Victoryrunner Build
Discussion in '5th Gen Builds (2010-2024)' started by victoryrunner, Mar 6, 2019.
  1. Oct 25, 2019 at 7:50 AM
    JulieJ
    JulieJ New Member
    Julie
    2018 4Runner
    none yet
    Looks great !
    victoryrunner[OP] likes this.
  2. Oct 29, 2019 at 11:29 AM
    victoryrunner
    victoryrunner [OP] New Member
    Cam
    2017 SR5 Magnetic Gray Metallic 4Runner
    Falken Wildpeak A/T3 285/70R17 | Mamba Offroad Wheels M23 | 3" BDS Suspension | Victory 4x4 Blitz Front Winch Bumper | Victory 4x4 Strike Sliders
  3. Oct 29, 2019 at 12:09 PM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    ^^^ THAT... right there ^^^
    Outstanding vehicle!
  4. Feb 28, 2020 at 6:30 PM
    Khens12
    Khens12 New Member
    19’ T4R Off Road
    Installed: 20% Ceramic Tint / Pro Grille and LED’s On Order: 2.5 King Coilovers / 2.5 (2) tube bypass shock / Icon UCA / 17” Icon Compression wheels / Eibach 1” lift rear springs / SDHQ Light Bar Mounts / SDHQ Ditch brackets
    Great build and great products!
  5. Feb 29, 2020 at 6:31 AM
    victoryrunner
    Cam
    Thank you!
  6. Mar 9, 2020 at 8:05 PM
    Krezz
    Krezz Doesn't want to be a new member
    Southern Ontario, Canada
    2020 4Runner TRD Offroad
    Well you guys turned my Tundra into a thing of awesome - I can't wait to have the same done to our 4Runner.
    Awesome to see your build up on here as well.
  7. Mar 21, 2020 at 10:09 AM
    Mtbpsych
    Mtbpsych New Member
    Did you get new bumpstops? Or are they not needed?
  8. Mar 23, 2020 at 7:36 AM
    victoryrunner
    Cam
    I did not get new bump stops, but haven't noticed the need for new ones yet.
    Mtbpsych[QUOTED] likes this.
  9. Mar 31, 2020 at 12:21 PM
    Krezz
    Do you know if the rear diff skid plate will have a version to work along side the KDSS of the O/R package?
    Also this may be dumb, but when I replace my OE suspension to go with some Fox coilovers, would that eliminate the function of the KDSS making the skid plate compatible or still something I'd still not be able to use?
  10. Apr 1, 2020 at 12:28 PM
    victoryrunner
    Cam
    No, great question, I wasn't sure myself! I talked with engineering and the current skid probably wouldn't work. Even if you replaced the rear sway bar, the old sway bar mounts would be in the way of the skid.
    We do plan to make a KDSS compatible diff skid but haven't had one in the shop yet. If you come down sometime after we open back up we can figure one out!
    Krezz[QUOTED] likes this.
  11. Apr 1, 2020 at 12:44 PM
    Krezz
    I will be coming for sure once life returns! It may have to be over a couple visits, which is perfectly fine. We'll be done to do what can get done in a Monday and then revisit for further options until done.
    Can't wait to get everything back to a semblance of normal.
  12. Apr 8, 2020 at 2:03 PM
    Chris In Milwaukee
    Chris
    @victoryrunner - are you guys stocking the 20" light bars for your bumpers, or would I need to source them elsewhere? I don't see them in the product list so thought I'd ask.
  13. Apr 8, 2020 at 6:04 PM
    victoryrunner
    Cam
  14. Apr 8, 2020 at 6:45 PM
    Chris In Milwaukee
    Chris
  15. Jul 13, 2020 at 11:10 AM
    victoryrunner
    Cam
    Kayaking in Northern Michigan
    2Toys, Krezz, wmdtech and 1 other person like this.
  16. Aug 7, 2020 at 7:01 AM
    victoryrunner
    Cam
    Some photos from last week's camping trip!
    2Toys, BSmart66 and wmdtech like this.
  17. Sep 11, 2020 at 12:43 PM
    Krezz
    Hey Cam, do you have a fire extinguisher on board?
    We are about to start the build on our 4Runner and this came to mind.
    cheers!
  18. Sep 11, 2020 at 12:54 PM
    victoryrunner
    Cam
    I should but I don't have one yet. I'd probably bolt a small one to the rear molle panel or under the shelf.
  19. Sep 11, 2020 at 12:55 PM
    #49
    Krezz
    Yeah, fairly sure she'll be going up onto the molle in the rear.
    Thanks for the quick reply!
  20. Sep 11, 2020 at 2:52 PM
    #50
    BSmart66
    BSmart66 New Member
    Brian
    2020 Metallic Grey "Venture" Edition
    None yet.....
    Ssssoooo........where did you take that shot of the "Speed Goat"?!?!? It's looking mighty interested in that rig!!
  21. Sep 14, 2020 at 5:12 AM
    #51
    victoryrunner
    Cam
    :laughing: Yellowstone!
    BSmart66[QUOTED] likes this.
  22. Oct 9, 2020 at 8:52 AM
    #52
    BSmart66
    BSmart66 New Member
    Brian
    None yet.....
    The switch from the Blitz to the Strike is pretty....sorry....striking. While I like the non-obvious Blitz, makes me wonder (depending on terrain) about the....uh...structural integrity of the stock bumper and if going with the Strike is a 'makes sense' choice in the long run.
    Then again, guess it depends on the intended use.
  23. Oct 14, 2020 at 10:55 AM
    #53
    victoryrunner
    Cam
    Took a trip up north!
  24. Oct 27, 2020 at 12:21 PM
    #54
    victoryrunner
    Cam
    Trying out a new 70-200mm lens!
    Oldtoyotaguy likes this.
