Waiting on 2025 but need a vehicle now
Discussion in '6th Gen 4Runners (2025+)' started by Dare2Dream, May 27, 2023.
  1. Aug 29, 2023 at 5:04 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I liked taking a step backward in tech when I got my 2023! :)
    broken-giver, LuLu and RusPro17 like this.
  2. Aug 29, 2023 at 10:17 AM
    broken-giver
    broken-giver BFD
    lol what dealership overlord control you talking about. And people will regret keyless fob, really? I don't even know what tech windshield is -- mine just looks like glass windshield :p
    DirtyHairy likes this.
  3. Aug 29, 2023 at 10:57 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    this
    Windshield has technology in it like the camera interconnects, needs to be recalibrated and shit anytime you want to replace. Personally I don't need or want stuff like that but it's the new norm I understand. Not on my 2016 it ain't.
    https://www.4runners.com/threads/windshield-sticker-shock.16725/
    Dealership wants to collect data and track you're data and behavior more than some realize. They don't always make everything clearly known to you and can be difficult to work with to disable features. Re: connected services; safety connect, service connect, etc
    https://www.google.com/url?sa=t&sou...IoAXoECCMQAg&usg=AOvVaw3NGg1XHZlwVybNOIciMJ7a
    Keyless fob technology comes with concerns about theft, allows addition methods for thieves to unlock and start your vehicle. Yes, there is a lot of info out there to curb this, but I'll stick with my key thank you.
    I can keep going :p
    Ripper238 likes this.
  4. Aug 29, 2023 at 1:36 PM
    broken-giver
    broken-giver BFD
    so what can be replaced by insurance companies (once per year is standard) is problematic tech for you?
    have you used any google or fb product in last couple of decades it will eclipse whatever Toyota is collecting. Plus opt out is an option.
    how many thefts have happened due to keyless fob entry for a 4Runner?
    Pls keep going, I am curious why a 4Runner 2019 or lower is da-bomb and 2020+ are dripping with so much tech that they’ll break if you drive fast on a pothole :cool:
  5. Aug 29, 2023 at 1:38 PM
    It's just my opinion buddy, you're looking too deep into my comments. I prefer less tech, I've provided my reasoning. No offense
  6. Aug 29, 2023 at 1:40 PM
    I'm a simple guy, and a good enough driver to not want or need even blind spot mirrors, lane assist, safety sense, automatic parking. Less is more I feel. Once the day comes that someone gets hit with a bill to service these things, the love may wear off a little.
    Han4Run and gomiami like this.
  7. Aug 29, 2023 at 1:46 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I love my tech, but I agree with you. That's exactly why I bought a 2019 just before they added the nanny systems (though good, not perfect). Plus I see way more issues with what I call post COVID models with all this extra tech. They even had a shortage of key fobs so they went back to keys for some models.
    One day ill have a battery powered 4Runner/Landcruiser/GX550, but not till I feel they are refined to what I feel they should be.
  8. Aug 29, 2023 at 1:55 PM
    Yeah buddy, I agree with ya'll - like enjoy material things and Amazon and tech like everyone does. I'm in the tech industry. I know it all fails and is overpriced. So I really enjoy my 2016 and it's somewhat closeness to the older simple v6 4Runners. If I could I wish I could have grown up in an older generation, especially during disco lol
  9. Aug 29, 2023 at 1:56 PM
    Ripper238
    2019 TRD OR
    You had me till disco. lol
  10. Aug 29, 2023 at 2:30 PM
    @Ripper238 Hahaha you know what disco is a bad choice of words.
    I mean during the period where Bob Marley came out with Natural Mystic in '77. Or being able to see the Doobie Brothers live early 70's.
  11. Aug 29, 2023 at 2:45 PM
    Anyways, @Dare2Dream OP, sorry to hijack your thread a bit.
    The 2024 4R is a killer vehicle, do it. Figure out getting your hands on a 6th gen after a few years pass, and perhaps after a facelift happens.
