What else do you drive or ride?
Discussion in 'General Automotive' started by LMR, Apr 24, 2014.
  1. Aug 26, 2023 at 5:23 PM
    #721
    2023_lunarrock-ORP
    2023_lunarrock-ORP Pistolero
    Brandon
    Pacific Northwest
    2023 lunar rock orp
    EM-1 si?
  2. Aug 26, 2023 at 5:33 PM
    #722
    2023_lunarrock-ORP
    Brandon
    Pacific Northwest
    2023 lunar rock orp
    I’ve had two in electron blue pearl. Love that car!
    gomiami likes this.
  3. Aug 26, 2023 at 5:39 PM
    #723
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    My screen name was because of my EBP EM1.
    Avatar however isn’t an EM1
    2023_lunarrock-ORP and gomiami like this.
  4. Aug 26, 2023 at 5:43 PM
    #724
    2023_lunarrock-ORP
    Brandon
    Pacific Northwest
    2023 lunar rock orp
    Hey Washington plates who was snapping pictures of my old car lol!
    gomiami likes this.
  5. Aug 26, 2023 at 5:59 PM
    #725
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    2017 Ford Transit 250, stainless racking by Sterling
    I hate Ford's for good reason, but love free company gas & insurance
  6. Aug 26, 2023 at 6:00 PM
    #726
    Corolla came with LED headlights starting in 2014, everyday I see a vehicle with a burnt out light. I got emissions and inspection coming up.
  7. Aug 26, 2023 at 6:05 PM
    #727
    I met a kid with a torn up 1988 KX 80 at the gas station. It is awesome. Then he followed me home so I gave him a pair of kicker 6x9’s and a 12 inch kicker sub. Then his engine locked up.:)
    gomiami likes this.
  8. Aug 26, 2023 at 6:15 PM
    #728
    I heard when you change an LED light out on a Ford, you have to reprogram the computer?
  9. Aug 26, 2023 at 6:22 PM
    #729
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    Saved
    Yes, Technically my avatar was from a Vivid Blue EP3
  10. Aug 26, 2023 at 7:54 PM
    #730
    Captain Sensible
    Captain Sensible New Member
    Believe it or not, this street legal 50cc YSR will do 3rd gear wheelies and bury the speedo with my fat ass on it.
  11. Aug 26, 2023 at 8:11 PM
    #731
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    2011 Wide Glide which is currently getting a face lift.
    2012 Tenere 1200
    2021 GSXR1000R
    BMerrill33, gomiami and SR5 Limited like this.
  12. Aug 26, 2023 at 8:30 PM
    #732
    “BFF” suspension? Best friends forever!
  13. Sep 20, 2023 at 6:22 AM
    #733
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Just picked up a '23 Tundra Platinum with the I-Force Max engine.
    4scooter19, SR5 Limited and siblue like this.
  14. Sep 20, 2023 at 7:31 AM
    #734
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    Congrats. My non hybrid is a year old today without any issues that the internet states.
    PVT Pablo[QUOTED] likes this.
  15. Sep 20, 2023 at 4:44 PM
    #735
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Thats good to hear! Popped over to the Tundras forum and was actually pretty surprised to see as much 3rd gen hate as I did.
  16. Sep 20, 2023 at 4:57 PM
    #736
    I know you didn’t trade in your 4R for that? Second vehicle?
  17. Sep 20, 2023 at 5:01 PM
    #737
    Rupp1
    Rupp1 New Member
    NC
    2017 SR5 Premium RWD Starlight Black
    2015 hidden winch, ARB onboard air, etc.
    Pentangler, djwantke and Thacrow like this.
  18. Sep 20, 2023 at 5:10 PM
    #738
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    Same hate that the 3rd Gen Tacoma did but 10x amplified.
    You’ll see that shit here when the next 4Runner comes out.
  19. Sep 21, 2023 at 1:55 PM
    #739
    Rupp1
    Rupp1 New Member
    NC
    Thanks. Kinda have to be a Canes fan. Brind’Amour and Ward live right down the street…
    gomiami likes this.
  20. Sep 23, 2023 at 7:21 PM
    #740
    I just got a ticket to ride a 611 Steam engine, on the observation deck car. I have this in “O” scale!IMG_9314.jpg
    Mass4runner and engineer90 like this.
  21. Sep 23, 2023 at 7:22 PM
    #741
    Normally I would be sniffing deer asses with bow but I’m taking it easy this year.
  22. Sep 23, 2023 at 7:44 PM
    #742
  23. Sep 26, 2023 at 12:52 PM
    #743
  24. Sep 26, 2023 at 12:55 PM
    #744
    Electric start!
  25. Sep 26, 2023 at 3:12 PM
    #745
    Captain Sensible
    Should be a 2-smoke
    4scooter19 likes this.
  26. Sep 26, 2023 at 3:42 PM
    #746
    I drank a “Monster” energy today and almost recovered from my sat workout.
  27. Oct 10, 2023 at 6:46 AM
    #747
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    Picked this up last night. 09 WRX wagon. Pretty much stock minus STI tranny, short throw shifter and a mishimoto radiator. The mods will start soon!
  28. Oct 10, 2023 at 12:03 PM
    #748
  29. Oct 11, 2023 at 6:54 PM
    #749
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    engineer90, rickystl and SR5 Limited like this.
  30. Oct 11, 2023 at 6:59 PM
    #750
    That’s a well done “flake” floor. I’ve installed a few. We grind then my boss would order boxes and boxes of the “flake”. Just keep throwing it and then vacuum before the polyaspartic clear sealer!
