When to Regear??
Discussion in 'Performance' started by 1SilverRunner, Jan 17, 2024.
  1. Jan 19, 2024 at 5:33 AM
    34's are more than what's necessary for the vast majority of us. Also, anything over 33" starts to require modifications that most people probably don't want to do.
    If you want to overload your drivetrain, that's your choice. But, it's not good advice.
    Edit: aside from putting extra strain on the engine and transmission, you're also adding wear to bearings, CV axles, and steering components. This is hardly ever worth it for mild to moderate off-road use.
  2. Jan 19, 2024 at 6:10 AM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Thanks for taking the time to answer these questions.
    One concern remains. I'd like to retain the ability to comfortably cruise at higher speeds because I do cross country road trips with the wife. Very long deserted highways means I cruise at 80-90 for hours. Will moving to 34s and regearing no longer allow this? What is a comfortable cruising speed with your setup?
  3. Jan 19, 2024 at 6:27 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    If you have the money and want to do it right. Going over 285 7017 you WILL benefit from 4.56 or 4.88.
    Some may say its not needed. But driving an absolute turd that does 0-60 in 15-30 seconds is no fun.
    4runners come 3.73 with 31s. Id try and keep that ratio.
  4. Jan 19, 2024 at 6:37 AM
    1SilverRunner
    Tejas
    This is one of the tire size and gear ratio calculators I've used. I'm thinking that sticking with 4.56 would be the safer bet for 34s.
    Sounds like a regear to 4.56 is better in just about every way. Except for the wallet lol
  5. Jan 19, 2024 at 6:42 AM
    flight
    flight New Member
    This is the first thread I've ever came across with people suggesting against a regear, but 34's are fine at freeway speeds if you live in a flat geographical region.
    I ordered both a SC and gears once the drivability became an issue for long trips, and mostly to make it easier for my significant other to drive it. I've never felt I needed either for off-road, at least for how much $ it all cost.
    Another argument here is 33's are much easier to find in a pinch than 34 or 35's in your specific tire
  6. Jan 19, 2024 at 6:56 AM
    1SilverRunner
    Tejas
    Those are great points :101010:
    Trail Runnah likes this.
  7. Jan 19, 2024 at 8:42 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    big thanks for this
  8. Jan 19, 2024 at 8:44 AM
    1SilverRunner
    Tejas
    Here's another one that is useful
    Rob41 and djwantke[QUOTED] like this.
  9. Jan 19, 2024 at 8:45 AM
    Big thanks for this too
    And yours @Thatbassguy
    Regear is a topic right now too on my BC 5th Gen 4Runners Facebook members group. Surprising amou t of people,.many more than here, currently running 35's. Or some 34's. Little have regeared. Some have tuned, some have crawlbox mods. All this feedback great for perspective. Regear cost may never be in my budget so
  10. Jan 19, 2024 at 8:46 AM
    double like.
    saved this to home screen
  11. Jan 19, 2024 at 9:08 AM
    1SilverRunner
    Tejas
    I do like how the truck performs now w/ 33s. It can be a little sluggish at elevation or going up big hills, but its very livable and cruises nice, even loaded up.
    I've pretty well been convinced to stick with my 33s for the time being. I'll continue working on storage mods and improving organization.
    Less building, more exploring, more camping. The truck is pretty damn capable at this point. Maybe bigger is not always better.
    If I move to 34s it will be alongside a regear. Thanks for showing me the light guys!
    Glad I joined the forum recently for the wealth of knowledge here.
    Big thanks
    @Yotaholic
    @ChessGuy
    @Thatbassguy
    @hossler1788
    @djwantke
    @flight
  12. Jan 19, 2024 at 9:18 AM
    Ain't that the truth!
    Godspeed
    Thatbassguy and Yotaholic like this.
