What has made my 5th gen gear shifter super squeaky?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, May 16, 2023.
  1. May 21, 2023 at 8:38 AM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    That'd be one of my first big strikes for Toyota, if I need replacement. 2016 ain't that old, counting on them quality Japanese parts. Is what it is tho, I'm nearing 90,000 kms, more bills are coming
  2. May 21, 2023 at 8:44 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    I can't comment from first hand knowledge, but it does sound like it's coming from the console just listening to the video....that being said if it is coming from below at the transmission it should be much louder if listening to it from under the vehicle, if coming from the console it would be less noticeable from underneath, if you had someone shift while you listen from under there it should be obvious as to where the noise is coming from.
  3. May 21, 2023 at 8:51 AM
    Thanks again for the replies, everything is super helpful.
    @AuSeeker I'll rope my wife in for this one, she can handle the shifting part haha
  4. May 21, 2023 at 10:03 AM
    EC15
    EC15 ...
    @djwantke
    Good luck on your quest.
    If it does lead you to the NSS, it can be had for about $100. It's easy to access and easy to swap (2 bolts and a plug)...if it isn't corroded to the shaft.
    My last 5th gen was a 2015, NSS swap in 2021.
    NOS4A2-1 and djwantke[OP] like this.
  5. May 21, 2023 at 2:13 PM
    @EC15 great advice appreciate that
  6. May 21, 2023 at 2:15 PM
    Popping console open, little gnarlier than initially expected
  7. May 21, 2023 at 2:16 PM
    Anyone point me where to attack here
  8. May 21, 2023 at 2:36 PM
    1. Salvage the quarter.
    2. Shop vac all the loose debris.
    3. Spray bottle with soapy water and agitate with disposable brush to loosen and remove remaining debris and any sticky stuff.
    4. Now that it’s as clean as possible, have someone drive you around while you operate the shifter with your ear close to the shifter as possible to see if you can pinpoint the squeak.
  9. May 21, 2023 at 3:27 PM
  10. May 21, 2023 at 4:13 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    So finally able to view and listen to your video. That’s what my squeak sounds like, just not as loud. I was able to get under the vehicle today and do some spraying. I’ll give it a day and report back if it made a Difference. Also, just to note nothing has ever spilled on my console and I’m getting the squeak.
  11. May 21, 2023 at 4:16 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    This is exactly what I did today. There is also a linkage on the drivers side for the transmission, that is what I sprayed when I was getting the hard shift. If you haven’t done so already, give that a spray also.
    djwantke[QUOTED][OP] likes this.
  12. May 21, 2023 at 4:56 PM
    @NOS4A2-1 have someone move shifter while spraying drivers side linkage, or not necessary? THANKS
  13. May 21, 2023 at 5:10 PM
    EC15
    EC15 ...
    You can try this...
    Have the NSS rotate WITH the shaft by unplugging it and remove the 12mm bolt before moving the shifter.
    If it no longer squeaks, its the NSS.
    Hope that makes sense.
  14. May 21, 2023 at 6:55 PM
    Hit all the spots now, vac'd debris, wife removed and cleaned plastic console parts
    I'll try NSS removal test
    I'll repeat lubing for couple days
    :burp:
    NOS4A2-1 and Captain Spalding like this.
  15. May 21, 2023 at 7:19 PM
    Your wife cleaned that filthy mess!? She’s a keeper.
    djwantke[OP] and NOS4A2-1 like this.
  16. May 21, 2023 at 9:33 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    I don’t think it’s necessary.
    Edit: Sorry for late response.
  17. May 21, 2023 at 9:36 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Nice! that’s the spot I was talking about on the drives side.
  18. May 21, 2023 at 10:15 PM
    My wife surprised me today too lol
  19. May 21, 2023 at 10:48 PM
    #49
  20. May 22, 2023 at 12:32 AM
    #50
    It’s hard to pinpoint the location of the sound from the video. Maybe a dab of grease at these points?
  21. May 22, 2023 at 7:14 PM
    #51
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    After lubricating the linkage and NSS yesterday, I still have the squeak. I’m pretty certain now it’s coming from the console area. As soon as I have some time I’ll get into the console as suggested @CaptainSpalding
  22. May 22, 2023 at 7:18 PM
    #52
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    What would you suggest, white lithium, silicone, or something else?
    djwantke[OP] likes this.
  23. May 22, 2023 at 8:02 PM
    #53
    It doesn’t really matter. For any applications where a particular specification of grease is not called for I use Super Lube. It’s a clear synthetic food grade all purpose grease. I’ve used it for years on everything from household hardware to firearms. I wouldn’t use it on the drive shafts, but it’s a no brainer for something like this. But like I said, it doesn’t matter. You just want something thick enough that it will stay where you put it.
  24. May 22, 2023 at 9:11 PM
    #54
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Okay, got you. Thanks! I used Super Lube on my firearms years ago, I didn’t know it was still around.
  25. May 22, 2023 at 11:02 PM
    #55
    I like to apply it with a hobby syringe. I buy it in a tube because it’s easier to transfer into the syringe than scooping the goop out of a can.
    I follow the adage “If it slides, grease it. If it pivots, oil it.”
    NOS4A2-1 likes this.
  26. May 23, 2023 at 9:55 AM
    #56
    I also need to try what I believe EC15 said, disconnect NSS out of the mix and check for squeak
  27. May 23, 2023 at 11:29 AM
    #57
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    My 16 does the same. Sounds like it's coming from the console. Have used penetrating lube to some reduction.
  28. May 23, 2023 at 1:07 PM
    #58
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    I will remember that one!
  29. May 23, 2023 at 1:09 PM
    #59
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    have you Lubed inside the console at all yet?
  30. May 23, 2023 at 1:11 PM
    #60
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    well, that’s a little encouraging, thanks.
