What else do you drive or ride?
Discussion in 'General Automotive' started by LMR, Apr 24, 2014.
  1. Jun 27, 2024 at 9:35 PM
    #931
    I'ld like to take a moment, and thank, Florida and Wellcraft, for building the 160CCF.
  2. Jun 28, 2024 at 5:12 AM
    #932
    Irving Zisman
    Irving Zisman New Member
    Vegas
    2008 V8 4Runner
    2 of my other rides. 2022 Africa Twin and 2012 KLR650.
    kolter45 and DenverMoto like this.
  3. Jul 1, 2024 at 5:49 PM
    #933
    JckDanls07
    JckDanls07 We May Not Know Them All, BUT, We Owe Them All
    2003 4runner Limited V6
    Since somebody posted some tractors... Here's mine... I built this myself...
    And this is what it puts out...
  4. Jul 1, 2024 at 5:54 PM
    #934
    JckDanls07
    But in all seriousness... 73 Stingray... All original... all numbers match...
  5. Jul 2, 2024 at 12:01 AM
    #935
    Man I wish I had changed the timing belt on the Deawoo Lanus before it locked the engine up at 60k miles.
  6. Jul 2, 2024 at 12:54 AM
    #936
    TRD PANTHER
    TRD PANTHER New Member
    Southern California
    2018 Black TRD Pro
    My other car is a Challenger widebody Scat Pack Shaker. I’ve never cared about gas mileage since my first car, a Boss 429 Mustang 50 years ago.
  7. Jul 3, 2024 at 2:08 PM
    #937
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Wife and I just bought a Jeep Patriot High Altitude to give the 4R a rest from being the family daily.
    $15kCAD
    2016 85,000 kms
    2.4L DOHC 16V I-4 w/Dual VVT
    4WD, leather, sunroof, heated seats, premium speakers, black and chrome trim + exhaust tip, allow wheels, clean carfax and inspection.
    Maximumdarkside likes this.
  8. Jul 3, 2024 at 2:20 PM
    #938
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    Congrats on the purchase. Does it have the flip down speakers in the rear hatch?
    djwantke likes this.
  9. Jul 3, 2024 at 2:53 PM
    #939
    I wish, no it does not.
    There’s no speakers on the hatch, so take Premium Audio with a grain of salt :laugh:
  10. Jul 3, 2024 at 3:01 PM
    #940
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    No, no, be glad it doesn't have the drop down speakers. *laughs* I had them in my 2017 patriot and the latch very quickly wore out and they wouldn't stay up at all. I thought I'd had it fixed one time...it worked loose again and I got busted in the head with those speakers. Thankfully my Wife's Patriot didn't have them. I don't think I could've dealt with the problem across two vehicles.
    djwantke[QUOTED] likes this.
  11. Jul 3, 2024 at 3:11 PM
    #941
    Ahh I see, that’s pretty funny, wasn’t funny for you at the time haha
    How reliable were your Patriots
  12. Jul 3, 2024 at 3:28 PM
    #942
    kolter45
    Denver
    Inferno Pro & BRM Sport
    When my brother lets me drive his 92 GTS4...
  13. Jul 3, 2024 at 3:36 PM
    #943
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    Not very, sadly. My Wife's 2012 had some CVT issues, which thankfully got fixed and it wasn't a problem again, but, its was always very herky-jerky and never felt right. So, we primarily used my 2017 that had a regular transmission in it that was a lot smoother and it didn't feel like it chugging and wanting to die, but, for some reason it chewed through coils and spark plugs like they were candy. Plus, my bumper just randomly came loose and was about to fall off for some reason. Add in the problems with the speakers in mine and yeah....I really didn't like them much. *laughs*
    I wish I had better things to tell you, and I'm happy for your purchase, man...I wish you the best of luck with your Patriot and I hope you have a better experience with yours than we did with ours. I will give them a thumbs up on being dirt cheap and great on gas at least, I can definitely commend them on that.
  14. Jul 3, 2024 at 4:28 PM
    #944
    GrantM64
    GrantM64 New Member
    Nice. A friend of my had a 1970 plumb crazy 340 cuda back in the early 80's and I had a 1970 340 Duster. Good ole days.
    TRD PANTHER[QUOTED] and RusPro17 like this.
  15. Jul 3, 2024 at 4:36 PM
    #945
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    IMG_20181116_145402438.jpg Our Albino Rhino….
  16. Jul 3, 2024 at 4:50 PM
    #946
    legend1011
    legend1011 New Member
    Not to make you paranoid, but plan any preventative maintenance that may help the life of the transmission. My brother had a 2012 Patriot hat he had to part ways with around 110,000 miles because of transmission issues. I was with him on one of the rides and the car went into "Limp Mode" and we couldn't get it to go past 10-15 mph until it cooled down. Since yours is a newer 2016, I'm hopeful that there were some positive changes from the 2012 until then. If not, just plan for extra maintenance that could help/extend the life of our transmission. Good luck with the nice ride.
