What has made my 5th gen gear shifter super squeaky?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, May 16, 2023.
  1. Jun 6, 2023 at 4:19 PM
    #91
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    I’ll give this a shot first. I saw the video @djwantke posted. Maybe I’ll have some success, my squeaking noise doesn’t seem as bad as his.
    djwantke[OP] likes this.
  2. Jun 6, 2023 at 5:10 PM
    #92
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    me over here with my squeak lol :spending:
    NOS4A2-1 likes this.
  3. Jun 6, 2023 at 7:00 PM
    #93
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    https://www.toyotanation.com/threads/squeaking-shifter-on-gear-change.1202394/#post-9991810
    Found this. This guy might have found the cause, metal rubbing on plastic in the console. He seems like he solved it, but months later he comes back to post the squeak has returned. I also saw Tundras having the same problem, metal rubbing on plastic in the console. I know you lubed the whole console, but maybe it’s worth a look. He talks about using a heavy grease.
  4. Jun 6, 2023 at 7:08 PM
    #94
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    They should name this squeak after you. “The djwantke Squeak”
  5. Jun 6, 2023 at 7:28 PM
    #95
    Broooo
    That's why lube did nothing perhaps
  6. Jun 6, 2023 at 8:45 PM
    #96
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Yeah, it really could be metal components rubbing on plastics.
  7. Jun 7, 2023 at 6:53 PM
    #97
    jstam316
    jstam316 New Guy
    Kansas City
    ‘14 Limited
    I also developed the sqeak on my '14 limited recently and I saw this one guy mention "a metal detent strip" -- -- i'll likely end up checking into this after you completely chart the waters for us Derek haha!
  8. Jun 7, 2023 at 9:10 PM
    #98
    This thread must be contageous. I’m starting to get a little squeak now too.
  9. Jun 7, 2023 at 9:43 PM
    #99
    backpacker
    backpacker New Member
    2023 TRD ORP
    If that's it, I'd be tempted to learn to live with it.
  10. Jun 8, 2023 at 6:52 AM
    #100
    lol, I’d let that squeak tucker itself out too:p
  11. Jun 8, 2023 at 8:16 AM
    #101
    Sounds like it could be reoccurring and relentless eh
  12. Jun 8, 2023 at 8:16 AM
    #102
    I'm busting out the white lithium grease there where metal meets plastic tonight
  13. Jun 8, 2023 at 10:52 AM
    #103
    EC15
    EC15 ...
    If that is the case, I would bend it back to check before putting grease in there.
    Not a fan of gear because it's not a permanent fix.
  14. Jun 8, 2023 at 4:03 PM
    #104
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    Curious to see the fix.
  15. Jun 8, 2023 at 6:50 PM
    #105
    I'm just doing what the video says to do with white grease specifically, but ya man I'll attempt to 'bend back' first
  16. Jun 17, 2023 at 3:23 PM
    #106
    Holy dog shit, after all this I think he's done it.
    Squeak seems to be eliminated instantly :eek:
    Bend tension off of gear shifter metal detent strip that provides gear selection positive stop. Added white grease spray + synthetic grease gel at ground zero.
    *Photo is b4 grease
    Massive thx to @jstam316
    https://youtube.com/shorts/htPIdTLhoVE?feature=share9
  17. Jun 17, 2023 at 3:24 PM
    #107
    Homie don't play like that
  18. Jun 17, 2023 at 5:33 PM
    #108
  19. Jun 17, 2023 at 5:53 PM
    #109
    Don't forget the wire harness I forgot :burp:
    EC15 likes this.
  20. Jun 18, 2023 at 6:50 PM
    #110
    4Runner_Patrick
    2023 TRD PRO Black
    Just to clarify the fix was grease in the console?
  21. Jun 18, 2023 at 7:24 PM
    #111
    Sorry I wasn't super clear in my excitement haha
    Was partly grease but more the bending back of the gear shifter metal detent strip. Grease goes between the metal, and the plastic that looks like little steps.
    Lc200 and 4Runner_Patrick like this.
  22. Jun 18, 2023 at 8:35 PM
    #112
    Congratulations on finding the fix! There is good information at times from the other forum.
    I looked at that transmission shifter, and actually ordered one, but decided to keep the Ellis Precision set I had that matched the transfer case knob:
    The shift knob you got is very nice. I liked the feel of it.
    djwantke[QUOTED][OP] likes this.
  23. Jun 18, 2023 at 9:16 PM
    #113
    jstam316
    jstam316 New Guy
    Kansas City
    ‘14 Limited
    This is awesome! Stoked you found it and have now charted the waters for us fellow squeakers haha. Thanks for keeping us updated!
  24. Jun 18, 2023 at 9:34 PM
    #114
    Some good folks out there!
  25. Jun 19, 2023 at 3:23 PM
    #115
    4Runner_Patrick
    2023 TRD PRO Black
    Great job. How hard was it to get the console apart without breaking the clips?
  26. Jun 19, 2023 at 3:48 PM
    #116
    @4Runner_Patrick thanks man. that part was easy, I did what I saw guys do on YouTube; remove knobs and just grab whole top console with one hand either side then pull straight up.
    Captain Spalding likes this.
  27. Jun 19, 2023 at 5:07 PM
    #117
    krashDH
    krashDH New Member
    2016 SR5, 4WD
    Just to clarify a bit more for when I get the "opportunity" to tackle this on the gf's runner (no squeaks at this moment), bending that tab in the direction of the arrow so it doesn't press as hard on the "steps", as well as the grease, solved the issue?
  28. Jun 19, 2023 at 5:23 PM
    #118
    @krashDH yes sir exactly right, couldn't have said it better myself.
  29. Jun 19, 2023 at 5:25 PM
    #119
    @krashDH I hope you enjoy the 'opportunity' haha
  30. Jun 19, 2023 at 5:54 PM
    #120
    krashDH
    krashDH New Member
    2016 SR5, 4WD
    I have had plenty other opportunities with this vehicle in the month we've had it in our possession so hopefully I don't have to experience this for a while :)
