Whats everyone getting for MPG?
Discussion in 'General 4Runner Talk' started by Ghost, May 18, 2014.
  1. Sep 29, 2019 at 8:58 AM
    #121
    PAnatureboy
    PAnatureboy New Member
    2018 4r TRD Off Road mag gray
    I normally at home driving I reset mpg after about 3 refills. I did reset it before leaving for Florida. I get between 17 and 19 around home.
    4runGirl88 likes this.
  2. Sep 29, 2019 at 6:04 PM
    #122
    2016Pro
    How are you measuring it? I wouldnt go by the vehicles calculation.
  3. Sep 30, 2019 at 6:15 AM
    #123
    PAnatureboy
    I keep an eye on miles per quarter tank. I was averaging 100-115 per quarter tank. With the 20 gallon tank it figures to be close to the 4r numbers.
  4. Sep 30, 2019 at 9:36 PM
    #124
    Twisted Bow
    Twisted Bow New Member
    '95 3.0
    12 highway :burnrubber:. Code 52 lol.
  5. Sep 30, 2019 at 10:45 PM
    #125
    jonny_04
    jonny_04 New Member
    '19 TRD Off Road w/KDSS
    King Shocks 2.5 w/adjusters, Total Chaos uca, Icon 2" rear coil, Nitto Ridge Grapplers 285/70/17, Rigid D-Series amber fog lights, Morimoto HID & LED lights, Meso custom dome light.
    3" lift, 285s, and 15k miles; currently at 19.0mpg, hasn't changed from stock at all. lol
  6. Oct 9, 2019 at 2:28 PM
    #126
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    13 MPG Average
    1991 2nd Gen 4Runner
    Best since engine rebuild 15.22 MPG
    Worst is 10.60 MPG (When I had to get it smogged 10° timing)
    Works best at 14° timing on 87 Regular Grade usually Union 76
    Mods:
    3VZ-E, Thorley's, test pipe with K&N-57-Series CAI!
    CAI is now shrouded in an insulated aluminum box with an acrylic cover and ported to the OEM headlight funnel. Best mileage as of 11Nov2019 was 16.18 MPG.
    Port-Matched and smoothed: TB, plenum, intake, and heads
    Lapped block/heads for MLS gaskets with ARP studs.
    Professional 40 µm stainless steel screen Oil Filter on Perma Cool remote filter mounting kit (no bypass)
    Zirgo 16 inch electric Fan on Aluminum Radiator, Deral thermal 185° switch/relay.
    15x7 OEM Wheels, Cooper Discoveries 31x10.5-R15's.
    OEM Gearing I think it is 4.56:1
    BJ-spacers and Daystar coil spring spacers about 1/2-1.00 inch overall lift over OEM ride height with reduced rear sag.
    Skyjacker M95 monotubes front and rear with OEM torsion bars and coils.
  7. Oct 9, 2019 at 2:34 PM
    #127
    wawuzit
    wawuzit New Member
    steve
    2019 Blue 4 runner
    none
    19.7 seems to be the normal everyday driving number
  8. Nov 5, 2019 at 1:47 PM
    #128
    4runGirl88
    4runGirl88 Get a little mud on the tires!
    2018 Black SR5 Premium (AKA Black Betty)
    I am getting 19.5 mpg. But I drive 90% highway miles. Gotta get this thing off road!!!!
  9. Nov 5, 2019 at 1:54 PM
    #129
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    Stock ORP, typically 45-55mph route to work. 18.7-18.9 mpg.
  10. Nov 6, 2019 at 2:54 AM
    #130
    mikeymtbs
    mikeymtbs New Member
    19 TRD ORP
    2019 ORP. 1” higher in front, stock tires - Nitto G2s. 30-mile highway commute twice a day.
    Generally average about 18-18.2mpg
  11. Nov 7, 2019 at 1:17 PM
    #131
    Tuco S.
    Tuco S. New Member
    I was consistently seeing 19.1 mpg for the first 4500 miles from April to July. Serviced the front and rear diffs and instantly saw a 0.7 mpg increase which has been verified across multiple fillups on fuelly. Did the first oil change at 8k miles, and now I'm seeing another slight increase.
    Overall average for the first 8250 miles is 19.5 mpg and climbing. Best tank was 20.5 mpg which will likely be surpassed on the next fillup, as I'm currently showing 21.2 mpg on the dash at the half tank mark. That's pretty impressive considering the weather has cooled significantly since Summer, and I haven't adjusted the air pressure in the tires.
    Edited to add:
    Overall average now 19.6. Best tank at 20.94.
  12. Jan 22, 2020 at 6:37 AM
    #132
    Denis23
    Denis23 New Member
    Denis
    2005 4Runner SR5
    2005 4 Runner V6 319,000 mi: 18 mpg +/- city, 24 -27 Hwy Premium Grade fuel
  13. Jan 22, 2020 at 4:27 PM
    #133
    Tama1968
    Tama1968 New Member
    Florida
    the truck tells me my average is 18.9 mpg no matter when I check it. quick glance while driving shows into the low 20's. all I know is that during travel soccer season and Christmas, I pay about as much for gas as I do for the truck itself.
