What's with the stinking gas mileage?
Discussion in '5th Gen 4Runners (2010-2024)' started by 4RMoreYears, Dec 13, 2020.
  1. Dec 14, 2020 at 12:22 PM
    Mtbpsych
    Mtbpsych New Member
    Have you ever driven a tundra? I have a 2018 crew max stock besides having 285’s and it gets 12mpg, got about 13mpg with stock tires lol the 5.7 is a gas guzzler compared to the 4.0 in the 4runners.
  2. Dec 14, 2020 at 12:40 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Do you park it outside at night or have a teenage son with a car?
  3. Dec 14, 2020 at 3:23 PM
    Lightning03
    Lightning03 New Member
    2019 TRD PRO
    My PRO got 18 mpg here in CO before I added a lift and 285’s. Now it gets 16 mpg, as others have stated the best way is to calculate by hand at the pump to get accurate mpg.
    Thatbassguy and gunsnob like this.
  4. Dec 14, 2020 at 6:25 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    TLCA #25089
    The kid is probably jerking off into the gas tank and bringing down the mpgs by dilution.
    That's what you meant, right?
    Fucking teenagers.
  5. Dec 14, 2020 at 6:43 PM
    gunsnob
    gunsnob New Member
    Vince
    2019 4Runner TRD ORP
    Wow, this conversation went south quickly.
    mrmike7189 and Thatbassguy like this.
  6. Dec 14, 2020 at 6:43 PM
    gunsnob
    gunsnob New Member
    Vince
    Same here, I am hovering around 16.9.
  7. Dec 14, 2020 at 6:53 PM
    Sixgunz
    Sixgunz Gold Member
    Phoenix
    2022 ORP
    If you could read, you would have seen that I said, "...which is worse than my 5.7 Tundra gets." If you're going to be a donkey hole, PM me and we can discuss this.
  8. Dec 14, 2020 at 6:57 PM
    Mtbpsych
    Mtbpsych New Member
    :eek::crapstorm:
  9. Dec 14, 2020 at 7:10 PM
    Sixgunz
    Sixgunz Gold Member
    Phoenix
    2022 ORP
    I've never got better than 16.5 with it - that was coming back from Flagstaff (downhill) in 2017 on stock wheels. (it's a 16) I bought it new & it's sitting on 285's now. My daughter now drives it as a DD, but I won't base anything on her driving, I'm basing it on when I drove it up until 2 years ago. My wife's 2017 Sequoia doesn't get much better than 16 normally, so if you are/were getting 18, that is awesome.
    Check out the Tundra forum on the E85 problem...there's peeps not getting better than 10 or 11 on their Tundra 5.7's with that issue. Toyota quit selling E85 5.7 motors in California in 2015-ish because of their consumer-favoring lemon laws.
  10. Dec 14, 2020 at 10:47 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    they are known for being thirsty....welcome to the forum
    4RMoreYears[OP] likes this.
  11. Dec 15, 2020 at 6:37 AM
    Red_5
    Red_5 New Member
    You need to figure out if this is (a) a problem with your mileage read-out or (b) a problem with your engine.
    Just hand-calculate your mileage for a tank. It's no big deal. If you're actually getting 10.2 mpg in a stock, brand new T4R then yes, there's something wrong.
    But I expect this is just calibration weirdness of the read-out due to the newness of your rig.
    4runningMan and HondaKen like this.
  12. Dec 15, 2020 at 6:57 AM
    4RMoreYears
    4RMoreYears [OP] New Member
    Brooklyn, Baby! (NY)
    2021 TRD OffRdPr
    I'm up to about 345 miles on the Odometer right now... So, yeah, she's still new, and I'm still breaking her in .... But still..., 10.2 MPG !!????
    Rockriv223 likes this.
  13. Dec 15, 2020 at 6:59 AM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
    Yes; either you're not calculating it (correctly), or driving too fast, or overloaded with junk, or maybe you have a mechanical issue.
  14. Dec 15, 2020 at 7:06 AM
    Toffees
    Micah
    LA
    16 LE
    That calculation is based on past driving, most of which may be test drives. Do the math yourself on a new tank and you'll be amazed by the improvement in mpg.
  15. Dec 15, 2020 at 7:12 AM
    HondaKen
    HondaKen New Member
    Ken
    WI
    2021 blue SR5 Premium
    TRD pro wheels, 12volt solutions remote start, dobinsons fronts
    Please don’t add 3 cans of sea foam and 93 octane fuel combo on the brand new truck. Do as others mentioned. Fill it up, run a few hundred miles, top it off and calculate. Let Toyota rectify this situation.
    it won’t do any harm, except waste money and time to go get it. But it won’t do any good...