  12. Aug 30, 2023 at 1:30 PM
    4R777
    4R777 New Member
    Imma take wild guess and say the first year of new 4Runner will have less major recalls and problems than usual, since it will likely get an engine, frame, and some other parts already in use on other vehicles.
    But yah, normally buying first year of new model is a bit of a gamble.
    MooreKen, nimby and djwantke[QUOTED] like this.
  13. Aug 30, 2023 at 3:23 PM
    garoto
    garoto New Member
    This is way too true. I unfortunately will be shoved into up to my Ying Yang, but at least it’s still a 5th gen. But if you can get a good one and tech-less that’s much better. Just hearing the words “windshield camera alignment for $2k” after a rock chip grosses me out, you don’t have that problem with pre-2020.
  14. Oct 10, 2023 at 2:49 PM
    TQ41
    TQ41 New Member
  15. Oct 10, 2023 at 2:50 PM
    TQ41
    TQ41 New Member
  16. Oct 10, 2023 at 3:23 PM
    Banda
    Banda New Member
    Same boat. Made the decision to get a 24'. Drive it to the ground, by then 6th gen will have all the kinks out. Win win.
  17. Oct 10, 2023 at 3:28 PM
    4R777
    4R777 New Member
    By the time you drive it into the ground, 7th gen will be out. They're that good. :)
    nimby and Banda[QUOTED] like this.
  18. Oct 10, 2023 at 3:59 PM
    Banda
    Banda New Member
    Will the 7th gen hover? Fly? :cool:
  19. Oct 10, 2023 at 4:15 PM
    #49
    broken-giver
    broken-giver BFD
    Knowing how conservative Toyota is…I’d say…no.
    Latrans, nimby and Steely123 like this.
  20. Oct 11, 2023 at 3:25 AM
    #50
    Toyota is the apple of vehicles. They wait for everyone else to do the new stuff and catches up about 5 years later. Lol.
    broken-giver[QUOTED] likes this.
  21. Oct 11, 2023 at 4:09 PM
    #51
    Ripper238
    2019 TRD OR
    How dare you compare Toyota to Apple.....
    Pavo and Steely123[QUOTED] like this.
  22. Oct 11, 2023 at 4:46 PM
    #52
    LA260
    LA260 New Member
    No but it will probably have full LED headlights/DRL/turn signals and tail lights.
  23. Oct 20, 2023 at 11:38 AM
    #53
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    I wonder what the percentages are driving the desire for later technology added to vehicles ?
    1 Federal Government mandates:
    2 Manufacturer added for their dealers benefit:
    3 Natural desire by consumers for additional creature comforts/convenience:
  24. Oct 24, 2023 at 7:10 PM
    #54
    KENTUCKYRUNNER
    KENTUCKYRUNNER New Member
    2006 sport to a2016 SR5 PREMIUM TO A 22 LIMITED
    exactly, that dude is over the top. guess my 22 and me are doomed
    DirtyHairy and clonebuilder like this.
  25. Oct 25, 2023 at 7:56 AM
    #55
    Meanwhile even the 70-series Land Cruiser sold in global markets is getting adaptive cruise control and blindspot monitoring (see the covers where the tail lights used to be?)
  26. Oct 25, 2023 at 9:46 AM
    #56
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    I will go with #3. It is the same reason why pickups have gotten so big.
  27. Oct 25, 2023 at 10:56 AM
    #57
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    And they are indeed BIG now. LOL
    I can remember renting one of the earlier Chevy Suburban's many years ago. It was like driving a battle ship filled with water. LOL But, I had to admit, when hauling both people and luggage on a long highway drive, it was hard to beat.
  28. Oct 25, 2023 at 11:59 AM
    #58
    Reddawg1100, icebear and pastoreater like this.
  29. Dec 2, 2023 at 9:36 PM
    #59
    Jasonst4r
    Jasonst4r New Member
    Jason
    2021 offroad barcelona red
    275 70 17 at3w
    do what you want. take advice in here with a grain of salt. im sure atleast one person in here wears tin foil hats at home so that government cant read their mind....
  30. Dec 2, 2023 at 10:58 PM
    #60
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Jasonst4r[QUOTED] likes this.
