What type of gas do you use?
Discussion in 'General 4Runner Talk' started by ExJeeper, Jun 8, 2020.
  1. Apr 18, 2024 at 5:06 PM
    #91
    TrailSpecial22 New Member
    PA
    87 around town and 93 when doing long hwy trips
    BS67 likes this.
  2. Apr 18, 2024 at 9:01 PM
    #92
    DesertSurfer
    Filled up this morning with ethanol-free 91 octane gas in Parker, Arizona at Monarch gas station. She purrs like Stormy Daniels.
    LuLu, SlvrSlug, BS67 and 1 other person like this.
  3. Apr 22, 2024 at 10:50 AM
    #93
    Awales74
    Awales74 New Member
    Be aware of placebo affect and marketing. Your engine's ECU doesn't "learn." Your engine's ECU doesn't have an octane sensor. It can detect knock which is horrendously bad. Your ECU will attempt to protect the engine by reducing the timing through knock retard. This is a defensive mechanism and not a learning mechanism. Your ECU will not invert this strategy and try to advance timing if it detects no knock. Cars with high compression ratios, forced air, and tuned cars need the higher octane to control the detonation due to the increased heat.
  4. Apr 22, 2024 at 11:15 AM
    #94
    2016Pro
    I use what the vehicle manufacturer recommends.
    PhantomTweak and LCJ77 like this.
  5. Apr 25, 2024 at 9:10 AM
    #95
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Regular 87. I look for Top Tier brand stations when I have the choice. Same thing Ive done with every vehicle Ive ever owned, with the exception of the Acura that required premium (it had 11:1 compression, 200hp from 2L).
  6. Apr 25, 2024 at 9:12 AM
    #96
    kolter45
    Denver
    Inferno Pro & BRM Sport
    In CO we can run 85, but there have been times I'm in other states that don't have 85. So I run 87 in the 4runner and taco because of that
  7. May 19, 2024 at 5:26 AM
    #97
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    A2FF9C5E-8AD9-49DF-AA8B-4F6C99216410.png Manual says 87 or higher i
  8. May 19, 2024 at 5:30 AM
    #98
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    There is zero benefit to running 91 in your Runner, unless you are purposely wanting to waste money.
    1SilverRunner and 2016Pro like this.
  9. May 19, 2024 at 5:42 AM
    #99
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    Lots of people believe running 91 or better is good for the newest six banger turbo charged Toyota Tundra, especially for towing. Seems likely that will apply to the 6th Gen Runner. Paying the extra price for premium gas in a truck sucks a donkey.
  10. May 19, 2024 at 1:08 PM
    #100
    DesertSurfer
    We can’t get ethanol-free gas here in San Diego so I thought I’d try it. Cost .75 cents a gallon less than San Diego’s 10% ethanol premium. It’s only sold as 91 premium at the pump. They also sell AV gas at 104 octane and VP Racing Fuel at 108 octane. Lots of “Rump de Dump” big V8 jet boats pull in for their high octane fix. Me, just pulled in to give it a try, didn’t seem to make a difference in power, I was however towing 2-jet skiis and gear.
  11. May 19, 2024 at 1:58 PM
    #101
    Chozen
    Chozen New Member
    2024 4Runner ORP
    Sorry I didn’t read through the posts…but the way that I understand it is that it’s a total myth that higher octane “Runs Cleaner” or is “Better”, a marketing myth to push for more profit. You are actually doing your vehicle a disservice if it’s “Not Designed” for higher octane. And 4Runner are not. They combust differently. You put higher octane into vehicles that were actually designed for it.
    Let’s keep it going and destroy another myth now…
    2016Pro likes this.
  12. May 19, 2024 at 2:45 PM
    #102
    JChiz
    JChiz Old Member
    South Of Tucson, AZ
    Regular 87 with no issues. Same for my previous 4Runner - 2008 Limited V8.
    2016Pro likes this.
  13. May 19, 2024 at 3:12 PM
    #103
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Weird, my mother's mustang says minimum 87 octane but for best performance to run 93 octane. My F150 with the 5.0 was the same and got better mpg on 91 than on 87.
    Dyno tests with the 5th gen have shown more power on 93 than on 87.
    Believe what you want.
    FWIW, I run 87 because the gains from 91 are not enough to justify the additional cost.
    Lc200 likes this.
  14. May 19, 2024 at 6:43 PM
    #104
    K20K54R
    K20K54R New Member
    89 octane, no ethanol here.
