What brand of grease you using
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Aug 4, 2023.
  1. Aug 9, 2023 at 7:19 PM
    #61
    Some does come out at the swiper seal, if the grease gets up that high, as the suspension and slip yoke move. I think the trick is to make sure it’s not so full, that on a hard/deep suspension hit, it blows the pressed cap off the end of the shaft due to hydro lock.
    So yeah, I agree, you have to be careful once you know it’s full inside there. Now that mine is “full” I’m keeping an eye out for evidence of grease around the swiper seal area. I’ll plan to only add a few pumps if it looks dry, and skip it if there is still a little grease around that area.
    TCW1184[QUOTED] likes this.
  2. Aug 9, 2023 at 8:21 PM
    #62
    The manual specs lithium for the spiders, and as an option for the slip yoke. But, based on the replies here, most people are just using whatever.
    Toy4X4, RingSteel and McSpazatron like this.
  3. Aug 13, 2023 at 5:05 PM
    #63
    AFDL17
    AFDL17 New Member
    Ha! I pulled one off the shelf at the store but then put it back when I saw the price. Maybe I should go back and get it, although there’s something to be said for doing it the hard way first (within reason) - just so you can appreciate why the easy way is better.
  4. Aug 13, 2023 at 5:11 PM
    #64
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Thixogrease.
  5. Aug 14, 2023 at 4:13 AM
    #65
    On the JBA control arms we use a synthetic silcone based grease from Mobil (XHP 222 special) as reccomended by JBA. For the drive shafts a Lucas lithium base. Years ago I used a 'grease' on poly control arm bushings, although it took some time, eventually they started to squeak. Once they start squeaking it's a uphill battle to get them to stop. FWIW.
  6. Oct 10, 2023 at 3:43 PM
    #66
    backpacker
    backpacker New Member
    2023 TRD ORP
    What's the best tool to unscrew the zerk? I'm thinking a small adjustable wrench, but there's little room to maneuver, so it seems like there would be a special-purpose wrench.
    I've read elsewhere that dropping any of the skids wasn't necessary, but when I got underneath and looked, it sure seemed like this one is likely to be problematic, especially if the shaft is rotated to an unlucky position.
  7. Oct 10, 2023 at 3:49 PM
    #67
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Any recommendations for a silicon paste for sunroof?
    I have the spray kind but would prefer a more thicker consistency to put on the sunroof rubber beading.
  8. Oct 10, 2023 at 4:06 PM
    #68
    mtnslyr
    mtnslyr New Member
    6 or 7 mm socket for the zerk, on a small extension.
    The plate is just a single bolt, I think it’s there to protect exhaust pipe from grease splash.
  9. Oct 10, 2023 at 4:10 PM
    #69
    Oakboro, N.C
    Responding to Lc200...
    I have used this on numerous seals, It is really thick, So a little bit goes a long way.
  10. Oct 10, 2023 at 4:22 PM
    #70
    No special tool needed. A regular wrench will suffice… I believe it was a 6mm, or 7mm, or maybe 8mm lol. It’s tiny, so be careful to not over torque. Gutentight, the standard for German metrology. No more.
    Also, the front shaft rotates in 2wd, so you can move the zerk to whatever position is best.
  11. Oct 10, 2023 at 8:13 PM
    #71
    backpacker
    2023 TRD ORP
    Thanks, I'm glad I have what I need. I used 4L to get up the ramps, so I'll back down and try again in 2H if I can't get at the zerk.
  12. Oct 10, 2023 at 11:47 PM
    #72
    I would try putting it in N and disengaging 4wd, Should work on the dial operate TC, I would guess. I only mention it since I hate trying to get my 4runner up on the ramps in 2wd…they always get pushed.
  13. Oct 11, 2023 at 5:57 AM
    #73
    Why use ramps in the first place?
    I've never needed ramps to grease the zerks.
    Toy4X4 likes this.
  14. Oct 11, 2023 at 6:10 AM
    #74
    backpacker
    2023 TRD ORP
    I also changed the oil, and stopped to paint the trail rash on the skids while I had them off, as well as refreshing the woolwax on the jack points from rotating the tires.
  15. Oct 11, 2023 at 6:11 AM
    #75
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Are you guys using a heavier duty ramp for 4r? I have rhino ramps for car but not sure I trust the weight of truck. Luckily I don't need them so far since plenty of room to crawl under truck. The predator steps were my biggest pain until removed and replaced with sliders.
    Didn't know the sliders would make it easier for me to slide under truck.
  16. Oct 11, 2023 at 7:10 AM
    #76
    backpacker
    2023 TRD ORP
    I use Rhino ramps. They're rock solid. I'll also replace my Predator steps with sliders before long.
    Adding: my warning label says 3000 pounds each, 6000 pounds for a pair, or 12,000 pounds for four. Thus more than twice what's needed in any application for the 4R.
  17. Oct 12, 2023 at 9:25 AM
    #77
    Cuda
    Cuda New Member
    Lucas Red 'N' Tacky for the spider joints, Mobilgrease XHP 322 Mine for the slip yokes.
  18. Oct 12, 2023 at 9:29 AM
    #78
    backpacker
    2023 TRD ORP
    FWIW, my zerks are 7 mm.
  19. Oct 12, 2023 at 9:53 AM
    #79
    4R777
    4R777 New Member
    I also use this
  20. Nov 14, 2023 at 8:49 AM
    #80
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    This is what we used. It is most sticky, tacky grease I have used. I don't think it's possible to wash it out. Hard to push in hand pump gun. I don't want where you get.
  21. Nov 14, 2023 at 7:19 PM
    #81
    2Toys
    Gordon
    2019 4Runner TRDORP
    Remind me not to have lunch with you!! :D:D:D
  22. Nov 14, 2023 at 8:43 PM
    #82
    HazOpRed
    HazOpRed 22' TRDOR
    The red one
  23. Sep 28, 2024 at 6:41 AM
    #83
    JoeSchmo
    JoeSchmo New Member
    2024 silver TRD ORP 4Runner
    Got a 2024 and still has zerks. 6 total between prop and drive shafts
  24. Sep 28, 2024 at 8:00 AM
    #84
    Those that mention Lucas Red-n-Tacky - are you using that on both the universal joints and the drive shaft?
    I need to do this...
    raimieb likes this.
  25. Sep 28, 2024 at 8:05 AM
    #85
    UncleShorty
    UncleShorty New Member
    I use a German brand call Veinner-Schlider for all my lubrication needs...
    whippersnapper02 likes this.
  26. Sep 28, 2024 at 8:41 AM
    #86
    TrailSpecial22 New Member
    PA
    Lucas Red n' tacky
  27. Sep 28, 2024 at 9:27 AM
    #87
    Same here. I bought a mini grease gun and a 3 pack of cartridges which included a red n tacky.
  28. Sep 29, 2024 at 6:30 PM
    #88
    Impractical buy
    Impractical buy New Member
    Windy City (ish)
    2015 Limited
    I have this loaded in the grease gun for the trailer, and other misc steering components. Turns out it meets the specs, so I use it.
  29. Sep 30, 2024 at 12:15 PM
    #89
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    I use Lucas Red n Tacky on everything. It works fine and I flush it through regularly enough it never dries up or really pushes the limits of the grease. Any quality grease that meets specs should be fine as long as you keep up with maintenance intervals so grease is always clean.
