VOA of good quality oils
Discussion in '6th Gen 4Runners (2025+)' started by Yotaholic, Nov 22, 2024.
  1. Dec 4, 2024 at 9:52 AM
    Interesting. I’m assuming the first batch of people getting engine replacements will get new ones then everyone else will get remans. How much of the old engines are reused?
  2. Dec 4, 2024 at 11:50 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    At a remanufacturing plant?
  3. Dec 4, 2024 at 12:20 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Here comes the Pennzoil Ultra report. Not as impressive as HPL. I have made up my mind, I am going with HPL
  4. Dec 4, 2024 at 12:30 PM
    Meaning what parts? Just the block, etc?
  5. Dec 4, 2024 at 12:31 PM
    HighSierraGuy
    HighSierraGuy New Member
    Is this related to all the blown Tundra engines? It seems that problem is still pretty rampant.
  6. Dec 4, 2024 at 12:53 PM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    Why do you think this is good? Magnesium is highly reactive, just like with ZDDP there could be 'too much'.
  7. Dec 4, 2024 at 1:11 PM
    Yotaholic
    Olympia, WA
    Not too much if real chemists do it, not backyard chemists. HPL is a reputable company. Not high magnesium is just for longer OCI.
  8. Dec 4, 2024 at 1:47 PM
    1SilverRunner
    Tejas
    We recycle everything. Bolts, timing gears, cranks, heads, blocks, cams etc. The percentage depends on that particular part's fallout. Some parts are not repairable or reusable. Some OE's do not allow re use or repair of certain parts…. So that's a complicated thing to answer. But generally speaking if we receive 100 core engines we will be able to manufacture 70-80 engines out of majoritively remanned parts.
    Toyota is still in the process of getting all of their customers taken care of. I’d assume they’ve already made changes in their facilities to ensure new engines are no longer suffering the same fate. But unfortunately them continuing production and getting all these engines replaced is likely putting them over capacity. So they’re looking at different companies to help them out. Which is kind of an industry standard to be frank.
    LCJ77 and icebear like this.
  9. Dec 4, 2024 at 1:52 PM
    So an owner could potentially get a replacement engine that has more mileage on its parts than the one they took out. Awesome.
  10. Dec 4, 2024 at 2:12 PM
  11. Dec 4, 2024 at 2:16 PM
    1SilverRunner
    Tejas
    I suppose. But there's an argument to make that our machining and testing protocols are IATF certified and actually go above what most manufacturers require. There's also an argument to be made for work hardening materials; Meaning a crankshaft reground for a larger bearing may actually be stronger than the original crankshaft machined for the OE bearing.
    I think a lot of people assume remanufacturing is this janky process in someone's garage... It's most certainly not. It's a multi billion dollar industry employing millions of American workers. Certified by outside organizations and meeting the same or better standards than most OE's. This is why these companies are trusted and have been contracted by OE manufacturers for the last 80 years.
    LCJ77, roboturner, Mr.DRZ and 2 others like this.
  12. Dec 4, 2024 at 2:19 PM
    1SilverRunner
    Tejas
    Can you post all of these side by side in one post for easy comparison. Including price might be nice for future viewers as well.
    LCJ77 and Yotaholic[QUOTED][OP] like this.
  13. Dec 4, 2024 at 3:17 PM
    4R777
    4R777 New Member
    I'll use Mobile 1 oil in the engine like I always have, and it will last as long, and run as good as anything else. Lol
    LCJ77 and Tama1968 like this.
  14. Dec 4, 2024 at 4:19 PM
    Yotaholic
    Olympia, WA
    HPL Premium Passenger 0W-20, $15.60/quart
    Amsoil Signature Series 0W-20, $15.4/quart
    Pennzoil Ultra Platinum 0W-20, $5.6/quart
    HPL
    Amsoil
    Pennzoil
  15. Dec 4, 2024 at 9:24 PM
    2016Pro
    Yep another dumb oil thread
  16. Dec 4, 2024 at 9:45 PM
    Yotaholic
    Olympia, WA
    :oops:
  17. Dec 5, 2024 at 5:09 AM
    Sin4R
    Sin4R New Member
    Mall crawling kit.
    How do you know that? Is that Brawndo thing or did you actually do some research into what that additive does?
  18. Dec 5, 2024 at 5:58 PM
  19. Dec 11, 2024 at 7:35 AM
    #49
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I wouldn’t touch a new Toyota turbo engine for at least 3-5 yrs. Until I get at least a view of long term durability, I’ll stick with the known quality of the 5th gen. I keep good vehicles a long time.
    Yotaholic[OP] and 1SilverRunner like this.
  20. Dec 11, 2024 at 4:29 PM
    #50
    Yotaholic
    Olympia, WA
    Good for you, I just couldn't pass the new GX
  21. Dec 11, 2024 at 4:43 PM
    #51
    SOSHeloPilot
    SOSHeloPilot New Member
    2024 4Runner SR5
    Owned Many Toyotas - Past
  22. Dec 11, 2024 at 5:27 PM
    #52
    Do you have a GX now?
    What do you think about Valvolines restore and protect oil? I just got some for my Tacoma and change it this weekend. I’ll see if it quiets the engine down like many claim it does.
    Yotaholic[QUOTED][OP] likes this.
  23. Dec 11, 2024 at 7:30 PM
    #53
    Yotaholic
    Olympia, WA
    Not yet. I'm looking for a very particular one so dealer is on the hunt. It will take some time but I'm not in a hurry. This GX is going to be with me for a long long time so I make sure I get exactly the one I want.
    Isn't the Valvoline Restore and Protect for sludged up motors? Did you neglect your Tacoma? If not then don't worry about it
  24. Dec 11, 2024 at 7:49 PM
    #54
    It has 195K miles on it
  25. Dec 11, 2024 at 8:01 PM
    #55
    Yotaholic
    Olympia, WA
    Run Valvoline R&P, but I heard it takes 4 oil changes to make a difference. Or run HPL Premium Plus once. Or run their engine cleaner with their oil
  26. Dec 12, 2024 at 5:34 AM
    #56
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    At 3x the cost of Pennzoil & changing at same intervals! No way worth that much more $$ & I ain't cheap either. But then again I trade vehicles between 70-85k miles.
  27. Dec 13, 2024 at 5:54 AM
    #57
    Sin4R
    Sin4R New Member
    Mall crawling kit.
    Yotaholic[OP] likes this.
  28. Dec 13, 2024 at 2:35 PM
    #58
    SOSHeloPilot
    2024 4Runner SR5
