What do you have still waiting to be installed?
Discussion in '5th Gen 4Runners (2010-2024)' started by 5six, Mar 5, 2023.
  1. Mar 7, 2023 at 12:09 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Been looking at gmrs radios for a long time. You got pics? Or rather which radio did you go with.
  2. Mar 7, 2023 at 12:31 PM
    Sure. It’s the Midland MXT575. 50 watts. I’ve seen some nifty installations of the MXT275 in the center cubby, but the 575 is a little bigger and I’d really have to shoehorn it in there and I worry about heat. So here’s the plan:
    • The radio will go under the driver’s seat, mounted on a stand-off so it doesn’t touch the carpet. There’s plenty of room underneath with the seat in any position.
    • The antenna will be mounted at the lower corner of the windshield on the driver's side on a CaliRaised ditch light bracket.
    • Power will be drawn from the wires feeding the 12v outlet in the center cubby using PosiTaps.
    • While the center console is pulled apart I’ll run a cat5 cable from the radio to the area of the switch blank to the right of the steering wheel The switch blank will be replaced by an RJ-45 pass through, where the handset will be plugged in.
  3. Mar 7, 2023 at 1:02 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That's a really good looking radio. I've been using hand held's with my friends. Like peasants. And then we gotta worry about batteries. I'm very jealous.
  4. Mar 7, 2023 at 1:07 PM
    steelevo
    Utah
    I have a bunch of RCI armor that is sitting in the garage waiting for the new 4Runner to arrive.
    5six[OP] likes this.
  5. Mar 7, 2023 at 1:51 PM
    Mr Rutherford
    Mr Rutherford New Member
    Houston, TX
    2019 SR5
    Alpharex Nova G2 Alpha black headlights and DD Elites LED yellow fogs.
  6. Mar 7, 2023 at 4:21 PM
    BimmerChop
    BimmerChop Rich
    CT
    '17 Super White TRD Pro
    C4 Sliders...
    Picked them up in the fall and decided to hold off on putting them on until after winter. Want to give the frame a good cleaning in the spring beforehand.
    5six[OP] and Thacrow like this.
  7. Mar 8, 2023 at 6:38 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I’ve got a Harbor Freight Apache rifle case in my garage waiting for me to mount in my roof rack. I’ll need a little extra dry storage for a trip out west this summer….
    Cheers
    Bob
  8. Mar 8, 2023 at 11:02 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    -RCI rear differential skid. This has been sitting, brand new, for over a year. Still debating wether to install or sell
    -ARB rear diff breather kit
    -Canvasback rear cargo side and hatch protectors
    -Trail4Runner heritage/pro style grill
  9. Mar 8, 2023 at 3:56 PM
    5six
    5six [OP] New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    RCI rear diff skid, I still have to get that at some point. At least the rest of the stuff isn’t too difficult to install.
  10. Mar 8, 2023 at 10:12 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Just bought a like-new set of Apex Overland Front Recovery Points w/ KDSS. Been watching for a good cash sale through the community, and it finally came. Gotta remove bumper, and drill out frame.
    Dabigono and 5six[OP] like this.
  11. Mar 9, 2023 at 6:07 AM
    jth
    jth trdle
    Saint Paul, MN
    2020 Army Green 4Runner TRD Pro
    Waiting for snow to be done here, but so far:
    * front license plate mount
    * Accessorides remote starter
    * Miller cat shield
    * H9 headlight bulbs
    5six[OP] and Steely123 like this.
  12. Mar 9, 2023 at 3:12 PM
    Dr. KDSS full kit in mail
    5six[OP] and JETSPD1477 like this.
  13. Mar 9, 2023 at 7:04 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i’m hoping to get mine installed too. dom is a stand up guy.
    5six[OP] and djwantke[QUOTED] like this.
  14. Mar 11, 2023 at 10:29 AM
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    Well, my new suspension is sitting at R4T in Denver waiting for my appointment on 3/27. Unfortunately I can't get up there any sooner to have it installed. I'm doing a 2 1/2 to 3" lift on Elka's with the SPC adjustable UCA. They will also be doing a slight bumper cut so I can fit 33's on it. I have new rims on order with TPMS's coming soon and I'll need to pick up the tires I want between now and the 27th. I'm also going to have them do the ARB Diff breathers since they will have it up on the lift it will be easier for them to do it.
