Upgrade Shocks on TRD Pemium?
Discussion in '5th Gen 4Runners (2010-2024)' started by maptol, Sep 8, 2023.
  1. Sep 10, 2023 at 11:45 AM
    My buddy had an 88 Towncar years ago, he'd drive that thing like a truck. Over curbs, full speed over speed bumps, you felt NOTHING. I miss riding in cars like that.
    Slopemaster likes this.
  2. Sep 10, 2023 at 12:46 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I had a job out of college where I rode home in a Lincoln Town Car every night at no cost - basically because I was never out of work before 9pm, and would be back again at 7:30am or so to do it again
    To this day, I still have flashbacks to how much that job sucked every time I’m in a black Lincoln.
  3. Sep 12, 2023 at 10:55 AM
    TRD5thgenner
    TRD5thgenner Not Very Well Known Member
    2021 4runner TRD Offroad Premium
    Stock shocks are soft to me
  4. Sep 12, 2023 at 6:26 PM
    Tentiger
    Tentiger New Member
    Nashville, TN
    2020 gray TRD Off Road
    I just installed Bilstein 5100 today on my TRD off road and I have to say I’m pretty happy. The floaty, leaning , nose dive has been pretty well mitigated and with the front set at .85 (second knotch) it leveled the front up to the back….front measurement from the hub to the top of the shell wells is 20.5” at all four corners.
    TrueTexas likes this.
  5. Sep 13, 2023 at 5:43 PM
    throwback
    throwback New Member
    Stock measurements are 22” rear 20” front. 5100s at .85 should just add exactly that .85, or in some cases close to 1”.
    You must’ve gone to the third clip or something else to add 2” to the front.
  6. Sep 13, 2023 at 7:11 PM
    Tentiger
    Tentiger New Member
    Nashville, TN
    Sorry.. I was not clear. I did the second clip adding .85… it actually added about an inch as the shocks add about .25 vs the stock shocks at the first clip per the installer at 4 Wheel Parts …the fronts are capable of about two inches at the top clip and that would require some additional work on the rears to keep the vehicle level … I did not want to go higher… just take out some of the rake … the ride is more firm, but I prefer this to the bouncy, leaning nosedive which is much much reduced and the ride is still smooth at speed
    Technologic80 likes this.
  7. Sep 14, 2023 at 6:49 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    If you haven't already, make sure you get it aligned.
    Good choice on the .85. I went to the next clip up (1.85") and added rear Bilstein 1" Springs. Then I chased the lean and added a 10mm spacer in the rear drivers side, followed by a .25" spacer in the front drivers side. Lost my caster and added UCAs to get that back in spec. It's finally where I want it (2" lift on all 4 corners) but it did add some cost to get that extra 1.15" of height.
    Fortunately, I twist my own wrenches so experimenting with the spacers wasn't that bad.
  8. Sep 14, 2023 at 7:06 PM
    Tentiger
    Tentiger New Member
    Nashville, TN
    Good work.. your ability is beyond mine! Thanks to this site and members with previous experience help me decide on the level the suited my goal and I found a good shop nearby to do the work… drive mine more today at interstate speed and totally happy with the responsiveness changing lanes, turning and braking . Cheers
  9. Oct 22, 2023 at 11:17 AM
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Super Ice Cap White
    This is absolutely true. A 13° drop in average temperatures in my area since my last pressure adjustment led to a 2 to 3 psi drop in my tire pressure. I had gone to Costco and done my own nitrogen exchange. The last time I wanted to check my tire pressure, Costco’s pumps were off, and I used Discount Tire air... in addition to the Costco nitrogen pumps having the high concentration of nitrogen, that’s in the 90% to 91% range, they also remove all the moisture. From what I understand, the discount tire pumps do not have the same level of drying of the air.
    Saker[QUOTED] likes this.
