What else do you drive or ride?
Discussion in 'General Automotive' started by LMR, Apr 24, 2014.
  1. Jan 4, 2024 at 10:47 AM
    #811
  2. Jan 17, 2024 at 1:56 PM
    #812
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    New work van came with the new salary.
    There's a little Transit Connect under there.
    Photon_Chaser and LCJ77 like this.
  3. Jan 17, 2024 at 8:26 PM
    #813
  4. Jan 17, 2024 at 8:33 PM
    #814
    Reddawg1100
    Reddawg1100 New Member
    2014 Limited MGM
  5. Jan 17, 2024 at 8:42 PM
    #815
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  6. Jan 17, 2024 at 9:02 PM
    #816
    What a spread
    Rob41[QUOTED] and gomiami like this.
  7. Jan 17, 2024 at 9:23 PM
    #817
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Thanks. All the "stuff" is meaningless. I'm just thankful to have land and live in a good place.
    gomiami likes this.
  8. Jan 17, 2024 at 9:28 PM
    #818
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    I traded a 5k sq ft house on the water for a modest ranch on 40 acres with three barns and it's the best thing I ever did.
  9. Jan 19, 2024 at 9:04 AM
    #819
  10. Jan 23, 2024 at 4:31 PM
    #820
    Ford Tough!
  11. Jan 23, 2024 at 5:24 PM
    #821
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Nothing fancy, just a 2016 Jeep GC, and 2012 Ram 2500. 4Runner has replaced our GC as a daily driver now. Thinking of trading my GC for a Dodge Challenger. Also, I am in the market for a TJ Wrangler.
    2ndGen22re likes this.
  12. Jan 26, 2024 at 4:48 PM
    #822
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Rough terrain BBQ….my favorite to drive. Requires beer to keep it running….
    Best hotdog you’ve ever had in a moldy bun…..Dodge/Cummins.
    Reddawg1100 and Photon_Chaser like this.
  13. Jan 26, 2024 at 6:06 PM
    #823
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Sold this a few months ago...
    Have a deposit down on this, waiting for it to come over on a slow boat from Italy...
  14. Jan 27, 2024 at 9:53 AM
    #824
    2ndGen22re
    CR
    Carson Valley, NV
    That MG is so cool.
    Bummer, I promised the wife I would quit the street riding when I retired if I wanted off road toys.
  15. Jan 27, 2024 at 11:49 AM
    #825
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    For now a 2014 HD Dyna Super Glide Custom, but that's up for sale & if it doesn't go I'll take the loss on trading for 2023 Honda CBR1000RR. Just can't get into that style riding sitting so upright & not fun is the twisties.
  16. Jan 27, 2024 at 11:57 AM
    #826
    Captain Sensible
    Captain Sensible New Member
    Sold the Duc, kept the dog. Since weed became legal the amount of distracted (stoned) drivers is frightening. I no longer ride the streets. I still have my minibike and my racebike. Because the track is safe.
  17. Jan 27, 2024 at 12:23 PM
    #827
    bronzestar1
    My Aprilia looks like your Duc. Interesting bike to ride, not quite a sportbike, not quite a dual-sport, something weird in-between!
    Maximumdarkside likes this.
  18. Feb 29, 2024 at 6:40 PM
    #828
  19. Feb 29, 2024 at 7:32 PM
    #829
    kenwrob
    kenwrob New Member
    Ken
    2000 Lmtd Elckr 2nd gen SC + 2024 ORP
    TRD Supercharger
  20. Mar 1, 2024 at 9:33 AM
    #830
    bronzestar1
    Need to work on getting this back on the road. It's blowing blue smoke and has a strong fuel smell. I'll have to start with the simple things, like a blown fuse for a fuel-related component, and go from there. Hoping it's not rings or valve stem seals, it just happened all of a sudden.
    gomiami likes this.
  21. Mar 25, 2024 at 8:31 AM
    #831
    IMG_9912.jpg IMG_9913.jpgStarted on the first crank! Second year of fuel injection.
    Maximumdarkside, 2ndGen22re and Reldn like this.
  22. Mar 25, 2024 at 8:47 AM
    #832
    2ndGen22re
    CR
    Carson Valley, NV
    Cherry 2004.5 Cummins Laramie Sport(pre DEF!) with a bunch of DynaTrac $tuff and built transmission.
  23. Mar 25, 2024 at 8:57 AM
    #833
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2024 Polaris Sportsman 570EFI Ultimate Trails W/EPS.
  24. Mar 25, 2024 at 9:21 AM
    #834
    BMerrill33
    BMerrill33 Someone once said ??? Something...
    Wyoming
    2020 T4R SR5P
    '95 3.0 Toyota Pickup. Picked up a couple years ago and quickly became my daily!
  25. Mar 25, 2024 at 9:40 AM
    #835
    broken-giver
    broken-giver BFD
    My "other" boat is a Hobie :p
    hossler1788 and BMerrill33 like this.
  26. Mar 27, 2024 at 8:34 PM
    #836
    bronzestar1
    Should be getting this delivered next week, it's a 2005 Audi A4 3.0 (V6) Quattro convertible. Already have a new set of wheels and tires on the way, and plan on doing a rear muffler delete with new stainless tips. An S4 (4.2 V8) with a manual trans was on the list, but issues I've read about the V8 made me pass on it. This will be the Sunday driver when it's sunny out, cars and coffee car, so not a daily, but a garage queen.
  27. Mar 27, 2024 at 8:38 PM
    #837
    EmmanuelMV
    EmmanuelMV New Member
    Emmanuel
    21 White ORP
    Black TRD wheels.
    Just picked up this bad boy
    Maximumdarkside and jeepster09 like this.
  28. Mar 28, 2024 at 6:57 AM
    #838
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
  29. Apr 6, 2024 at 10:44 PM
    #839
    maximum
    maximum New Member
  30. Apr 7, 2024 at 3:49 AM
    #840
    Texas-Gorilla
    Texas-Gorilla New Member
    2015 Toyota 4Runner SR5
    IMG_3025.jpg 2001 Tacoma PreRunner Xtracab Stepside
    2008 Jeep Wrangler JK
    2010 Triumph Speed Triple
    2015 Toyota 4Runner
    2020 Kia Telluride
    The Triumph is my favorite. I had a 2006 Triumph Speed Triple but recently replaced it with the 2010 special anniversary model.