  14. Jan 22, 2020 at 6:41 PM
    #134
    wawuzit
    wawuzit New Member
    steve
    2019 Blue 4 runner
    none
    Are you living in the 4Runner ?:crapstorm:
  15. Jan 23, 2020 at 5:40 PM
    #135
    xyzzy
    xyzzy New Member
    At the lake
    2019 Barc. Red TRD ORP
    For the first 1400 miles I've driven (odometer is at ~1410 miles), the dash shows me at just under 17mpg, but I haven't yet calculated the actual based on the fuel fill up receipts that I've saved in an envelope. It's also been winter here, so that should rightly reduce mpg a bit.
    I do a manual fuelly-style record keeping in a small bound notebook that I record all fuel stops, maintenance, and care I do to the vehicle chronologically and I have yet to enter all the data.
  16. Jan 23, 2020 at 5:49 PM
    #136
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    20.2 mpg
    Bone stock
    47k miles
  17. Jun 8, 2020 at 10:59 AM
    #137
    Wanderer
    Wanderer New Member
    Dave
    2013 4Runner
    Working on that
    According to the dash, 17.5. Pretty consistent unless I'm doing a 1000 mile highway drive, then a bit better.
  18. Jun 8, 2020 at 11:02 AM
    #138
    Mtbpsych
    Mtbpsych New Member
    15.7MPG.
    295’s, and a 3 inch lift.
    Probably higher if I did it by hand though.
  19. Jun 9, 2020 at 5:11 AM
    #139
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    2020 SR5 bone stock averaging 20.5 mpg mostly city driving.
    I have the DuelerH/T tires (which is basically a street tire), pumped up to 36psi, so that might account for the better than average mpg.
    Edit: Today I checked my mpg & it is 21.7mpg after driving some highway speeds this week.
    8/20/20 took a trip on highway, getting 22.5 mpg now. my mileage is getting better!
  20. Jun 9, 2020 at 6:36 AM
    #140
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    I was getting 13.1 litres/100 km, then I added a winch and a couple of bumpers and now I’m getting 13.2 litres/100km. Haha. Btw, in American speak that’s roughly 17.8 mpg. According to the gauge on the dash, anyway. And it doesn’t seem to matter how or where I drive it. I stick to regular fuel, because it runs great on that.
  21. Jun 9, 2020 at 8:33 AM
    #141
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    1992 4Runner V6 with 31's. Got 12 mpg mixed driving with last fill up. Best I have ever gotten was 20 straight highway back in the 90's.
  22. Jun 18, 2020 at 4:12 AM
    #142
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    235-15-KO2’s, 1990 3VZE, 5 speed. Right around 16 MPG Avg.
  23. Aug 20, 2020 at 5:38 AM
    #143
    tamas61
    tamas61 New Member
    Tom
    Cleveland, OH
    2018 SR5 Premium Grey
    K&N Drop in filter, resonator removals, K&N air cabin filter, Grey TRD Wheels, Michelin Defender Tires Stock size. Tints, Pedal Commander, Oil Catch can mod. Aluminum oil filter housing mod.
    20.1-20.3 in the summer, 19.3-19.6 in the winter.... mixed driving on 87 octane.
  24. Jul 26, 2021 at 1:10 PM
    #144
    Avalon2014
    Avalon2014 New Member
    2018 4Runner SR5
    None
    18.2 Mostly city driving. On long trips, 22.1.
  25. Jul 26, 2021 at 1:47 PM
    #145
    Between 13 - 15 mpg. Depends on how heavy my foot is that day.
    olliechristoper likes this.
  26. Jul 26, 2021 at 9:56 PM
    #146
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    '21 SR5 Premium. Lifted 2.5F/1R, steel skid plates and 265/70r17 Load Range E Grabber ATX. Pretty much all highway miles currently and averaging about 15 - 17 MPG.
  27. Jul 27, 2021 at 12:25 PM
    #147
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Right around 20 in the pickup, 18 in the 87 4Runner, 18 in the 99 4Runner. A lot depends on conditions, use of 4WD in the 4Runners during the winter (snow/ice to deal with), amount of city driving, highway speed (stuck behind a slow big-rig), etc etc etc. SO many variables it's hard to get a real accurate reading.
    Now throw in the quality of the gas, ethanol or not, and so on...who knows.
    Enjoy!
    Pat☺
  28. Jul 27, 2021 at 1:11 PM
    #148
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    2020 Limited with stock tires and no mods. Computer says I've averaged 18.1 in the 10,000 miles I've driven. On a recent 100 mile round trip with a mix of driving but most speeds between 50-60 MPH, the computer said I got 21.1 on the way there, and 21.9 on the way back. Based on my calculations at the pump, the computer is only slightly optimistic. Maybe a couple tenths of one MPG.
    That said, GPS shows that the speedometer runs 1-3 MPH higher than actual, depending on speed. Thus, the truck is presumably traveling slightly fewer miles than the ODO reports. And if that's the case then presumably my calculations at the pump are also a bit optimistic. So, to ballpark actual MPG, I'd take about a half-MPG off of whatever the computer is saying.
    In around town driving the computer often reports only 13-15 MPG. So less than the EPA city number. The only reason the computer reports more than 18 MPG over my 10,000 miles is that roughly half of those miles are highway. On most of my highway trips the computer has reported 20 MPG or a hair under.
  29. Jul 27, 2021 at 4:35 PM
    #149
    esavi87
    esavi87 .
    2017 TRD ORP/'15 SR5 Prem/'99 Limited
    14.4
  30. Jul 27, 2021 at 5:47 PM
    #150
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    37 mpg going down hill with foot off the pedal....
