Upgraded to bigger tires
Discussion in '5th Gen 4Runners (2010-2024)' started by 2022LimitedMidnight, Jul 12, 2024.
  1. Jul 12, 2024 at 3:42 PM
    I've been trying to help, but it's like you're not even reading my posts.
    From earlier:
    LT refers to load range C, D, E, etc...
  2. Jul 12, 2024 at 3:44 PM
    2022LimitedMidnight
    2022LimitedMidnight [OP] New Member
    GVL SC
    2022 Limited
    @Thatbassguy Thanks for that website, I need to be at 37 PSI I will deflate tomorrow morning. Thanks to everyone who responded and gave advice. I appreciate it.
  3. Jul 12, 2024 at 3:49 PM
    2022LimitedMidnight
    GVL SC
    2022 Limited
    @Thatbassguy I didn't see this message- "Also, what size are the new tires? I think 275/55/R20 is the usual upgrade for the Limited/Nightshade, but I'm not sure. If I am correct, even LT tires in that size should only be inflated to 37 PSI, cold. SL tires could be run at 26, but I don't know if I'd run them that low."
    Thanks dude!!!
  4. Jul 13, 2024 at 7:13 AM
    2022LimitedMidnight
    GVL SC
    2022 Limited
    @Thatbassguy do I need to do these steps?
    How to register the ID codes
    1. Select on the multi-information display using the meter control switches on the steering wheel. (→P. 96)
    2. Select "Vehicle Settings" and then press and hold 0.
    3. Select "TPWS" and then press O
    14 Select "Change Wheel Set" then press and hold @ until the tire pressure warning light blinks slowly 3 times.
    Then a message will be displayed on the multi-information display.
    When registration is being per-formed, the tire pressure warning light will blink for approximately 1 minute then illuminate and "..." will be displayed for the inflation pressure of each tire on the multi-information display.
    Drive straight (with occasional left and right turns) at approximately 25 mph (40 km/h) or more for approximately 10 to 30 min-utes.
    Registration is complete when the tire pressure warning light turns off and the inflation pressure of each tire is displayed on the multi-information display.
    Registration may take longer than approximately 1 hour in certain situations, such as when the vehicle is stopped for a long time at traffic lights, etc. (→P. 437)
    After registering the ID codes, make sure to initialize the tire pressure warning system. (→P. 430)
  5. Jul 13, 2024 at 9:51 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Yes, the first three steps will start the reset. Don't worry too much about the driving instructions, they'll register after a while with any normal driving.
