What do you get out of a single tank?
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Feb 23, 2024.
  1. Feb 23, 2024 at 6:06 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Shotguns and rifles are fine :yes:
    djwantke and 2Toys[QUOTED] like this.
  2. Feb 23, 2024 at 6:08 PM
    Yotaholic
    Olympia, WA
    Give us BC and you keep Alaska. Deal
  3. Feb 23, 2024 at 6:35 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I wish we had Alaska !
    No deal
    Yotaholic[OP] likes this.
  4. Feb 23, 2024 at 6:53 PM
    Yotaholic
    Olympia, WA
    I did the math. In the worst case scenario I would need 300 gallons of gas to drive to Alaska and back. Around $1,500
  5. Feb 23, 2024 at 7:20 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    You miscalculated.
    Worst case scenario you get eaten by a bear before you get back since you can’t bring your guns
    2Toys and Yotaholic[QUOTED][OP] like this.
  6. Feb 23, 2024 at 7:20 PM
    Photon_Chaser 48576 and counting…
    Roger
    Sierra Nevada Mountains
    Like this one! :D
    BS67, 2Toys[QUOTED] and Yotaholic[OP] like this.
  7. Feb 23, 2024 at 7:30 PM
    You fuckers sure know how to derail a thread... Wasn't this about miles per tank? Now we're talking about guns and moose and Canada??
    BS67, djwantke, 2Toys and 1 other person like this.
  8. Feb 23, 2024 at 7:30 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    It's worth a look. Among other things, the ratio of successive numbers in the Fibonacci sequence approaches the golden ratio as they get large.
    https://en.wikipedia.org/wiki/Golden_ratio
  9. Feb 23, 2024 at 7:38 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    We definitely know what we are doing. :D Keep poking the bear and we will make you spend more money on your truck... :spending:
    icebear, BS67 and Yotaholic[OP] like this.
  10. Feb 23, 2024 at 7:43 PM
    Roger
    My averages so far are in line with your results. Better by around 10% when I buy the 'good' gas in Nevada State!
    Yotaholic[QUOTED][OP] likes this.
  11. Feb 23, 2024 at 7:46 PM
    Yotaholic
    Olympia, WA
    Are you stock? I am not.
  12. Feb 23, 2024 at 7:48 PM
    Roger
    Yup, totally stock but with around an extra 200 pounds on her full time.
  13. Feb 24, 2024 at 5:12 AM
    On my '19, it comes on when there's around 4.5-5 gallons left. Cruising range seems to hit 0 when there's around 3 gallons left.
    I was thinking the same thing. Maybe they're going by the estimated fuel range after refueling, which isn't very accurate, either. :notsure:
  14. Feb 24, 2024 at 6:43 AM
    TrailSpecial22 New Member
    PA
    285-300 depending on what im doing
  15. Feb 24, 2024 at 8:30 AM
    Curlystooge
    Curlystooge Member
    2022 limited in magnetic grey
    Damn, got me off on a math tangent. I thought I was doing great just remembering the order of operations! That is most interesting, thanks for the link. Now back to gasoline stuff.
  16. Feb 25, 2024 at 7:12 AM
    HuskerRunner
    O,NE
    2023 SR5P
    i havent actually done the math, but anecdotally I suspect the light comes on at 3x the avg mpg left.
    Edit: Which is a stupid way to say "3 gals left" on my part. What I mean is I've run it down pretty low since new, filled up at 0 range and beyond. And its fluctuated .5-.75 of a gallon depending on if the last tank was mainly highway vs in town
  17. Feb 25, 2024 at 11:34 AM
    Gumpus
    Gumpus New Member
    Exactly.
    I get about two weeks out of a tank.
    Yobruhitsme[QUOTED] likes this.
  18. Feb 25, 2024 at 1:01 PM
    semprenissart
    semprenissart Mèfi
    That’s even more inconsistent
  19. Feb 25, 2024 at 2:41 PM
    #49
    icebear Recovered Kia Owner
    “this baby only takes $20 to fill up!”
    semprenissart[QUOTED] likes this.
  20. Feb 25, 2024 at 3:22 PM
    #50
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    It’s a joke.. about as precise as miles / tank.
