What else do you drive or ride?
Discussion in 'General Automotive' started by LMR, Apr 24, 2014.
  1. Nov 11, 2024 at 4:36 PM
    #1051
    Corolla S passed inspection car in front of me failed for non oem led headlights. I think its melting the housing.
  2. Nov 12, 2024 at 1:50 PM
    #1052
  3. Nov 13, 2024 at 10:08 AM
    #1053
    "Rollen' in my 5.0', Need new t-tops seals so my hair will flo'
  4. Nov 13, 2024 at 10:52 AM
    #1054
  5. Nov 13, 2024 at 10:54 AM
    #1055
    Best $800.00 I ever spent.
  6. Nov 13, 2024 at 11:09 AM
    #1056
  7. Nov 13, 2024 at 1:17 PM
    #1057
    I can go anywhere 250 miles from home.
  8. Nov 13, 2024 at 8:25 PM
    #1058
    Just scored a new helmet. Its the AGV k3 "Dreamtime" Ive wanted this helmet for awhile and it IMG_1023.jpg has a tinted windscreen for $170.
    cuse93 likes this.
  9. Nov 17, 2024 at 1:08 PM
    #1059
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    ^ this, now.
    2ndGen22re likes this.
  10. Nov 18, 2024 at 12:36 PM
    #1060
    Got the new lid.IMG_1030.jpgI already have a Pista and Corsair, so this is a little different fits well like brand new.
  11. Nov 18, 2024 at 12:41 PM
    #1061
    IMG_1032.jpg And I installed my tintedIMG_1033.jpg windscreen.
  12. Nov 18, 2024 at 1:13 PM
    #1062
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    My new 2024 Honda Pioneer 1000-5 in Black Forest Green is pretty much identical to our Army Green 4R.
  13. Nov 18, 2024 at 1:41 PM
    #1063
    I put the clear visor on it, it has a drop down sunshield. I did not know it had it. Very kewl.
  14. Nov 18, 2024 at 4:48 PM
    #1064
    IMG_1035.jpgThis is a 2015 model.
  15. Nov 19, 2024 at 8:54 AM
    #1065
    International Race Of Champions.
  16. Nov 26, 2024 at 11:00 AM
    #1066
    IMG_1042.jpg A guys brand new ZX14 got submerged in his house. So IMG_1043.jpg and he forgot to set a reserve.
  17. Nov 26, 2024 at 3:40 PM
    #1067
    The Cardo links with your cell phone and you dont have to touch it,IMG_1044.jpg its voice command. And it has upgraded speakers installed by a tech. Plus has a gold faceshield.
  18. Nov 26, 2024 at 5:16 PM
    #1068
    64mech
    64mech New Member
    2017 Toyota Tundra Crewmax 4x4. Bought it new. I believe it’s the only Toyota that gets worse MPG than the 4R.
  19. Nov 27, 2024 at 1:42 PM
    #1069
    Now he has not mailed it. Not my fault there was no reserve?
  20. Nov 27, 2024 at 1:42 PM
    #1070
  21. Dec 5, 2024 at 3:24 PM
    #1071
    This Cardo sounds bada$$!
  22. Dec 5, 2024 at 5:12 PM
    #1072
    This has turned into the weirdest thread ever.
    4scooter19, jiveydude and Daddykool like this.
  23. Dec 8, 2024 at 10:10 AM
    #1073
    IMG_1072.jpg Im gonna rock this new helmet in the sandrail without the windshield.
  24. Dec 8, 2024 at 2:42 PM
    #1074
    got new to me black wheels and larger tires on the wife’s Jeep we bought as a cheap local commuter.
    I think it looks much better. Could use a little spacer lift LOL
  25. Dec 8, 2024 at 4:42 PM
    #1075
    Nice, glad to hear it still runs.
  26. Dec 8, 2024 at 8:47 PM
    #1076
    NeverTooLate71
    NeverTooLate71 New Member
    Bob
    2024 4Runner SR5
    Wife has a 2018 Tesla Model 3. I get go back it out of the garage the mornings she goes to work.
    My other vehicle is a 2016 Winnebago Minnie Winnie 22R
    We have (2) bikes but I am looking at at Solar Eclipse Ebike, neighbor has one. Impressive!
  27. Jan 26, 2025 at 4:50 PM
    #1077
  28. Feb 10, 2025 at 3:38 PM
    #1078
    Hetzer
    Hetzer New Member
    Alex
    2021 Audi A5, 2007 Porsche Boxster 987 245hp.
    I also have a 2016 Sprinter van, and I'm looking for information on how to build folding van bed frame. Once I finish updating the interior and making some small modifications, I’ll definitely head out on a trip in it.
  29. Feb 17, 2025 at 7:55 AM
    #1079
    Camaro Won the Daytona 500!
  30. Mar 1, 2025 at 10:32 AM
    #1080
