What do you have still waiting to be installed?
Discussion in '5th Gen 4Runners (2010-2024)' started by 5six, Mar 5, 2023.
  1. Aug 15, 2023 at 9:17 PM
    #151
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Been dying to get my Sherpa Crestone rack installed, been sitting in my garage for probably 6 months now…meh.
  2. Aug 15, 2023 at 9:18 PM
    #152
    Henry J
    Sacramento Ca
  3. Aug 16, 2023 at 7:41 AM
    #153
    5six
    5six [OP] New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    Next nice day, just do it. I did it myself, using 2 ladders in my driveway. I installed one side rail at a time, not tightening things down till I had all the crossbars loosely installed. Definitely do the rear most cross bar and 2nd from front bar installed first to help provide a little more stability first. Be cautious when tightening the rail feet to the roof, so you don’t overtighten. I got it done in 4 hrs because I had the flat plates on top, and one of the side window panels (still haven’t installed the driver’s side one).
    spyder918[QUOTED] likes this.
  4. Aug 16, 2023 at 7:48 AM
    #154
    5six
    55_4Runner
    2022 Black TRD ORP
    Still to do:
    • DR KDSS front sway bar rings, and relocation mounting plates
    • DR KDSS override KDSS switch
    • Ironman 4x4 UCAs
    New to do:
    • C4 Low Profile high bar front bumper w/Extreme LED light bar, and Warn EVO 10s winch (need to build something in wood to help me install it, as it’s heavy).
  5. Aug 16, 2023 at 8:08 AM
    #155
    Henry J
    Sacramento Ca
    Still to do
    - rear shock skids
    - wire reverse lights for bumper
    - ARK rear mud flap deletes (need to solve issue due to new rear bumper)
    - Rear diff breather
    5six[OP] likes this.
  6. Aug 16, 2023 at 10:14 AM
    #156
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    Fit and finish is on par with the GFC Superlite RTT :thumbsup: More feet room due to the top opening higher and it is wider by 5 inches. Also it's 10 inches shorter and I gained 1 mpg better also. Less noise then the Superlite also
    Dabigono and 5six[OP] like this.
  7. Aug 16, 2023 at 10:22 AM
    #157
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Doglover2003 likes this.
  8. Aug 16, 2023 at 11:29 AM
    #158
    Doglover2003
    '18 ORP w/KDSS
    Thanks! It's the Rigd ultra swing. I got the Tacoma version so I can mount 2 4-gallon rotopax in the back.
    djwantke[QUOTED] likes this.
  9. Aug 16, 2023 at 11:53 AM
    #159
    The only things I install are gas and occasionally oil and filters.
    Gman2530 and RNR4P like this.
  10. Aug 16, 2023 at 12:15 PM
    #160
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Lying in the garage and still to install:
    - Front UCA and LCA
    - Eibach Shocks
    - stock coils
    - wheel well covers
    - MAF sensor
  11. Aug 16, 2023 at 9:15 PM
    #161
    spyder918
    2019 TRD ORP MGM
    Hey thanks for the tips! Yeah I live in a fairly foggy area and worried I won’t finish quick enough should the wet fog come in.
  12. Aug 16, 2023 at 9:19 PM
    #162
    @spyder918 over 6 months wait, that's quite the foggy area
  13. Aug 18, 2023 at 6:10 AM
    #163
    Henry J
    Sacramento Ca
    Dammit
    just got my ARB awning in yesterday so that’s on the list now ‍
  14. Aug 18, 2023 at 10:28 AM
    #164
    @Henry J Nice haha!
    Rear bumper light wiring is a fun time
  15. Aug 18, 2023 at 10:30 AM
    #165
    Henry J
    Sacramento Ca
    Kinda dreading it. I mean at least it’s a kit from Diode, but I don’t wanna run that wire the whole length:(
  16. Aug 18, 2023 at 10:37 AM
    #166
    Ooo diode dynamics, I'm jealy.
    Ya I bought 14awg truck trailer wire. Went from battery so I can turn on at any time (with switch on dash). Crossed engine bay at firewall dropped down followed passenger frame rail
    Henry J likes this.
  17. Aug 18, 2023 at 10:39 AM
    #167
    Henry J
    Sacramento Ca
    I might be able to do it next week, maybe
  18. Aug 18, 2023 at 10:41 AM
    #168
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    Roof basket (going back on for vacation in fall) with traction mats
    Henry J likes this.
  19. Aug 18, 2023 at 4:52 PM
    #169
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Received my ARB diff breather kit and veepeak obd2 scan tool. Diff (and elocker) will probably wait until fall when it cools down a bit more.
    Going to knock off the AVS hood and windows (still on the list) in the morning and try out the veepeak with an app I downloaded on old iPad that can't be upgraded anymore - will see if this last ditch effort will repurpose it or if it goes back to Apple to be recycled
  20. Aug 18, 2023 at 5:19 PM
    #170
    Henry J
    Sacramento Ca
    Are you gonna route the breather to engineer bay or where the jack is at?
  21. Aug 18, 2023 at 5:39 PM
    #171
    FN2187
    FN2187 Stormtrooper
    Earth
    Excellent question - I don't know yet. Jack is one option, I think I've seen fuel filler compartment as a possible option too (both are really close).
