What brand of grease you using
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Aug 4, 2023.
  1. Mar 29, 2025 at 12:48 PM
    #91
    Nope. Toyota specifies lithium-based grease for the U-joints: https://assets.sia.toyota.com/publications/en/om-s/OM35C03U/pdf/OM35C03U.pdf
    This is not to say the Spicer grease is bad, but you should stick with the same grease for the rest of your U-joints' life and avoid mixing with lithium grease.
    2025 gasser manual no longer specifies any grease, which probably means the 6th gen U-joints aren't greaseable: https://assets.sia.toyota.com/publications/en/om-s/OM35B85U/pdf/OM35B85U.pdf
