What to do after 4 to 5 months in storage
Discussion in '5th Gen 4Runners (2010-2024)' started by weezol, Jan 13, 2025.
  1. Jan 15, 2025 at 5:04 PM
    Check the tire pressures then just start it up and drive it.
    RUNNER4DAN likes this.
  2. Jan 16, 2025 at 4:33 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    And the under hood fluid levels.
    Toy4X4 likes this.
  3. Jan 17, 2025 at 7:14 AM
    obxbird
    obxbird New Member
    2018 Toyota 4Runner SR5 Premium
    Hopefully you have ethanol free gas in your system.
  4. Jan 17, 2025 at 7:27 AM
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5
    id personally pull the spark plugs, pull the C/OPN fuel pump relay and I would crank the engine over with the starter until the oil light goes away to prime everything.
  5. Jan 17, 2025 at 7:37 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Ethanol free gas is not required in modern fuel injection systems.
    Toy4X4 and bassist like this.
  6. Jan 17, 2025 at 8:19 AM
    Honestly, I'd just hook the battery back up, check the tire pressure, and drive it.
    If you hadn't changed the oil before storing, then I might change it. But, it seems like a waste to change it before and then after sitting. Maybe double check the level and call it good. :notsure:
    Toy4X4, icebear and bassist like this.
  7. Jan 17, 2025 at 8:29 AM
    weezol
    weezol [OP] New Member
    Thanks everyone, I did fill it with ethanol free gas and put fuel stabilizer in it.
    The only thing I’m having second thoughts on now is that I can’t remember if I left the E brake engaged or not. It is sitting inside my garage, not exposed to the elements.
  8. Jan 17, 2025 at 8:39 AM
    Oakboro, N.C
    I would not stress about it until after you get it started back up and drive it around. If stored inside, I do not see any issue with the parking brake sticking. Then again, If it does, You should find out fairly quickly if it is.
    icebear and Thatbassguy like this.
  9. Jan 17, 2025 at 9:05 AM
    Why are you filling with non ethanol after the fact? Its not going to do anything before or now.
    Just check fluid levels, gas and go.
    I've had outboards sitting longer with less worries.
  10. Jan 17, 2025 at 9:21 AM
    And the cabin filter for mouse nest. Don't want to be breathing mouse urine for a year.
  11. Jan 17, 2025 at 11:08 AM
    weezol
    I think there’s some confusion. I filled it with non ethanol before leaving it 3 months ago. My post was asking if there’s anything I need to do before starting it after taking it out of storage.
  12. Jan 17, 2025 at 11:13 AM
    Yup. My boat motor sits longer than 6 months every year with nothing special done to it.
  13. Jan 17, 2025 at 2:40 PM
    I noticed that now. My bad. Still wasn't needed but its done already.
    If mine sits more than 2 weeks I'm dying to go. But it did sit for almost 8 months last year with the re-power. Checked fluids and fired her up.