    I'm going to do more research and decide after but I'm leaning towards engine bay. I like the idea of keeping it close, and in the interior because it seems much easier than running it all the way up to the engine bay. I do, however, have a C4 engine bay mount that it would attach to nicely but that and the blue sea systems switch (for winch) are also still waiting install. When I install those I want to armor the winch and front camera cables with that plastic loom (or whatever it's called) while I'm in there. Will probably do it all at once.
    Henry J[QUOTED] likes this.
  22. Aug 18, 2023 at 5:45 PM
    #172
    Henry J
    Sacramento Ca
    I’m in analysis paralysis right now with mine, so was curious. Thank you
    djwantke likes this.
  23. Aug 18, 2023 at 6:22 PM
    #173
    FN2187
    FN2187 Stormtrooper
    Earth
    I haven't researched in quite a while since I decided I was going to lift. I knew I shouldn't do it before then or I would be guessing at how much slack to leave. Now that I'm at final height, it's go time so I need to refresh my knowledge.
    From what I remember, there were two things that put me in analysis paralysis. For the engine compartment, I'm threading the hose all the way up front past things that are hot and things that can move. I don't want to melt or break that skinny hose. Also seems like a really long way for it to breathe through a straw. In the jack area, you're now essentially venting into the cabin.
    I've got to do a lot of reading again before I make the final decision.
  24. Sep 5, 2023 at 1:41 PM
    #174
    5six
    55_4Runner
    2022 Black TRD ORP
    Update on recently done, C4 bumper with light bar, and winch. Damn heavy kit for me to do alone, so built a basic wooden frame on top of a $15 furniture moving dolly. Rear chase lights added and wired up.
    Still to do:
    • DRKDSS KDSS manual on/off harness
    • DRKDSS front sway bar lock rings
    • DRKDSS front sway bar relocation mounting plates
    • Ironman 4x4 UCAs
  25. Sep 5, 2023 at 1:43 PM
    #175
    Woo wee ! Nicely done
    Where'd you tie in the chase lights to?
    Thx
  26. Sep 5, 2023 at 1:44 PM
    #176
    5six
    55_4Runner
    2022 Black TRD ORP
    Now that you’ve had this for awhile, how’s it working? Any issues with heat while under driver’s seat? Any parasitic draw even if handset is unplugged?
  27. Sep 5, 2023 at 1:45 PM
    #177
    5six
    55_4Runner
    2022 Black TRD ORP
    I have an 8 panel SwitchPro that I’ve connected it to. Then programmed their panel button to continuously blink when double pressed (on solid for single press, or for full off).
  28. Nov 14, 2023 at 1:29 PM
    #178
    Enfuego_T4RPro
    Enfuego_T4RPro EnFuego_T4RPro
    Boz
    Seal Beach, zca
    '22 T4R Pro Midnight Black
    GTe proformamce cold air intake, performance MAF & fuel sensors, Powerstop performance brake calipers, upgraded race ready carbon rotors and pads, XTROS Potent Booster Controller, Mishimoto Performance oil cooler, Mishimoto trans cooler,
    Waiting to be installed? Hmmm, lets see .................
    Well I got:
    1. modified TJM Carbon Fiber snorkle
    2. Aura Opt7 LED accent kit
    3. Aura Opt 7 LED underglow kit
    4. custom braided brake lines (all way around) from King Racing
    5. various mounts for rotopax's, lift jacks, tube mounts, light bar mounts, etc. But I wont be installing these - these are the "extra" crap I went overboard with
    6. rear window molly panel
    7. ARB Hi-Output mounted dual air compressor, custom made 1.75 slim aluminum air tank, 4 hose kits w/accessories and digital pressure compressor connection (not mounted because I'm leaning towards PowerTank now)
    8. Magellan TRX7 CS Pro Off-Road Navigation kit
    9. 4 3-way touch screen switches (basically rocker switches but they don't rock back and forth, theyre touch screen) to wire ditch light to high-beam trigger, rear backup light bars to back up lights and separate trigger, etc
    10.Recoil fuse block (6 fuse), recoil pos/neg bus bars, 150A primary fuse/circuit breaker for secondary "hot system"
    11. Koyorad Hyper V-Core radiator with
    12. external transmission cooler
    13. Mishimoto (modified) 6 row performance oil cooler w/push kit
    14. MAF and/or upgraded throttle body assembly
    That's whats still in my garage. This is my first time getting my hands dirty, so things are taking a little longer to assemble. I do have one hell of a tool box now tho.
    Item's 10 - 14 are waiting to get installed for when my super charger comes in. Just sayen. LOL.
  29. Apr 1, 2025 at 6:05 PM
    #179
    FN2187
    FN2187 Stormtrooper
    Earth
    Raising another zombie from the grave.
    Not sure what I had on the last list I posted but here are currents:
    1. Still haven't installed diff breather kit
    2. Still haven't installed BSS switch on the C4 engine bay bracket (need to but short jumper cables) for winch
    3. Just got the ROF carrier so need to photo, remove, and sell the SSO hitch mount when I install
    Guess I've knocked some stuff off the list but I bet I have more stuff in the garage since the 4runner hasn't gotten much attention lately. I also have a cracked windshield that needs replacing after the weekend road trip but I won't be doing that meself
  30. Apr 1, 2025 at 6:48 PM
    #180
    Pentangler
    Pentangler Happy Member
    Coyote V8 crate motor....................................................................................Happy April 1st!
