What things about your 4Runner are a first for you?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Nov 1, 2024.
  1. Dec 7, 2024 at 3:23 PM
    #61
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    They got Adaptive cruise control on the ‘22’s eh, that’d be nice actually.
    Jedi5150[QUOTED] likes this.
  2. Dec 7, 2024 at 6:33 PM
    #62
    Jedi5150
    Jedi5150 New Member
    2022 4Runner ORP
    Yep, it's very handy. The downside is foul weather. I drive a lot in cold places and snow and ice make the radar useless in no time.
  3. Dec 7, 2024 at 9:16 PM
    #63
    NeverTooLate71
    NeverTooLate71 New Member
    Bob
    2024 4Runner SR5
    Backup Camera
    Phone connectivity (Still don't know how to always make it work with my iPhone)
    Roll Down Rear Window
    All the Buttons and Gadgets on my steering wheel and dash I still haven't figured out.
    (I'm coming from an 06 Tacoma TRD Off Road)
  4. Dec 8, 2024 at 7:01 AM
    #64
    Trouble24
    Trouble24 New Member
    Steph
    Leavenworth, WA
    2024 4Runner TRD Pro
    Ceramic Tint Prinsu Pro Roof Rack 3” Westcott lift ARB Awning
    Cup holders --- seriously
    I'd never had a vehicle with cup holders until 2017 when I bought my 2018 OR ... so I don't get super annoyed when the inserts stick to my cup. Better than the alternative and the many uncomfortable spills.
  5. Dec 8, 2024 at 7:37 AM
    #65
    My 4runner is my 1st toyota SUV
  6. Dec 8, 2024 at 2:15 PM
    #66
    Beachguy
    2024 TRP ORP
    My 4Runner was the first vehicle I ever owned that motivated me to join a forum like this.
    Jere39 and 2Toys like this.
  7. Dec 8, 2024 at 4:23 PM
    #67
    kjfswkr
    kjfswkr New Member
    New Hampshire
    2023 4 Runner
    They say CD's are old school though I miss it on my 2023 Runner.
  8. Dec 8, 2024 at 4:25 PM
    #68
    Took a road trip to Fort Sumner yesterday, and listened to 3 CDs. :)
  9. Dec 8, 2024 at 4:29 PM
    #69
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    Yeah cool. I think they used to listen to CDs at Fort Summer too. ;)
  10. Dec 8, 2024 at 4:31 PM
    #70
    First Toyota, or any Japanese vehicle for that matter.
    First 4x4 with IFS.
    First 4x4 with an E-locker.
    First vehicle with Bluetooth and a nav screen. First vehicle with backup cam.
  11. Dec 8, 2024 at 4:37 PM
    #71
    Yup. They had pre-Apple Play mules.
  12. Dec 8, 2024 at 4:44 PM
    #72
    BLKNBLU
    BLKNBLU New Member
    Yeah, those mules were reliable but their tech sucked.
