What do you have still waiting to be installed?
Discussion in '5th Gen 4Runners (2010-2024)' started by 5six, Mar 5, 2023.
  1. Mar 19, 2023 at 9:00 AM
    #91
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    careful. it’s mostly phillips head screws for that install.
  2. Mar 19, 2023 at 9:13 AM
    #92
    Don't wait too long, or you risk being labeled as a useless 4Runner parts hoarder. :confused:
  3. Mar 19, 2023 at 9:14 AM
    #93
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Dang, they still won’t know how to wrench after installin em.
  4. Mar 19, 2023 at 9:37 AM
    #94
  5. Mar 19, 2023 at 9:40 AM
    #95
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    All done! Vacation addresses programmed into GPS. Reservations made. (Postponed a month due to us getting COVID followed by wife's stomach flu!). Took off roof basket.
    whippersnapper02 likes this.
  6. Mar 19, 2023 at 9:46 AM
    #96
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    I’ve also wrenched on my own vehicles for over 30+ years. I’m not as physically capable as I used to be but I still wrench when I can. I get lazy most of the times as my 4Runner is my day off/ back up vehicle.
    As I posted before, my KING front coil overs are on back order till July. I’m not installing any of the parts I listed until I have the fronts in hand.
    But, good for you, for letting everyone know that YOU work on your own rig. Someone might be impressed here.
  7. Mar 19, 2023 at 9:51 AM
    #97
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Peeing contest going on?
  8. Mar 19, 2023 at 10:29 AM
    #98
    Just some twisted knickers.
  9. Mar 19, 2023 at 10:42 AM
    #99
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Life's too short!
    Mr Rutherford likes this.
  10. Mar 19, 2023 at 11:44 AM
    #100
    Oh how I wish I could wrench.
  11. Mar 19, 2023 at 11:49 AM
    #101
    Nah I need quality workmanship, not rushed shortcuts just to impress someone. Thanks though.
    Doglover2003, nimby and BearBio like this.
  12. Mar 19, 2023 at 12:36 PM
    #102
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Extra charge for the ego? :dancingbacon::dancingbacon:
    "Best-laid schemes o' mice an' men gang aft a-gley........."Robert Burns
    nimby and Nano909[QUOTED] like this.
  13. Mar 19, 2023 at 12:54 PM
    #103
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Nano909 dude stop blowing up my phone, and stop with the emojis most of all. Instead of parachuting in here. Buddy, just post some of this stuff you're so good at wrenching next time you have sumn to wrench, that's what this page is.
  14. Mar 19, 2023 at 1:02 PM
    #104
    I din cry about anything, I told you to shut up essentially twice. First time I seen you post, all it said was you guys who post long lists can't wrench. You parachuted in
  15. Mar 19, 2023 at 1:04 PM
    #105
    Go back to Facebook or something lol
  16. Mar 19, 2023 at 1:17 PM
    #106
    That part is true
    Nano909 likes this.
  17. Mar 19, 2023 at 1:18 PM
    #107
    andrewtheadventurer
    Relaxxxxxxx
    Nano909 likes this.
  18. Mar 19, 2023 at 1:38 PM
    #108
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    Appreciate the head's up, I didn't even know that was an option. I'm all for people having a dissenting opinion, but when in every thread I see them in, the same poster seems to have nothing better to do than starting arguments or trash talking others to boost their own ego, I can do without reading any more of it.
    Tomorrow I'm having my Hefty Fab front bumper and winch installed. I happily admit that is way beyond my skill level. I'm not mechanically inclined. The following day I'm moving to Mexico, which should be a fun adventure.
  19. Mar 19, 2023 at 2:00 PM
    #109
    You'll find that others who haven't put those members on ignore will quote their posts once in a while, and you'll remember why you did.
    Interesting. That is a big step. Hope everything goes as planned.
    R1200Jedi[QUOTED] likes this.
