What else do you drive or ride?
Discussion in 'General Automotive' started by LMR, Apr 24, 2014.
  1. Mar 1, 2025 at 11:40 AM
    #1081
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Trying to sell my 2014 Dyna Super Glide custom. 5500 miles on it.
  2. Mar 5, 2025 at 5:51 PM
    #1082
  3. Mar 5, 2025 at 6:13 PM
    #1083
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    the ford and the 4runner.
    the 4r doesn’t even have a burnt out light bulb yet.
    meanwhile the ford’s fell apart a bit and the heater started not working this week :laugh:
  4. Mar 5, 2025 at 6:18 PM
    #1084
    vthoky New Member
    Most of last week?
    One of these:
    (Not my pic.)
    Thacrow likes this.
  5. Mar 5, 2025 at 6:25 PM
    #1085
    I wish I’ve learned how to drive fork lifts.
    Every time I see TOYOTA forklift I wanna get in
  6. Mar 5, 2025 at 7:48 PM
    #1086
    Inyo Runner
    Inyo Runner New Member
    2024 trd off road premium
    IMG_0576.jpgMy 2004 TJL built by AEV in Montana
    Nhmountainman likes this.
  7. Mar 6, 2025 at 2:24 AM
    #1087
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Sold all my motorcycles a few years ago, but just couldn't stay away.
    Picked up this basically mint 2008 Yamaha FZ1 with just 7500 miles on it.
    4scooter19, LCJ77 and vthoky like this.
  8. Mar 6, 2025 at 7:27 AM
    #1088
    Blackshirt
    Blackshirt New Member
    ‘24 SR5 Premium 4WD
    We have a total of four four-wheelers, three Toyotas and a Honda. I also have five motorcycles…a BMW, two Guzzis, a Honda, and an old Meriden Triumph. We also have a ‘63 VW Ragtop in the process of restoration.
    Pentangler and vthoky like this.
  9. Mar 6, 2025 at 9:51 AM
    #1089
    Accelerator
    Accelerator New Member
    Chris
    Satellite Beach, Fla
    2022 SR5 Super White 4Runner #3
    This one right here.
    4scooter19, Pentangler and Blackshirt like this.
  10. Mar 6, 2025 at 11:14 AM
    #1090
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
  11. Mar 6, 2025 at 2:16 PM
    #1091
  12. Mar 7, 2025 at 5:49 PM
    #1092
    Changed the oil and filter on the Corolla today. Next oil change 228,000, runs like brand new. No valve chatter or knocking at all. Ive always changed it at 10,000 mile intervals.
    Mobile 1
  13. Mar 14, 2025 at 6:42 PM
    #1093
    TRD_Sport_Green
    TRD_Sport_Green New Member
    2022 TRD Sport
    4RUNNER, IMPALA & SUPRA
    4scooter19 likes this.
  14. Mar 15, 2025 at 9:03 AM
    #1094
    TRD_Sport_Green
    2022 TRD Sport
    Damn dude, this is bad ass. Im after a 56 Convertible myself, love the Nomad.
  15. Mar 15, 2025 at 8:24 PM
    #1095
    vthoky New Member
    Sweet! I've always loved the Nomad, though my preferred model is the '55. :cool:
  16. Mar 16, 2025 at 5:31 PM
    #1096
    leftyfire
    leftyfire New Member
    Michael
    2006 Limited V6
    Pierce is the only way to go...or maybe a Seagrave
  17. Mar 23, 2025 at 10:46 AM
    #1097
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Just had ankle surgery so im riding this scooter around temporarily for a little bit. It of course needed rock lights.
    Trying to figure out how to get some raptor lights (also known as @Borracho Loco Lights) on this thing since everyone here likes em and I understand they're pretty mandatory if you own a 4runner.
  18. Mar 23, 2025 at 10:59 AM
    #1098
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
  19. Mar 23, 2025 at 11:00 AM
    #1099
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
  20. Mar 23, 2025 at 11:13 AM
    #1100
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Yes had 1984 VF700F, 2001 CBR929RR & 2004 CBR954RR.I like the way the hold the road, like on rails. The front of the HD @65+ feels way to loose to me & in corners worry about catching peg mounts to hide side. did it once turning onto my neighborhood street, Never leaned like that again. Sitting up right W/wind takes toll on my back too.
  21. Mar 23, 2025 at 11:26 AM
    #1101
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Interesting. Theyre such different bikes. Its like a jeep wrangler vs a Lamborghini. First time riding my Harley and also my super tenere 1200 I scraped pegs. I scraped pegs a lot of the tenere before I learned to ride it like it wasnt a GSXR.
    Ive met people who ride Harleys and start comparing them to street bikes and im just like, hey since you've never ridden a sport bike....its not comparable. Its a different universe.which is why I asked.
    Sounds like you need two bikes.
    I was asking because most of my miles on sport bikes was a 750. Just got rid of my liter bike. 2022 GSXR1000R. It just had so much power that it was less fun. You always need to meter how much throttle. Whereas the 750 i could full throttle a lot more which was more fun. The 750 felt a little more agile and light and could flick the bike around a lot faster as I danced around in traffic splitting lanes.
    And then insurance is a little less on the 750.
    Just saying if I got another sport bike it would be a 750.
    I would ride like a fairly crazy person and to me the only difference is the 750 would start slowing down at 135mph and then get really slow at 150 while the 1000 would start slowing down at 160. I mean acceleration would be less. And at that point, may as well ride a 750.
    The 750 or 1000 I would cruise at 110mph which feels like 65mph on my Harley. Its just a different universe. Total different sport.
  22. Mar 28, 2025 at 8:08 AM
    #1102
  23. Apr 2, 2025 at 1:37 PM
    #1103
    Check out my mom's. Hottie?IMG_1388.jpg She needs a boyfriend?
  24. Apr 4, 2025 at 11:23 AM
    #1104
  25. Apr 4, 2025 at 11:32 AM
    #1105
    Just paid a year of full coverage insurance. Its not that bad. On 5 tags.
