Victory 4x4 New Product Prototyping
Discussion in '5th Gen 4Runners (2010-2024)' started by victoryrunner, Mar 6, 2019.
  1. Jun 13, 2019 at 11:29 AM
    #61
    victoryrunner
    victoryrunner [OP] New Member
    Cam
    2017 SR5 Magnetic Gray Metallic 4Runner
    Falken Wildpeak A/T3 285/70R17 | Mamba Offroad Wheels M23 | 3" BDS Suspension | Victory 4x4 Blitz Front Winch Bumper | Victory 4x4 Strike Sliders
    With most things you will mount, you can simply lift the notched side of the crossbars to install your hardware. With a RTT that is a little more difficult, so you have two other options. You can use RTT mounting brackets (there are lots of options) that raise the tent up from the crossbars. You can also do what I did quickly before a long trip and remove the factory rails with the crossbars attached, mount that to the tent and then place it back on the roof.
  2. Jun 14, 2019 at 8:22 AM
    #62
    danssr5
    danssr5 New Member
    Dan
    2017 sr5 premium 4x4
    Thank you that makes perfect sense and helps a ton.
  3. Jul 9, 2019 at 11:32 AM
    #63
    victoryrunner
    Cam
    Aluminum Blitz Front Bumper prototype! 28lbs. Who would be interested?
  4. Jul 9, 2019 at 8:28 PM
    #64
    WallyT4R
    WallyT4R New Member
    I would! But would prefer the front light cut out to be without the company logo and completely open.
    PandaXIX and Doglover2003 like this.
  5. Jul 10, 2019 at 5:58 AM
    #65
    mikeymtbs
    mikeymtbs New Member
    19 TRD ORP
    Looks great. Love the stacked nickels on those welds!! Somebody knows what they’re doing!
  6. Jul 10, 2019 at 7:31 AM
    #66
    victoryrunner
    Cam
    They are now live on the site!
    4Runner Front Winch Bumper | Blitz | 5th Gen (14+) - Victory 4x4
    4Runner Front Winch Bumper | Blitz w/Tube | 5th Gen (14+) - Victory 4x4
    The aluminum version with or without tube will be the exact same design as the steel version, the bull bar will look the same. The only difference will be in the material (1/4" aluminum with 1" thick shackle tabs as opposed to the 3/4" tabs on steel).
    The mounting, recovery points, winch plate, and all three faces are tied together allowing for plenty of strength for winching/recovery.
    Use coupon code FIVE for 5% off!
    Strandskov, Firefly21 and dtmenace like this.
  7. Jul 10, 2019 at 6:30 PM
    #67
    WallyT4R
    WallyT4R New Member
    I guess I could always cut the logo out myself. :computercoffee:
    Strandskov likes this.
  8. Jul 10, 2019 at 6:31 PM
    #68
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    2017 T4R Pro 040
    Is plasti-dip a mod?!
    Nice stack o’ dimes!
    I like this bumper, heck I like it all! Can I just send you my runner with a list? Lol
    Will this bumper be winch capable?
  9. Jul 11, 2019 at 5:48 AM
    #69
    victoryrunner
    Cam
    Sure! Haha
    Yes it is winch capable!
  10. Jul 13, 2019 at 3:12 PM
    #70
    john8899
    john8899 New Member
    2019 Trd OR
    About how much space does adding the rtt mounts on the cross bars?
  11. Jul 15, 2019 at 5:44 AM
    #71
    victoryrunner
    Cam
    You may need to drill to add the RTT mounts, they are designed for the full rack, but they will add about 1" above the rail and the mounting location is moved outside (to the left and right) of the rail, so you have about an inch above the rail, down to the roof.
  12. Jul 15, 2019 at 5:46 AM
    #72
    john8899
    john8899 New Member
    2019 Trd OR
    Gotcha! Thanks for the info.
  13. Jul 17, 2019 at 7:49 AM
    #73
    john8899
    john8899 New Member
    2019 Trd OR
    There wouldn't happen to be any coupon code out right now for a roof rack would there?
  14. Jul 17, 2019 at 7:59 AM
    #74
    victoryrunner
    Cam
    You can use coupon code "FIVE" for 5% off your whole order!
  15. Jul 17, 2019 at 8:00 AM
    #75
    john8899
    john8899 New Member
    2019 Trd OR
    How much higher off the roof does the rack sit vs the cross bars that you guys make?
