Westcott or wait for Eibach for pro?
Discussion in '5th Gen 4Runners (2010-2024)' started by Zal4R, Aug 16, 2021.
  1. Oct 3, 2021 at 8:02 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    Random question: will the eibach springs be able to compensate for the additional weight of a front bumper/winch?
  2. Oct 3, 2021 at 8:24 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    No. They aren’t a heavier weight
    Jrunr[QUOTED] likes this.
  3. Oct 4, 2021 at 2:24 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    That’s good to know. At what point Will I have to make adjustments for the weight? (How many added lbs?)
  4. Oct 4, 2021 at 7:08 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    you can get away with a slimline bumper and winch but you’re going to lose some of that lift. I wouldn’t run them with a full bumper.
    My bumper is off right now so you can see the difference.
    F5F47AF3-219A-4BCC-AE4D-7DF4628D2EDD.jpg 5773796C-7584-4337-B4AD-6F655C02B428.jpg
    Rocksurfer and Jrunr[QUOTED] like this.
  5. Oct 4, 2021 at 7:28 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I disagree. My Eibach kit definitely helped support my bumper, winch, and skids.
    Spring rate for front Eibach Coils = 662lbs Spring rate for rear Eibach Coils = 206lbs +/- 2% Here's my 4Runner:
    No lift no winch or bumper:
    Warn bumper with steel cable Warn Winch - note the front end sag:
    Eibach Pro Truck Lift (4 coils 4 shocks) set on the lowest front shock setting:
  6. Oct 4, 2021 at 7:44 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    That’s dandy and all, but you’re still sagging on the eibach’s.
  7. Oct 4, 2021 at 7:51 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    True.
    I could crank up the shocks but seems that would limit travel / worsen ride quality.
  8. Oct 4, 2021 at 9:24 AM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    He was asking about the Trd Pro 4RNR setup that goes with Fox Shocks
    DRobs[QUOTED] and Jrunr like this.
  9. Oct 4, 2021 at 12:28 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    That is correct. Do we know if the spring rates are going to be the same as stock?
  10. Oct 4, 2021 at 12:41 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    no one really knows the OEM spring rate. It’s been a mystery lol.
  11. Oct 4, 2021 at 12:44 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    Eibach will know. They know everything!!! Lol
  12. Oct 4, 2021 at 2:11 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Just get the Eibach and stop procrastinating. Lol.
    nimby likes this.
  13. Oct 4, 2021 at 5:08 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Missed that.
  14. Oct 5, 2021 at 1:13 AM
    Zal4R
    Zal4R [OP] New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    That’s the thing. We are still waiting for the eibach kit for the front of the 2021 pros.
    Jrunr likes this.
  15. Oct 5, 2021 at 3:38 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    Yes. “Patiently” waiting. Lol
    patiently waiting for these springs, the Magnuson SC, new headlights… everything for the 2021’s. Lol
  16. Oct 7, 2021 at 12:34 PM
    Gossamer
    Gossamer lunarrocktrdpro1
    Middle of America
    got bad news for all you Eibach folks waiting for front springs...6 months is what I was just told by corporate. Won't be available until March 1, '22 at the earliest.
  17. Oct 7, 2021 at 1:11 PM
    Jeez. So are they having trouble getting enough steel to make them or are they having trouble with the new design for the Fox shock?
    Or maybe a labor shortage?
  18. Oct 7, 2021 at 1:16 PM
    RusPro17
    Don
    Pa.
    Probably the labor shortage Jake. I work in a steel mill and we cannot get anyone to come in an work. The place I work in use to be so hard to get into. I would just go with the westcott if your looking to do it and cannot wait.
  19. Oct 7, 2021 at 1:20 PM
    #49
    Crazy times.
  20. Oct 7, 2021 at 6:16 PM
    #50
    Gossamer
    Middle of America
    The guy didn’t say a word about labor…said a part needed wasn’t available until March…previously, he had mentioned the design change in the spring that is causing a different manufacturing process. Who knows…I never thought I’d hear a company say they’d have a 6 month wait on a spring. Strange times for sure.
    nimby likes this.
