When to Regear??
Discussion in 'Performance' started by 1SilverRunner, Jan 17, 2024.
  1. Jan 19, 2024 at 4:28 PM
    #61
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I’ll keep my 4Runner xD
    Just spoke to a guy who bought a jeep new and it needed an entirely new ignition system (plugs, coils and harness) at 30,000 miles…
    He is on 37s without any drama though. So pick your poison I guess
  2. Jan 19, 2024 at 4:30 PM
    #62
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Warranty paid for it
  3. Jan 19, 2024 at 4:33 PM
    #63
    1SilverRunner
    Tejas
    But the warranty won’t help me when I’m miles away from civilization and I have to use SOS on my Garmin to get rescued lol
    semprenissart likes this.
  4. Jan 19, 2024 at 4:35 PM
    #64
    Yotaholic
    Olympia, WA
    Can happen to all cars
  5. Jan 19, 2024 at 4:36 PM
    #65
    1SilverRunner
    Tejas
    I was hopeful I wouldn’t have to regear but I see the light now.
    Trail Runnah likes this.
  6. Jan 19, 2024 at 4:38 PM
    #66
    Yotaholic
    Olympia, WA
    If you have decided to regear, then go 4.88 and 37s, and throw an Eaton locker in the front too. 34s won't quite cut it, they are very small
  7. Jan 19, 2024 at 4:40 PM
    #67
    Yotaholic
    Olympia, WA
    34s are tiny, you will hardly notice them
  8. Jan 19, 2024 at 5:06 PM
    #68
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I actually agree. If you've chopped
    Hey question do you know how exactly is the tire affected when you run 7.5" wheel compared to a 9"? What is the physical or visual effect
  9. Jan 19, 2024 at 5:06 PM
    #69
    Yotaholic
    Olympia, WA
    I am on stock wheels
  10. Jan 19, 2024 at 5:13 PM
    #70
    I don't know how the wheel width particularly affects the tire is what I'm saying.
  11. Jan 19, 2024 at 5:15 PM
    #71
    Yotaholic
    Olympia, WA
    Oh ok. I have no issues, the stock TRD wheels can take 285/75s. 13000 miles in all kinds of terrains and no issues
  12. Jan 19, 2024 at 5:43 PM
    #72
    1SilverRunner
    Tejas
    What do you mean?
  13. Jan 19, 2024 at 8:21 PM
    #73
    Hmm, I'm not a math expert, but I'm pretty sure 4.10 is higher than 3.73. :notsure:
  14. Jan 19, 2024 at 9:34 PM
    #74
    Yotaholic
    Olympia, WA
    35s and a mobile house are also higher than 34s. If that Gladiator with 4.10 is fine, then OP's 4Runner with 3.73 is much finer
  15. Jan 19, 2024 at 9:44 PM
    #75
    Huh? That doesn't even make any sense..
    Who the fuck cares what someone bolts onto a Gladiator? What does that have to do with this conversation, at all? Different vehicle, different drivetrain, etc..
    Why clog up a thread about 4runner gearing with pointless comparisons to a totally different vehicle?
  16. Jan 19, 2024 at 9:46 PM
    #76
    Yotaholic
    Olympia, WA
    Dude, it is simple mechanics, physics
  17. Jan 19, 2024 at 9:47 PM
    #77
    Yotaholic
    Olympia, WA
    I am the only one who has 34s here giving suggestions to OP, and my truck runs perfectly fine.
  18. Jan 19, 2024 at 9:49 PM
    #78
    Yeah. The 4Runner is geared high to begin with, for fuel economy. Adding a bunch of weight and bigger tires puts a bigger strain on the engine and drivetrain.
    Physics
  19. Jan 19, 2024 at 9:52 PM
    #79
    Yotaholic
    Olympia, WA
    Dude, the Gladiator has not been designed to carry that much crap and those big tires. So what are you going to say now if OP decides to mount 37 in tires? Are you going to suggest that he should strengthen his axles or, get bigger axles for the 4Runner?
  20. Jan 19, 2024 at 9:55 PM
    #80
    Yeah, and I have smaller tires and still notice reduced performance. I can't even use overdrive without it downshifting constantly.
    Your idea of perfectly fine will not be the same as everyone else's. Some people think it's underpowered to begin with.
  21. Jan 19, 2024 at 9:56 PM
    #81
    Who the fuck is talking about 37's, besides you?
    I would suggest that anyone who is doing shit that requires 37's should probably get a different vehicle.
  22. Jan 19, 2024 at 9:58 PM
    #82
    Yotaholic
    Olympia, WA
    My truck wasn't fast from Day 1, I haven't noticed anything different with 34s
  23. Jan 19, 2024 at 9:58 PM
    #83
    Yotaholic
    Olympia, WA
    37s are the new 35s
  24. Jan 19, 2024 at 10:04 PM
    #84
    If you haven't noticed the difference, you must not be paying attention. I noticed the difference from 265/70/17 KO2's to 285/70/17 Toyo AT3's instantly. Anyone who is paying attention would notice the difference jumping up in tire size. It's almost impossible not to notice.
  25. Jan 19, 2024 at 10:06 PM
    #85
    Yotaholic
    Olympia, WA
    It is all in the mind.
  26. Jan 19, 2024 at 10:07 PM
    #86
    1SilverRunner
    Tejas
    How do you like the at3’s? They are quite a bit lighter than the ridge grapplers.
    About 10 pounds or so
  27. Jan 19, 2024 at 10:08 PM
    #87
    @Yotaholic I mean aren't your 34's like 33.8? LT285/75
    Think mine are closer to 32.7.
    Dude can you say your 4R runs perfectly fine when you probably haven't even worn the 34's to 50% yet?
    You don't know what you don't know I say.
    When ppl start talking about 37's on 5th gen:
  28. Jan 19, 2024 at 10:08 PM
    #88
    What is? The will to ignore reduced performance?
  29. Jan 19, 2024 at 10:14 PM
    #89
    I'm very happy with their overall performance. They're quiet, and have decent traction in a variety of conditions. The only complaint is that I'm starting to see so dry-rot already. They're not even 4 years old, and probably have 40-50K miles on them. Treadwear has been very good.
    I wonder if the dry-rot is a result of them sitting half of the year. Toyo generally has a very good reputation for quality.
  30. Jan 19, 2024 at 10:16 PM
    #90
    1SilverRunner
    Tejas
    You’re not wrong. I was reading up on Sandy Cat’s 4Runner. He has a full custom suspension, Dana 60 rear end, triple bypass shocks. Absolutely insane build. Thing weighs close to 8,000 pounds. The work he has had to put into that thing to make it reliable is crazy. It is a constant project that seems to never be complete.
    That is what you sign up for if you start modifying a vehicle that much. I used to build race cars. They turn into money pits real fast… My 4Runner will be lightly and tastefully modified and that’s good enough for me.
    edit: Sandy Cats 4Runner is on 37s and it took aaaallllll that work to make it happen
