URD MAF Sensor
Discussion in '5th Gen 4Runners (2010-2024)' started by jarhead75, Oct 10, 2019.
  1. Dec 20, 2021 at 10:49 AM
    T-Runner
    T-Runner New Member
    Honolulu, Hawaii
    22 Army Green TRD Sport
    How's the pickup and go on this mod? Kinda on the fence of purchasing and wont be able to return if im disappointed with it.
  2. Dec 20, 2021 at 9:58 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    Has anyone seen any specific HP gains with this or is it just the seat dyno method? Just curious if it is worth the time and money?
  3. Dec 21, 2021 at 3:27 AM
    Stuffy
    Stuffy New Member
    DFW
    2014 4runner SR5 2WD
    SCS RAY10 17" BFG KO2 TRD PRO FRONT GRILL HID LOW BEAM, LED high/fog/interior Ceramic tint all around TRD CAI Blackout emblems
    Honestly, it says on there website that it helps mods like intake work better. For me it seems to run a bit more efficiently. I only had it for one gas tank and I still have a quarter tank left. So im hoping it will atleast improve my mpg. Was getting 17.1mpg-17.6mpg mixed driving. If im getting 18.5mpg-19mpg mixed then ill be happy.
    I didn't feel any noticeable difference with a $200 something equipment that only took me less than an hour to install. So it is worth time bc I didn't have to do much and im hoping to get slightly better mpg. I am not going to do any actual dyno and Im sure no one else is going to do any dyno unless they actually install a supercharger.
    If you guys want to know more or have any other questions then feel free to message me.
    DBGW5 and Vito Corleone[QUOTED] like this.
  4. Dec 21, 2021 at 1:09 PM
    T-Runner
    T-Runner New Member
    Honolulu, Hawaii
    So no noticeable of better acceleration at all? Im assuming you got an intake and/or exhaust? If so, by chance did you get an uploaded map from URD to go along with the bolt ons?
  5. Dec 21, 2021 at 1:32 PM
    CameramanA73
    CameramanA73 New Member
    White TRD Pro 4R
    the URD MAF does this in simple terms
    More air flow in due to CAI >
    it sees the air flow signal from the MAF.
    amplifies the signal based on air flow and programmed curve charts inside URD module with Throttle position
    sends that signal to ECU telling it there is more airflow there at current throttle position that actual TP is programmed in ECU at
    This then makes the ECU add more fuel, timing, and AF ratio to get optimum burn.
    There are many factors that affect engine performance.
    Barometric pressure
    air temperature both exterior and underhood Intake temperature. (temp of air inside motor before combustion - lower temp = more power)
    Fuel octane
    Air Flow both CAI and Cat Back/delete exhaust. Free Flow. Some engines need some backpressure.
    You have to remember Toyota is a very conservative tuner of their ECU's so they are programmed for efficiency and longevity - meaning its hard to trick the 4R ECU into superpower mode.
    I hope this helps.
    I have the URD MAF module and I am pleased with it. I understand my expectations too.
    DBGW5 and BionicRandy like this.
  6. Dec 24, 2021 at 12:17 PM
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    Looks like a great trail (Round Knob) - how far would you say that is from Chattanooga? I've got property due west of Chattanooga we visit a couple time a year - the area looks similar to mine but I'm always up to try something different.
  7. Dec 24, 2021 at 12:19 PM
    Sandbuster
    Central Florida
    2019 TRD Offroad
    Okay - that said about performance improvement how would you rate the improvement compared to the $300 (+-) one gets from the Pedal Commander?
  8. Dec 24, 2021 at 2:32 PM
    Matt83
    Matt83 New Member
    Northeast
    What a joke. Why waste money?
    peter2772000 likes this.
  9. Jan 2, 2022 at 5:43 AM
    CameramanA73
    White TRD Pro 4R
    Pedal commander does nothing more than remap the drive by wire response curve. That why it has different settings.
    you are not adding more fuel or air you are only changing the voltage going to the electronic throttle to open faster.
    If Im not mistaken some "pedal commanders" out there have the ability to go the other way and smooth out the throttle even more for rock crawling and offroading.
    Where as a Cold air intake is adding more air - URD is remapping the actual sensing of the mass air flow sensor telling the ECU there is more air flow - thus ECU adds more fuel.
  10. Jan 2, 2022 at 10:15 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Almost got me again. Get me once, shame on you. Get me twice, shame on me LOL
  11. Nov 8, 2022 at 9:46 AM
    DBGW5
    DBGW5 New Member
    19 T4R ORP Icon 2.5 CDCV, 74Weld UCAs, Icon Overland rear springs w/ Icon 2.0 Resi, 285’s KM3, Icon rebounds, 4:56 Yukon gears, YOTAWERX AD Prem tune, Sumo Springs Blue bumps, magnaflow side exit, S&B intake. KC hidden bumper Rough Country 20”LED, RIGd tire carrier, frontrunner full roof rack, RIPP coil packs, victory ladder, BD Fogs, DRT hitch skid, MORE CO2 bracket, Rigid DSS Pro ditch lights
    3/2 lift new springs w/bilstein, 285’s, icon rebounds, magnaflow side exit, Pedal CDR
    URD MAF up for sale. Listed in the marketplace. Went with a full YotaWerx tune.