  16. Dec 15, 2020 at 7:46 AM
    My 2019 was similar when new. That dash readout on mine was in the low 14s for a while, then kept creeping upward. It now stays around 19.2.
    If you currently have 345 miles on the truck, you've barely surpassed what one tank of gas should get you. If you've already filled your tank multiple times, and are going off that dash readout, stop. Turn that readout off, or -0- it out, fill your tank, drive it 'til empty, hand calculate, report back. Basically the same thing @ElectroBoy said back in post #5...if hand calculating a full tank to empty still comes up 10.2 mpg, there's definitely something off.
  17. Dec 15, 2020 at 8:47 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    That's a little weird... I was more going with someone is stealing his gas.
    7385 likes this.
  18. Dec 15, 2020 at 10:42 AM
    mousemeat
    Memphis, TN.
    70 pounds of human hair ? wtf.....did someone get run over ?
  19. Dec 15, 2020 at 10:47 AM
    #49
    ForRun
    ForRun 4Runner
    2020 orp
    Not sure if this was mentioned. Are you buying your gas at a trusted station? Years back filled up at a shell station on the interstate. Worst tank of gas ever. Had a Corolla and ended up that tank got under 15 highway. Next tank it returned to normal
  20. Dec 15, 2020 at 11:07 AM
    #50
    AgentKooper
    AgentKooper New Member
    2021 4Runner TRD Pro
    Not a serious post, IMO. The OP has barely run through a single tank of gas on a brand new car and hasn't indicated that he's followed much -- if any -- of the advice from other posters. Nothing to see here.
  21. Dec 15, 2020 at 11:16 AM
    #51
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    Thats at least 6-7 people!
  22. Dec 15, 2020 at 12:15 PM
    #52
    MeefZah
    Lexington, Ohio
    GX460
    TLCA #25089
    Oh this is embarrassing
    DRobs[QUOTED] likes this.
  23. Dec 15, 2020 at 1:49 PM
    #53
    4RMoreYears
    2021 TRD OffRdPr
    WTF ???? Not even gonna engage with such pointless, needless & vacuous stupidity
  24. Dec 15, 2020 at 2:18 PM
    #54
    ForRun
    ForRun 4Runner
    2020 orp
    How many years have you waited to use that word in a real life situation?
  25. Dec 15, 2020 at 2:28 PM
    #55
    4RMoreYears
    2021 TRD OffRdPr
    Update from the OP:
    Ok - I called my local Dealer - He told me not to get my panties in a twist too much..... He's heard of this problem before ... And that 11-14 MPG isn't too uncommon with constant short-haul trips (my profile exactly) & with the constant stop & go driving of NYC ... He also claimed that gas here in the NYC-area is now all spiked with anti-coagulants / anti-freeze, and all sorts of other such crap to prevent freezing in our fuel lines... and that this worsens gas-mileage even more
    He also said they won't really do an exhaustive fuel-line workover until at least 3000 miles on the Odometer ... So there ya have it
    I will do a manual MPG count over my next 2 fill-ups and report back.
    Thanks very much everyone for your fantastic input, advice, support, and encouragement (except @AgentKooper ... He's (or she) a douche)
    Greatly appreciated!
    promoflb, Red_5 and Thatbassguy like this.
  26. Dec 15, 2020 at 2:39 PM
    #56
    4runningMan
    4runningMan New Member
    New Mexico
    Can you get it out on a highway at 55mph and just drive it for 30 miles and see what the gauge says?
    Thatbassguy and nimby like this.
  27. Dec 16, 2020 at 10:29 AM
    #57
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    What's an exhaustive fuel line workover?
  28. Dec 16, 2020 at 1:43 PM
    #58
    4RMoreYears
    2021 TRD OffRdPr
    Just a thorough checkup of the fuel line and fuel delivery system.... (I guess)
  29. Dec 16, 2020 at 4:37 PM
    #59
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
    How many stoplights/signs/turns are you stopping at per mile? If its more than 2 theres your answer.
    The official mpg test does about 1 stop every half mile. You have a heavy vehicle so any deviation will give worse^2 results
  30. Dec 16, 2020 at 9:20 PM
    #60
    4RMoreYears
    2021 TRD OffRdPr
    This is super interesting detail. THANKS!