    Reldn likes this.
  17. Jul 3, 2024 at 4:53 PM
    #947
    legend1011
    I've gotten by just fine the last 10 years with my setup: 2001 QX4 SUV and 1991 Honda Civic. Both cars are now well over 210,000 miles - we bought the 5th gen to replace the QX4 and I will be looking to replace the 91 Civic. I paid about 8,000 for both cars and got 10 years out of them. Now with the 4Runner near 50,000 and adding another car, this is hopefully the last of my new car purchases for another 10-15 years.
    Still looking, but not sure if I'm going to go new/use Honda Civic or Corolla. This market almost makes buying new the way to go.
  18. Jul 3, 2024 at 5:15 PM
    #948
    Thanks for all the feedback man, I appreciate it. Hopefully 2016+ fare a little better that the 2012 era, it sounds like they do. Nothings perfect at $15k. I don’t want another Kia or Hyundai either
    Reldn[QUOTED] likes this.
  19. Jul 3, 2024 at 5:29 PM
    #949
    NeverTooLate71
    NeverTooLate71 New Member
    Bob
    2024 4Runner SR5
    An Ebike and Tesla Model 3 long range. (When my wife let's me)
  20. Jul 3, 2024 at 5:40 PM
    #950
    doxidad
    doxidad love my 4runner
    Tom
    NE Ohio
    2024 TRD ORP Ice Cap w/KDSS
    Not sure if this counts. This is my other ride - about 2-3 times a week. Not an engineer but a trainman. Diesel-Electric ~1600HP20230601_090554.jpg
    Bagman, TRD PANTHER, djwantke and 3 others like this.
  21. Jul 3, 2024 at 7:25 PM
    #951
    Rupp1
    Rupp1 New Member
    NC
    2017 SR5 Premium RWD Starlight Black
    In the game of musical cars, I rarely get to park them together. My 2015 Tacoma DC Off Road. Hidden winch, ARB on board air, etc.
  22. Jul 3, 2024 at 7:38 PM
    #952
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    No problem! You should be better off with the later model year as aside from my issues with the coils and spark plugs, the worst parts of the 2017 was mostly fit and finish related. No transmission issues or anything like the 2012.
    *laughs*My other issue with that 2017 is that I never really wanted it after the issues my Wife went through with her 2012. I had been set on a Silver '08 or '09 FJ Cruiser that was sitting at the dealership. First time ever seeing an FJ and I knew right away I wanted one...Yeah, she talked out of buying it and buying the much cheaper Jeep.
  23. Jul 3, 2024 at 8:50 PM
    #953
    NeverTooLate71
    Bob
    2024 4Runner SR5
    We recently took a 150 mile train trip in Mexico from the Copper Canyon. Many tunnels, beautiful scenery. I wish it had been 1,000 miles!
    doxidad[QUOTED] likes this.
  24. Jul 4, 2024 at 12:20 AM
    #954
    TRD PANTHER
    Southern California
    2018 Black TRD Pro
    Here is my Boss 9 with the original L.A.Times ad. Purchased for $2500 in ‘74 at 17. The other picture is a year and a half later with tunnel ram, headers, a big Crane cam and slicks. I learned a lot because of that car. Those were the days. Great cars, music and girls.
  25. Jul 12, 2024 at 9:49 PM
    #955
    I wish I was 17 in ‘74!
    TRD PANTHER[QUOTED] likes this.
  26. Jul 12, 2024 at 9:55 PM
    #956
    Bought and installed two matching premium car seats in the new to me Jeep Patriot. Mom has made the thing hers now, including pink interior accents ordered :rolleyes:
    This one sure is cleaned up nice with black interior trim & leather, and simple big knobs. Got fogs too.
    Just needs tires. And a little spacer lift :p
    NeverTooLate71 and Reldn like this.
  27. Jul 13, 2024 at 2:46 AM
    #957
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    It's my second ride, but only when the weather is nice and not that often.
    2009 XR1200
    Bagman and SR5 Limited like this.
  28. Jul 13, 2024 at 2:50 AM
    #958
    TRD PANTHER
    Southern California
    2018 Black TRD Pro
    If I had a Time Machine…:)Great times.
  29. Jul 13, 2024 at 2:54 AM
    #959
    TRD PANTHER
    Southern California
    2018 Black TRD Pro
    Interesting that you went with a Jeep SUV as a 4Runner owner. Did this fit the bill from a financial and practicality basis for your needs? Be interesting to see how the reliability and quality pan out.
  30. Jul 13, 2024 at 7:29 AM
    #960
    I rode the Honda 300EX. Its a beast but yet light enough you can pick it up. Has a "jockey" shift reverse. And its bored out 30cc's.