  15. Mar 14, 2023 at 11:46 AM
    Being installed this week
    1. Eibach Pro lift 2.0
    2. Toyo AT3s 33s
    Finished over winter:
    1. Crestone Roof Rack
    2. Diode Dynamics fog lights (ran to their own switch)
    3. 4 ditch lights
    4. BD Led light bar on the crestone
    5six[OP] and djwantke like this.
  16. Mar 14, 2023 at 5:50 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Add AVS aeroskin and in-channel window ventvisor to my list
  17. Mar 14, 2023 at 8:38 PM
    I have waiting...and waiting....because I want to do it myself with the help of some pros...
    Breaks, durobumps, ARB breather, panhard correction bracket, and a 50K lube/grease maintenance check all around. Hopefully this weekend...
  18. Mar 14, 2023 at 9:02 PM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    This was the first thing I put on. I have had it on and off a few time now, it’s actually not bad. If you are creative with angles, you don’t have to disconnect the sway bar. Tightening the small nuts where the drive shaft neck connects to the beefy piece is probably the most annoying part.
    I am still waiting to install:
    RCI cat guards onto my skids
    FJ Toyman rear shock mount skids
    Shovel mount for my rack
    Seat fire extinguisher mount
    5six[QUOTED][OP] likes this.
  19. Mar 14, 2023 at 10:32 PM
    #49
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    This is what we have in possession that needs to be installed right!?!? :D
    ARB DUAL COMPRESSOR
    PARACORD WRAP THE STEERING WHEEL
    Finish the dual battery install (mount is in, just nothing else)
    Install the Dana 60 front and 70 rear..... If I decide to go that route hahahahahhaha kidding...kinda....
  20. Mar 14, 2023 at 11:55 PM
    #50
    Added Alpharex MK2 Nova headlights to the mix. I’m off next week but it’s raining for most of it.
    Doglover2003 and 5six[OP] like this.
  21. Mar 15, 2023 at 5:28 AM
    #51
    5six
    55_4Runner
    2022 Black TRD ORP
    Wow, with all the new posts I’m feeling less guilty about waiting to install. Maybe I should order more parts, lol. Picking up a an additional TPMS sensor for the spare tire (which will be part of the rotation).
    MyWyfsRnnr likes this.
  22. Mar 15, 2023 at 5:58 AM
    #52
    5six
    55_4Runner
    2022 Black TRD ORP
    I’ve been paranoid about theft now that I’ve raised it, just ordered mine from RCI and read diff guard.
  23. Mar 15, 2023 at 6:43 AM
    #53
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    You need to set them per the TRA charts.
  24. Mar 15, 2023 at 8:41 PM
    #54
    Mr Rutherford
    Houston, TX
    2019 SR5
    Did they just rename the Nova G2 to MK2 this week? I ordered the Nova G2 last week and now this week its called MK2. Odd.
  25. Mar 15, 2023 at 8:55 PM
    #55
    I remember seeing the G2 somewhere since I was eyes these for a while.
  26. Mar 16, 2023 at 2:46 PM
    #56
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    My list:
    DR KDSS harness kit
    OEM flip open pocket cover under AC control
    Driver side grab handle
    Trail Grid Pro Sony XAV-AX8100 bundle
    Southern Style Off Road slimline front bumper
    Extreme LED stealth 30" light bar
    RSG rear lower shock guards
    RCI aluminum gas skid
    C4 rear diff skid
    Reroute radio antenna location
    Oh yeah the FSR Aspen Lite RTT when I get to order it on March 20th 2023 :laugh:
    5six[OP] and whippersnapper02 like this.
  27. Mar 16, 2023 at 2:51 PM
    #57
    Doglover2003
    '18 ORP w/KDSS
    Dam i forgot:
    Total Chaos gusset kit for front spindle
    Total Chaos alignment reinforce tabs
    ECGS driverside CV bearing kit
  28. Mar 16, 2023 at 2:52 PM
    #58
    Doglover2003
    '18 ORP w/KDSS
    Nah too much OT work/family life then enough down time to work on the truck
    Trail Runnah and Mr Rutherford like this.
  29. Mar 16, 2023 at 3:27 PM
    #59
    Work, school, not being interested...don't worry, we can wrench.
    Doglover2003 likes this.
  30. Mar 16, 2023 at 3:32 PM
    #60
    K. Not all of us are you.
