What else do you drive or ride?
Discussion in 'General Automotive' started by LMR, Apr 24, 2014.
  1. May 16, 2024 at 6:16 PM
    #901
  2. May 19, 2024 at 12:39 PM
    #902
    I should of bought that used repoed Ferrari for $65k from the marina.
  3. May 21, 2024 at 11:52 AM
    #903
    My Briggs and Stratton engine in my Ariens lawnmower was Made in the USA, and going strong!
  4. May 21, 2024 at 12:05 PM
    #904
    Wait, its "assembled" in USA. Thats close enough?
  5. May 21, 2024 at 12:34 PM
    #905
    2006 Pontiac GTO 6 speed.
  6. May 21, 2024 at 4:01 PM
    #906
    My neighbor has one of these in RED. And when I say RED, Its RED!
  7. May 21, 2024 at 4:54 PM
    #907
    Sounds like Torrid red.
    SR5 Limited[QUOTED] likes this.
  8. May 21, 2024 at 6:03 PM
    #908
    When I see it, I go all gorilla and want to attack it.
    Its freakin bright!
  9. May 27, 2024 at 5:10 AM
    #909
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Added a new toy to the garage this week!
    2ndGen22re likes this.
  10. Jun 2, 2024 at 12:45 PM
    #910
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    New work van dealer dropped at my house.
    Outfitted w/ proper locking roof rack, black steel cage, Sterling shelving, and power inverter behind passenger seat.
    :woot:
    SR5 Limited likes this.
  11. Jun 2, 2024 at 5:20 PM
    #911
    Splice truck?
  12. Jun 2, 2024 at 5:55 PM
    #912
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Finally got her back!
    Trouble24 and SR5 Limited like this.
  13. Jun 2, 2024 at 5:55 PM
    #913
    Valmet
    Valmet Some Might Say.
    Richmond, Virginia
    2016 Trail
    I don’t. Just my 4Runner- 2016 SR5 Trail…
    djwantke likes this.
  14. Jun 6, 2024 at 6:49 PM
    #914
    Trouble24 likes this.
  15. Jun 6, 2024 at 9:07 PM
    #915
    Trouble24
    Trouble24 New Member
    Steph
    Leavenworth, WA
    2024 4Runner TRD Pro
    Ceramic Tint Prinsu Pro Roof Rack 3” Westcott lift ARB Awning
    I bought the Honda new in '86 when I was 15 yrs old.
    2ndGen22re and SR5 Limited like this.
  16. Jun 7, 2024 at 5:48 PM
    #916
    "Ride or Die"!
  17. Jun 8, 2024 at 9:02 PM
    #917
    IMG_0368.jpgThat's $5k!
  18. Jun 19, 2024 at 12:36 PM
    #918
  19. Jun 19, 2024 at 1:06 PM
    #919
  20. Jun 19, 2024 at 2:09 PM
    #920
    DenverMoto
    DenverMoto New Member
    2010 T4R Trail
    I like them Japanese built :dancingbacon:
  21. Jun 19, 2024 at 2:36 PM
    #921
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    I swap DD'ing both of these:
    DenverMoto likes this.
  22. Jun 19, 2024 at 2:53 PM
    #922
    I actually prefer Canada. You know the parts for those Japanese cars come from all over. The Philippines, all over. So it may be built there, but, they have more important things to figure out.
  23. Jun 20, 2024 at 6:20 PM
    #923
  24. Jun 21, 2024 at 9:35 AM
    #924
    IMG_0412.jpgIm about to renew my tags for 2 years. It will be the last time, ever. Then going antique.
  25. Jun 21, 2024 at 9:47 AM
    #925
    I just called the county because the Suzuki was not on my tax bill? They said it was not worth anything so no more taxes? Its insured for $7,500., I might raise it to $10k! The Full-Titanium exhaust was $3,800. These Lithium Fire-Power featherlight batteries are awesome. I think Im on my 3rd or 4th year on this one.
  26. Jun 22, 2024 at 7:22 PM
    #926
    IMG_0419.jpgAll it needs is Gas!
    BestGen likes this.
  27. Jun 23, 2024 at 12:40 PM
    #927
    I'ld like to take a moment, and thank, California and General Motors, for building the 3rd Gen Camaro.
    Maximumdarkside likes this.
  28. Jun 24, 2024 at 11:13 AM
    #928
    I'ld like to take a moment, and thank, Ford, for changing to IMG_0420.jpg Fuel Injection in 1985.
  29. Jun 26, 2024 at 10:21 AM
    #929
  30. Jun 26, 2024 at 5:38 PM
    #930
    Anyone want to lend me $7k for this rebuilt 1959 Sportster with a chopped and OEM frame?
