Was rear ended in a hit and run. Wondering if I may be able to fix it myself. Does this look fixable
Discussion in '5th Gen 4Runners (2010-2024)' started by MarcRed4R, Nov 26, 2023.
  1. Nov 28, 2023 at 3:40 PM
    MarcRed4R
    MarcRed4R [OP] New Member
    2021 Red 4Runner TRDOR
    @Redwood thank you for mentioning that I had no idea. I looked it up could it perhaps be this? If so it is listed as the reverse sensor. I don’t have any issues with the back up camera and my 21 never had any sort of warning sounds not sure about newer 4Runners.1316CCB1-CDB8-4AE9-A0D1-730F6DD453BC.jpg
  2. Nov 28, 2023 at 3:53 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    No it's not just a sensor but a module with like 12 wires in the connector. Doesn't look like #19 on your parts diagram. Don't believe it's connected with the rear camera. I've been leaning to it possibly being the smart key receiver for rear hatch unlock/window functions but not sure. Are you push button start?
  3. Nov 28, 2023 at 4:21 PM
    MarcRed4R
    Looks like that may have been added on the 22 model. Found this on another thread.5AAF8065-6493-4AFA-B7A7-2B69DBB7F8A0.jpg
  4. Nov 28, 2023 at 4:36 PM
    Redwood
    Redwood New Member
    Quite possible as I said i wasn't sure what it was. But yes my "22 has BSM and RCTA. Could be part of the RCTA. My point is get under that corner and look. No module no worries.
  5. Nov 28, 2023 at 7:51 PM
    MarcRed4R
    @Redwood Checked and no module. The electrical harness only goes to the tail lights, at least as far as I can tell without taking off the bumper.
  6. Nov 28, 2023 at 9:29 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Yes, and drill out the frame LOL
    The bumper comes off, and more importantly the crush bar and it's mounts come off - because you use the frame holes behind that to fish in a nut plate for two 17mm bolts.
    Lucky me right?! I actually have enjoyed taking bumpers off.
    On non KDSS trucks, you unbolt the sway bar and sandwich the recovery point underneath on each side.
  7. Nov 28, 2023 at 9:30 PM
    Is that right eh?
    Gotta love the 2016, no bumper sensors or gadgets - they pop right off
  8. Nov 29, 2023 at 9:14 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    You forgot the part about swearing because you unbolted both sides of the swaybar brackets.
    That was fun.
    djwantke[QUOTED] likes this.
  9. Nov 29, 2023 at 10:03 AM
    Oh nooo, hah!
    Ya so I didn't have unbolt my sway bar, BUT, the KDSS cylinder and beefy sway bar get in the way of drilling 1 of two holes on either side that I must drill out. Hence my delays.
    FML
  10. Nov 29, 2023 at 10:12 AM
    bassist
    bassist New Member
    Have you reached the "Why didn't I just pay someone to do this?" point yet?
    That's a fun time. Happened with my sliders when my neighbor showed up to see what I was doing and then basically installed them single handily. :D
  11. Nov 29, 2023 at 10:21 AM
    @bassist haha I don't know if I'll ever be at that point, I do everything myself, I have the mentality of a Maker.
    Except I don't do fluid changes, YET!
  12. Nov 29, 2023 at 11:00 AM
    bassist
    bassist New Member
    I always start out thinking that I'm a "Maker" only to discover that there was dirt covering everything before "aker" and it really said "Breaker".
    NE Runner likes this.
  13. Nov 29, 2023 at 11:19 AM
    @bassist that's a good one!
    Very true
    Like most men I tend to also ignore instructions until I've wasted a sufficient amount of time going in the wrong direction. Like when I removed the crush bar for the first time, and first unbolted 6 nuts what were not necessary :rolleyes:
  14. Nov 29, 2023 at 7:22 PM
    bassist
    bassist New Member
    I have an actual diagnosis of ADD, so at least I have an excuse for some of my boneheaded moves. :D
  15. Nov 30, 2023 at 7:50 AM
    TheGreekFreak
    TheGreekFreak New Member
    Ughhh, sorry this happened to you. Some people are just selfish, irresponsible children in adult bodies.
    When stuff like this happens to me (vet bills from irresponsible dog owner’s demon dog attacking mine, finding damaged car in parking lot, etc), the reality that I’m fortunate enough to fix the issue without losing sleep while that other person had to stoop to being an immoral, panicked, responsibility-evading ass gives me perspective not to get too upset.
    In your case, you probably came out pretty cheap….if not ahead of you use it as an opportunity to go with the black valences lol. Awesome that the bumper just snapped in and didn’t deform or lose a bunch of clips.
    Outside of the electronics in the bumper, my big concern would be with the trailer ball taking most of the impact. While that may have saved you expensive body damage, hopefully it did not translate to any bent medal associated with the hitch itself.
    MarcRed4R[OP] likes this.
  16. Dec 3, 2023 at 9:24 PM
    MarcRed4R
    @TheGreekFreak Thank you I worked on it today and was able to install the front and back black valences. Luckily I did not see any big surprises, here are update pics, not perfect but good enough.
    TheGreekFreak likes this.
  17. Dec 3, 2023 at 9:27 PM
    MarcRed4R
    Thanks all for the suggestions and feedback!
