WD a lot more than I.
    Thatbassguy and McSpazatron like this.
  11. Jan 20, 2024 at 3:52 PM
    #101
    Yotaholic
    Olympia, WA
    "hard core rock crawler that canbomb through the desert at 65-70 mph"
    The most stupid thing I have ever heard in a long time. Rock crawler that can bomb through the desert at 65-70 mph, and this stupidity gets two likes :eek:
    I ran 37s on my JK Dana 44s when I lived in CA. Did rock crawling including the Rubicon trail. Sold my JK after it had 120k miles, no issues whatsoever.
    You don't need Dana 60 for 37s, and you don't freaking need 37s to "bomb through the desert"
  12. Jan 20, 2024 at 4:02 PM
    #102
    Yeah, I'm starting to think we're getting punked, also.
  13. Jan 20, 2024 at 4:41 PM
    #103
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    So nice this forum has the ignore feature.
  14. Jan 20, 2024 at 5:07 PM
    #104
    Yotaholic
    Olympia, WA
    19.7 mpg
    20240120_170517.jpg Screenshot_20240120-170339_Speedometer.jpg 20240120_170440.jpg
  15. Jan 20, 2024 at 5:43 PM
    #105
    19.7 or 18.7, either way that's pretty good
    I'm at 12.5 average
    See your truck runs perfectly fine as you can see case closed :p
  16. Jan 20, 2024 at 5:49 PM
    #106
    Yotaholic
    Olympia, WA
    Bigger tires have slowed down the speedometer, Common Sense 101.
    Anyways, see this accurate measurement
    18.7 mpg
  17. Jan 20, 2024 at 5:55 PM
    #107
    Yotaholic
    Olympia, WA
    20.1 so far on my current trip
    20240120_175235.jpg 20240120_175232.jpg Screenshot_20240120-175253_Speedometer.jpg
    djwantke likes this.
  18. Jan 20, 2024 at 5:55 PM
    #108
    Righto, I understand the concept
    $38 USD for 10gallons eh
    10gallons = 37.8litres
    ($1.65/litre)
    That's $62 CAD for 10gallons Haha
    I burn over $30 gas in 100kms, or 62 miles
    Math is fun :anonymous:
  19. Jan 20, 2024 at 5:58 PM
    #109
    Yotaholic
    Olympia, WA
    I am beating EPA with 34s, bunch of steel and Viper Cut :p
  20. Jan 20, 2024 at 6:07 PM
    #110
    Right!?
    I think ORP's are 16L/100km and I'm only at 18.5 with gas killing mods
    Yotaholic[QUOTED] likes this.
  21. Jan 20, 2024 at 10:26 PM
    #111
    Yotaholic
    Olympia, WA
    19
    20240120_220123.jpg 20240120_220130.jpg Screenshot_20240120-220106_Speedometer.jpg 20240120_220515.jpg 20240120_220327.jpg
  22. Jan 20, 2024 at 10:39 PM
    #112
  23. Jan 20, 2024 at 10:41 PM
    #113
    Yotaholic
    Olympia, WA
    Smiles
  24. Jan 20, 2024 at 10:41 PM
    #114
  25. Jan 22, 2024 at 10:03 AM
    #115
    Yotaholic
    Olympia, WA
    18 mpg doing 70 mph
  26. Jan 22, 2024 at 10:09 AM
    #116
    I replied 16 L/100 km is factory and I get 18.5.
    You replied: 19
    Still dunno what you mean
    Don't really care if you got 18 MPG at 70 mph
  27. Jan 22, 2024 at 10:12 AM
    #117
    Aren't we talking about re-gearing here
    Regearing isn't a bad idea
  28. Jan 22, 2024 at 10:12 AM
    #118
    Yotaholic
    Olympia, WA
    Bad idea if better mpg and better performance are the goal, good idea if one gives a F
  29. Jan 22, 2024 at 10:13 AM
    #119
    I mean I kinda give a fuck about my drivetrain, supposed to pass this truck to the kids
    semprenissart and Thatbassguy like this.
  30. Jan 22, 2024 at 10:13 AM
    #120
    Two things can be true at the same time
    -Ben Shapiro
