What has made my 5th gen gear shifter super squeaky?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, May 16, 2023.
  1. Jun 19, 2023 at 6:37 PM
    #121
    backpacker
    backpacker New Member
    2023 TRD ORP
    Did it pull easy, or was it a punch-yourself-in-the-face kind of thing?
  2. Jun 19, 2023 at 7:17 PM
    #122
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Lol that's funny
    So no it's not bad just send it, it pops off just like the videos. I've prolly done it 4 times now
    Goodluck
  3. Jun 23, 2023 at 9:06 PM
    #123
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Hey, I’m a little late to celebration, just wanted to say congrats on getting this solved. I’m still living with the squeak for now, but I feel a little better about getting into the console. This was definitely a good thread, will help a lot of people in the future.
  4. Jul 27, 2023 at 10:36 AM
    #124
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Finally! I had the time today to get into the console. Once you know, the fix is easy. Like posted previously, just bend back the metal strip slightly and give it it some white lithium. I also sprayed anything else that moved while I was in there. And it’s a good opportunity to clean up and detail the console parts while you have it all apart. Thanks everyone.
    9634F44A-819D-4C07-878C-6BC7EB152EBE.jpg A62FE523-340F-4F36-9323-69912E1F9828.jpg 3C8540DE-15A6-41DA-936F-D6D005AB1647.jpg
  5. Sep 11, 2023 at 12:27 PM
    #125
    antimadder
    antimadder New Member
    Bryan
    2023 ORP w/KDSS
    Pedal Commander
    I had installed an Ellis Precision shift knob set in my 2023 4Runner ORP. After a week or so, each shift would cause a very noticeable CHIRP sound. I thought of every other possibility before thinking of the shift knobs.
    I read this post, bought the grease that I needed, gathered my trim removal set and removed the Ellis Precision Shift knob set. Before I removed the trim I noticed the CHIRP was completely gone. I reinstalled the factory shift knob set. Chirp when shifting was still completely gone.
    After a week, Reinstalled the Ellis Precision shift knob set and that darn chirping sound returned. I thought to myself "NFW", sure enough it was the aftermarket shift knob that caused the chirp. The sound was coming from underneath trim, not the knob itself.
    The Ellis knobs are machined aluminum and steel. Noticeably heavier than the factory knobs. All I can think of at this point, the aftermarket knobs applied to much weight and tension somewhere in the supporting mechanism, causing the Chirp. This entire scenario was annoying AF and that after market shift knob set was somewhat expensive.
  6. Sep 11, 2023 at 12:48 PM
    #126
    Odd. I've had Ellis Precision shift knobs on for two years with no chirp whatsoever. Maybe the Toyota tech who applies the oem grease was having a bad day when they built your 4R.
    Saker likes this.
  7. Sep 13, 2023 at 2:29 PM
    #127
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    You could try the fix outlined in this thread and then reinstall the Ellis knobs and see if that solves the problem. Honestly it’s not that difficult if you want to give it a try. You don’t even need trim removal tools.
    djwantke[OP] likes this.
  8. Sep 13, 2023 at 3:09 PM
    #128
    Thats just weird.
    I have Ellis Shift Knobs on my T4R and never experience any chirp.
    As far as the being heavier, my FJ Cruiser came from factory with the equivalent of the Ellis Shift knobs, maybe not quite as heavy , but close.
  9. Sep 13, 2023 at 3:25 PM
    #129
    Hey @antimadder Thanks for sharing, that's interesting to hear. Come to think of it I installed a heavier Teton Workshop shift knob and the squeak started sometime after that, not necessarily right away. You may be on to something, that the difference in shift knobs accelerated the grease displacement.
    Honestly I bet your squeak or chirp is still the same intermittent issue that I battled then fixed in this very thread.
    Goodluck!
    (And great work @NOS4A2-1!)
    NOS4A2-1 likes this.
  10. Oct 27, 2023 at 1:57 PM
    #130
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I just suddenly got this squeak this afternoon. Opened the console, cleaned it, applied some white lithium grease to the metal part, slightly pushed the part back and no more squeak.
    I love when a rattle or a squeak can be identified and recertified in under 5 mins.
    Thank you for figuring this out.
  11. Nov 14, 2023 at 6:32 AM
    #131
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I'm guilty but eating in one is worst thing I can do.
  12. Dec 30, 2023 at 9:02 AM
    #132
    14 month thread revival. @djwantke - just wondering if the fix is still fixed. I noticed my shifter being a bit "catchy", with a bit more effort, going from P to N yesterday with lower temperatures lately. No squeak, but that may follow. I'm wondering if a shot of lithium grease on that detente strip will get my P - N shift back to smooth...
    BTW - thanks for taking one for the team on the squeak issue.
  13. Dec 30, 2023 at 1:25 PM
    #133
    @glwood54 Hey buddy !
    14 months and still going strong, no squeaks or nothing
    :burnrubber:
    Yes I would recommend some spray lube from above. And if you're willing to open up the console parts, then do it right, pull back the metal detent strip with needle nosers, and add a glob of grease underneath on the plastic gear selectors.