  15. May 20, 2024 at 3:57 AM
    #105
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    Dual VVTi can advance or retard timing to accommodate hot intake air temps, heavy load, and 87 octane. So under load if no detonation is detected, the engine will advance timing. How much extra power this produces will not be a significant amount in most situations.
    I learned there are certain situations where higher octane is helpful. Truck was a heavy 5800 lbs (armor, camping gear and tools) one 93 degree summer day going up a steep grade to Ashville, NC. It was knocking itself to pieces keeping a 60 mph pace. Had to drop down below 50 mph.
    2 summers later, same temp and weight on the same grade w 93 octane, the truck was able to keep a 60 to 65 mph pace without detonation.
    For 95% of 5th gen owners, 87 is fine. But, 93 has its benefits, not worth the money spent in most cases, but our engine's have a comp ratio of 10.4:1 and are designed to run on 87 or 93 and it will not hurt the 1gr one little bit to run 93.
  16. May 20, 2024 at 7:41 AM
    #106
    I'm not sure to what extent, but I am pretty sure they do.
    I learned this when I changed the timing belt on my '03. Afterward, it would not idle. It would start, and instantly stall. After some googling, it seemed that reason was that the ECU had been compensating for carbon build-up in the throttle body. Disconnecting the battery for a prolonged period of time causes it to return to factory settings. I took the intake hose off, cleaned out the throttle body, and it solved the problem.
    This is just based on what I read, and personal experience, so there's a possibility I'm off here. But, I can't really think of any other logical explanation for what happened. I'd like to know if anyone has a better idea.
    TrailSpecial22, LCJ77 and SlvrSlug like this.
  17. May 20, 2024 at 8:16 AM
    #107
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Once again proving to be one of the most well informed and helpful people on this forum. Thanks @Thatbassguy
    ECU's do in fact learn. There are two types of running modes for modern ECU's. Open loop, and closed loop. If this interests anyone you can read more here:
    https://www.enginebuildermag.com/2023/01/open-loop-closed-looped-and-learning/
    LCJ77 and Thatbassguy[QUOTED] like this.
  18. May 20, 2024 at 8:23 AM
    #108
    91 because the single VVT-i was known for knocking at high load/low RPM. I don't run it for power that's not there and all gas has state and federal mandated detergents.
    Doglover2003 and Thatbassguy like this.
  19. May 20, 2024 at 8:48 AM
    #109
    1SilverRunner
    Tejas
    87 Octane from a decent gas station. (Chevron/ Shell/ Exxon/ etc.)
    The additive package/ age/ and overall quality of fuel has more effect than the octane rating for a unmodified 1GR-FE. Routinely using a quality fuel system cleaner can be helpful for longevity as well.
    As far as performance goes this engine (in stock configuration) will see no benefit from running higher octane fuel.
    2016Pro and Thatbassguy like this.
  20. May 20, 2024 at 8:59 AM
    #110
    usfbulls
    usfbulls New Member
    Jay
    2023 Lexus GX460 Premium
    Non-ethanol..but it is readily available in the KC metro and not so much more that it breaks the bank.
  21. May 20, 2024 at 12:59 PM
    #111
    2016Pro
    I use what the manufacturer recommends 87 octane. So far I have never had a vehicle fail because of this crazy practice.
  22. May 20, 2024 at 1:05 PM
    #112
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Used 87 at Shell all along. I recently tried 89 at shell. I am on my third tank fill since 89 and my mileage has improved from 18.5 I usually got during my mix driving to about 19.6 now.
    No other change , same route, same driving habits.
    If I drive around 60mph on highways I am pushing 20.5+ mpg. On 87 it would be under 19.5mpg
    I am going to use it for a few months. It's about $3.9/gallon compared to$3.4 for normal.
    NV4Runner likes this.
  23. May 20, 2024 at 7:24 PM
    #113
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    I get noticeable mpg improvement going from Winter to Summer blend.
  24. May 20, 2024 at 8:10 PM
    #114
    Definitely. The warmer weather helps, also.
  25. May 21, 2024 at 9:22 AM
    #115
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    87 from Conoco when I'm in town
    87 from anywhere (preferably something I've heard of) when I'm on the road
  26. May 24, 2024 at 6:46 PM
    #116
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Regular unleaded from Costco or from Chevron. 2022 SR5 Premium 4WD.
  27. May 30, 2024 at 11:14 PM
    #117
    TTerraMB
    TTerraMB New Member
    2024 TRD Pro Terra
    First tank was regular unleaded and plan to stick to it as I see no benefit using premium gas for this vehicle.
    LCJ77 and 2016Pro like this.