  16. Jul 17, 2019 at 8:04 AM
    #76
    victoryrunner
    Cam
    I'm not sure of the exact difference between the two. The crossbars for the stock rails are almost flush with the top of the stock rails, our roof rack only sits about 2.5" higher than the highest point of the roof.
    Strandskov and john8899[QUOTED] like this.
  17. Jul 17, 2019 at 8:11 AM
    #77
    john8899
    john8899 New Member
    2019 Trd OR
    What is the load rating for the rack and the rails?
  18. Jul 17, 2019 at 8:36 AM
    #78
    victoryrunner
    Cam
    We don't have an official number, Toyota only seems to have a load rating for the stock rails & crossbars (about 120lbs if I remember correctly). Our crossbars and rack are much stronger. The main thing is to be wise with what you have bouncing around on the roof of the vehicle, especially while wheeling. It's more than sufficient for the gear people usually run, RTT, recovery gear, storage boxes, fuel cans, etc...
    Strandskov and 4Runner fun like this.
  19. Jul 17, 2019 at 8:41 AM
    #79
    john8899
    john8899 New Member
    2019 Trd OR
    Thank you!
  20. Jul 18, 2019 at 11:48 AM
    #80
    victoryrunner
    Cam
    There has been a lot going on here, but prototyping is continuing!
  21. Sep 11, 2019 at 5:18 AM
    #81
    victoryrunner
    Cam
    Rear modular swingouts getting close!
    Strandskov, DrewMan, wmdtech and 4 others like this.
  22. Sep 11, 2019 at 11:01 AM
    #82
    tacotundra
    tacotundra New Member
    That's a good looking rear end :D
  23. Sep 24, 2019 at 10:58 AM
    #83
    victoryrunner
    Cam
    Full front bumper work starts today! It will be a factory-integrated look with all the clearance you need.
  24. Sep 24, 2019 at 7:07 PM
    #84
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    Will it retain or be able to use the factory fog light?
  25. Sep 25, 2019 at 8:17 AM
    #85
    victoryrunner
    Cam
    It will not, it will allow for cube/pod lights.
  26. Sep 25, 2019 at 2:54 PM
    #86
    I'd like to know what ladder that is, and where it came from!
    Nice products.
  27. Sep 26, 2019 at 6:07 AM
    #87
    victoryrunner
    Cam
    Thank you! The ladder in that photo is part of the Free Spirit Recreation RTT.
  28. Sep 26, 2019 at 3:32 PM
    #88
    teknoholic79
    teknoholic79 New Member
    I'm loving the design and may possibly purchase one. However, just a recommendation, any possibility of having a footstep hole on the rear side quarter panel area? Just thought about it so that we can use the side to load equipment on the roof (put one feet in the footstep hole while the other feet on the rear tire). Also, maybe a side bracket to put a flag pole, antenna, or pole to hold a washer bag to shower. Maybe another option is to extend the side to put in some kind of awning rear bracket. Again, these are just an idea to make your rear bumper more versatility compare to the other vendors.
  29. Sep 26, 2019 at 6:56 PM
    #89
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    Someone asked about light duty skids. Tough (and/or expensive) to get light plus strong.
    Plastics are good against punctures and scrapes but they flex easily so you could still damage parts behind the skid.
    Matching the coefficient of thermal expansion is tricky as well when you start mounting plastic on metal. UHMWPE for example is about 10x that of steel if I remember correctly. Means you could fab a perfect part in winter and in summer none of the bolt holes would line up.
    I reinforced stock skids with 1/8" flat bar pieces in key spots and made UHMWPE skins. Specifically made them on a day with mild temperature and oversized all mounting holes to allow for it to expand/contract. It's not as much protection as "real" skids but better than stock alone. And for front, mid, and gas tank it added less than 20lb total.
    Anyway, an idea for you guys:
    I like the way stock skid is wide such that it can deflect debris away from suspension. I've never seen aftermarket skids for 4R or Tacoma that are as wide as stock. Maybe make a bolt-on optional "splash shield" that would extend to the sides a bit more off of your standard skid.
  30. Sep 27, 2019 at 7:53 AM
    #90
    victoryrunner
    Cam
    Jigs are made, the rear bumper is finalized. Just need to finalize the carriers! More photos coming soon.
    WallyT4R, Strandskov, wmdtech and 3 others like this.