  21. Oct 7, 2021 at 8:24 PM
    #51
    Zal4R
    ‘21 LR TRD Pro
    So then my question now is does anyone with the wescotts have testimony on how they hold up to mild to moderately challenging off-roading. Anything from dirt roads to some class 4 stuff?
  22. Oct 7, 2021 at 9:16 PM
    #52
    banxwondar
    banxwondar @t4r08
    San Jose,CA
    21trdp
    -King 2.5 w/ adjusters -Westcott sliders 0 degree, DOM, no kick, plates, TIG -1.25" Spidertraxx Spacers -305/70/17 Maxxis Razr -CVC tune -20% Ceramic all around - Total Chaos UCA, cam tab, lower link skid -Black Rhino sradium 17 x 9.5 -18 -Joes side load panel -prinsu non drill rack -gobi ladder -eimkeith PCK
    They hold up great!
  23. Mar 18, 2022 at 12:34 AM
    #53
    JeanFamClan
    JeanFamClan New Member
    Could you install both kits for two inches of lift? If so, would you need a diff drop or UCAs?
  24. Mar 18, 2022 at 5:24 PM
    #54
    Zal4R
    ‘21 LR TRD Pro
    I just put my eibach springs on. You would probably need a new UCA if you did both. While not too far off, there was not quite enough adjustment left to get the camber to where it should be. (#should be 3, we got it to 2.6). Would think both might cause that issue to be a bit worse.
    JeanFamClan likes this.
  25. Mar 18, 2022 at 6:53 PM
    #55
    achtung6
    achtung6 New Member
    I hear ya! I'm waiting on the Magnuson SC as well. Just ordered the Wescott lift kit for my Fox suspension. Looking forward to have that installed!
    Rocksurfer likes this.
  26. Mar 18, 2022 at 9:04 PM
    #56
    T4Rrunning
    T4Rrunning New Member
    how are you liking the Eibach pro springs? Any pictures?
  27. Mar 20, 2022 at 7:07 AM
    #57
    Zal4R
    ‘21 LR TRD Pro
    I am loving the springs. The ride is slightly stiffer, not as much nosedive or roll when breaking and cornering (enough that my wife noticed and said she likes it better, she never notices stuff like that). I will not have a chance to get off-road until Jambo at the end of April, so I will update then for that side. The lift is subtle if you do not know what things normally look like. I went up an inch in the rear, and a little less than an inch and a half an inch in front, will keep an eye on that for settling. Only extra weight is my aluminum rci skids. I am still on stock tires, will probably be switching to 255/80/r17s when I wear these out.
    Will try to get a picture today if I can. Pictures:
    before
    After
    Jrunr, YetiMtnBkr and nimby like this.
  28. Mar 26, 2022 at 1:15 PM
    #58
    Zal4R
    ‘21 LR TRD Pro
    For reference, the top point on my rack only went up a little over and inch. Now it is just sky of 80. After a week of settle, a little under 1.5 gained from hubs to front fenders and still right at an inch in the back. That is after I put my RCI Aluminum sliders back on. Now I have to wait until I wear out my nittos to figure out tire, which gives me about a year (the boss said I cannot get tires right now).
  29. Mar 27, 2022 at 12:32 AM
    #59
    tn4runner
    tn4runner New Member
    I had a terrible experience with eibach. my 20 ORP making noise front and rear after installing. I had a local shop installed everything and the shop manager said it will making noise when driving there no way to fix it, idk if I have another shop remove and reinstall everything will fix that. Just so sad.
  30. Mar 27, 2022 at 5:51 AM
    #60
    Zal4R
    ‘21 LR TRD Pro
    What kind of noise, so I can listen for it. Mine sounds the same as always, makes creaking noises getting in and out on hills, but it has always done that.