  13. Jan 19, 2024 at 9:19 AM
    Getuponit
    Getuponit New Member
    Jimmy
    2013 4Runner
    70 mph/2200 rpm. Running 4:56 with 33" AT's. Can buck a little higher on mph when needed, honestly don't think 33" AT's are built for speed. Note - I've gotten a
    awesome balance job since purchasing these Yokohamas. Neither suspension/ front end or tire vibration comes into play @ 80 mph. Haven't bucked 90 mph yet.
    Almost 20k on these skins. Hope this helps OP
    Edit: changed tire diameter from 34" to 33"
  14. Jan 19, 2024 at 9:33 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    This chart may help and they note the RPM will be higher with an automatic transmission. Be sure to multiply the RPM in the chart by .72 as that's our 5th gear ratio.
    semprenissart likes this.
  15. Jan 19, 2024 at 11:18 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    You are correct. I forgot to mention that but have updated the post :)
  16. Jan 19, 2024 at 11:58 AM
    flight
    flight New Member
  17. Jan 19, 2024 at 12:07 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
  18. Jan 19, 2024 at 12:07 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    35s and almost a 1000 lbs of crap on stock 4.10, and you guys are worried about 34s on our 3.73.
    This thing is not even Diesel
  19. Jan 19, 2024 at 12:12 PM
    #49
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    And your point is? Your comparing apples to oranges.
    Thatbassguy, semprenissart and Rob41 like this.
  20. Jan 19, 2024 at 12:19 PM
    #50
    Yotaholic
    Olympia, WA
    Why apples and oranges?
  21. Jan 19, 2024 at 12:24 PM
    #51
    Yotaholic
    Olympia, WA
    My terrible gas mileage was not because of my big tires, it was because of my crappy aerodynamics, and I solved it
  22. Jan 19, 2024 at 12:38 PM
    #52
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    my guess would be because the Pro is technically a version of the off road trim, just like the ORP is not listed as well
  23. Jan 19, 2024 at 1:15 PM
    #53
    1SilverRunner
    Tejas
    Can I start calling mine a TRD Off Road Pro then :wink:
  24. Jan 19, 2024 at 3:08 PM
    #54
    Way better transmission gearing is well. I was curious the other day, I looked up the crawl ratio of the Mojave, which has the 410 axles and 2.72 transfer case, and it was 57 :1. 4Runner and Tacoma are like 35:1.
    I just watched a Gladiator video last night, the owner had installed a 3-in lift and 38-in tires. No rubbing. Amazing how easy it is to fit big tires on a Jeep. He said the stock gearing was adequate, though it would often shift out of 8th gear at highway speeds.
  25. Jan 19, 2024 at 3:11 PM
    #55
    Good call. I had been reading through this thread earlier, but hadn't had a chance to comment.
    I I've watched a number of Toyota videos where the owner had regeared, and they all said the same thing: since they had added larger tires and more weight incrementally, they didn't realize how bad performance had gotten until they did the gear swap, and they all said they wish they had done it sooner.
  26. Jan 19, 2024 at 3:23 PM
    #56
    Yotaholic
    Olympia, WA
    Jeep is engineered to be modified, Toyota is engineered not to be modified.
    But I'm confident with 34s, things are not worse for me than it is for that Gladiator. The guy will fall off the 8th gear to 5th or 6th if he farts
  27. Jan 19, 2024 at 3:27 PM
    #57
    Yotaholic
    Olympia, WA
    They're asking $130,000 for that Gladiator
  28. Jan 19, 2024 at 4:19 PM
    #58
    1SilverRunner
    Tejas
    That’s wild.
  29. Jan 19, 2024 at 4:25 PM
    #59
    Yotaholic
    Olympia, WA
    $65,000 minimum for the truck as it is fully loaded. $65,000 for the house on top, steel bumpers, Teraflex lift, $900 ARB jack, and a bunch of other crap.
  30. Jan 19, 2024 at 4:26 PM
    #60
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    That's overwhelmingly what I hear from people as well. That's been my experience as well and will likely be regearing next summer. I'm not overloaded with gear and I've got a blower to help but I also know it will be a noticeable difference. For some reason this thread is running counter to everything else I've seen. I'm not knocking anyone, just seems a bit unusual.