  20. Mar 19, 2023 at 2:09 PM
    #110
    HotelMedicis
    HotelMedicis No Commercial Interests
    What a thread
  21. Mar 19, 2023 at 2:09 PM
    #111
    R1200Jedi
    2022 4Runner ORP
    I appreciate it! It'll be fun, and it'll complete the trio of the big North America countries for me, since I've lived in the US and Canada already. My goal is to learn some Spanish, and by next year I hope to head up to Alaska and start driving the PanAmerican highway with my pup. For the first time in my life, I'm no longer supporting a family and I just retired, so the time is right to do some adventuring.
    whippersnapper02 and nimby like this.
  22. Mar 19, 2023 at 2:10 PM
    #112
    Sounds like an awesome adventure!
  23. May 11, 2023 at 8:15 PM
    #113
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Shit, the list keeps growing.
    • AVS low pro and window visors (waiting on wash - just turned on exterior water for power washer because not afraid of freezing anymore this year)
    • Anytime front/rear camera, license plate relocation kit when SSO swing away is delivered and installed (not delivered yet)
    • CTH flat black rear valance (when I remove, clean rust, and reinstall rear factory hitch)
    • OVS 180 - still haven't mounted brackets or awning. Need to re-sell gobi brackets for different awning. Thread pending. Want to move Gobi sunroof insert and then make OVS brackets work
    • OEM wiper blade inserts and backups
    • Blue Sea Systems cutoff switch for hardwired winch. Also need to buy armored sheathing for the winch cables
    • Idk, probably more cosmetic crap
    Edit: Forgot the pic
    Dabigono likes this.
  24. May 11, 2023 at 8:48 PM
    #114
    backpacker
    backpacker New Member
    2023 TRD ORP
    OK, I'm putting myself on the hook here. I opened a box from Apex Overland today containing front recovery points. The parts and tools are all laid out like surgical instruments in the operating room.
    I haven't worked on a suspension since 1988, when I put new leaf springs and tie rods on a '76 Nova. Of course that car had 150k miles on it compared to 75 miles my 4R, so the bolts should come out easier. They better, because getting up off the floor too many times isn't as easy 35 years later.
  25. May 11, 2023 at 8:56 PM
    #115
    backpacker
    2023 TRD ORP
    You did it without taking off the skid plate? Other members have reported doing that, I'm really tempted to try it that way, and only remove the skid plate and air dam if I don't have enough room to maneuver. ( I know the details are different with KDSS and the different skid plate, but perhaps not different enough to invalidate the comparison.)
  26. May 13, 2023 at 10:39 PM
    #116
    backpacker
    2023 TRD ORP
    OK, it's done, so my list is cleared for now.
  27. May 29, 2023 at 6:59 PM
    #117
    scottiezilla
    scottiezilla New Member
    I have a good amount to wrap up still but starting with my winch n bumper(hefty full)…question is to anyone who has the Ironman winch…how hard was it to locate a spot to mount the control box?
    I ask cause they have a 25% sale right now for an extension cable
    I’m debating on moving my dual ARB from driver side to behind my grill n use that area for an electrical setup
    meaning my control box could be in the “usual” spot, or I could have some wiggle room with extra cable…
    thoughts?
  28. Jun 27, 2023 at 8:50 AM
    #118
    dgrenier15
    dgrenier15 New Member
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Shrockworks Rock Sliders - need to take the OEM "sliders" off.
  29. Jun 27, 2023 at 9:35 AM
    #119
    backpacker
    2023 TRD ORP
    My driver's side grab handle installation was on deck, but two items jumped the queue: sleeping platform and roof basket. I hope to get the basket done this weekend (paint and assemble), then move on to the platform.
  30. Jun 27, 2023 at 10:56 AM
    #120
    rphillips66
    rphillips66 New Member
    Allen
    Charleston SC/ Gastonia NC
    2017 SR5 Premium
    6 Kicker Speakers a 10' sub and a 700 watt amp. This will be complete on Saturday. Interior LED lights arrive Thursday and will be installed over the weekend.
    Doglover2003 likes this.
