Under hood lighting
Discussion in '5th Gen 4Runners (2010-2024)' started by Imnrgman, Aug 28, 2019.
  1. Jan 23, 2024 at 10:21 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I like the placement of your light strip. Above and behind, as not to "blind" you when looking in and down at your engine compartment.
    Saker[QUOTED] likes this.
  2. Jan 23, 2024 at 10:43 AM
    Very well said. I don't see a need for this mod, but it's rather easy to do and cheap, so why not? Manufacturers are taking everything away from us, little by little. Cigarette lighters, engine bay lights, ash trays, grab handles, cubby holes, a dummy light instead of a gauge, etc...
    I have a flash light in my truck and one of those head mounted flash lights; plus a fire extinguisher and other emergency equipment.
    But back on topic: Cool mod OP!
    Saker likes this.
  3. Jan 23, 2024 at 11:12 AM
    Thank you!
    On my previous 14 T4R, I looked at the other under the hood light mods and that was what I saw. Blinding lights to the eyes. That wasn’t what I was looking for. IIRC, there was one previous to my mod and used the prop switch and some that used the push putting button switches. But the main thing was placement of the light.
    To me, works perfectly!
    alittleoff[QUOTED] likes this.
  4. Jan 24, 2024 at 6:27 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I got this little pivoting, magnetic 12v Milwaukee work light that is surprisingly the perfect hood light, aims away from ur eyes. 6ah battery long life
  5. Jan 25, 2024 at 11:46 AM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Got my LED strip lights, tested them by touching the wires to the battery, and all's good. But I have a question about wiring. It appears that the positive goes directly to the battery, and the negative goes to the plunger switch, or is it the reverse? It would seem to make more sense to me that the positive is switched, not the negative, so it's not "hot" all the time?
  6. Jan 25, 2024 at 12:00 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    My non-professional opinion: functionally, it doesn't matter, but traditionally it's the hot side you place the switch.
    djwantke likes this.
  7. Jan 25, 2024 at 2:58 PM
    I always switch the hot side and fuse it as well.
  8. Jan 25, 2024 at 3:38 PM
    Have you ever used inline fuse holders similar to maybe these, on your hot wires?
    Pretty sure I need to fuse between battery and a 6-circuit fuse block I picked up?
    *these are 4-8awg
  9. Jan 25, 2024 at 3:43 PM
    ^that one takes bigger maxi fuses tho right. Iunno if that's common? you get the idea
  10. Jan 25, 2024 at 3:44 PM
    coryanderson
    Cory
    I would use one of these. A little more expensive but cleaner look.
    Blue Sea Systems 5191 Fuse Block Terminal 30-300 AMP https://a.co/d/4p50Kq1
  11. Jan 25, 2024 at 3:49 PM
    Not in my setups.
    This is what I use:
    Old Tanker and djwantke[QUOTED] like this.
  12. Jan 25, 2024 at 3:50 PM
    Hey thank you for this :yes: I seen those the other day on Amazon after chatting with you and the boys I think, other thread. But I failed to grasp it's capabilities, clearly haha
    no wire splice to my 2ft lead this way
    coryanderson[QUOTED] likes this.
  13. Jan 25, 2024 at 3:56 PM
  14. Jan 25, 2024 at 3:57 PM
    Yes sir. There are companies that make similar!
  15. Jan 25, 2024 at 4:37 PM
    flight
    flight New Member
    i have mine from https://www.powertrays.com
    Im really not a big fan of the unsealed bluesea fuse and terminal blocks, but haven’t had any issues either. Mine looks pretty nasty right now
    djwantke[QUOTED] and Saker like this.
  16. Jan 25, 2024 at 4:58 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Saker likes this.
  17. Jan 25, 2024 at 6:54 PM
    Good man, excellent.
    Click on the post# in the top right corner of any thread reply/post to reset the website in the top bar to that post number specifically. Then if you copy,paste,share the web address and jumps straight to that post in the thread.
    Saker and Thacrow[QUOTED] like this.
  18. Jan 25, 2024 at 6:56 PM
    I hear ya, and thanks for the knowledge. I didn't think about a seal
    Problem is like I've said, gosh that's just a lot of CAD to land one.
  19. Jan 25, 2024 at 6:59 PM
    #49
    Sick
    Thx dude
    that a Blue Sea breaker?
  20. Jan 25, 2024 at 7:09 PM
    #50
    Both Blue Sea and Blue Fire knock-off brand have same power ratings. Blue Sea being better overall quality materials.
    32V DC
    30A per circuit/100A per block
    But, am I correct in concluding that they are both wired with nickel-clad copper. I read that nickel-clad is better than pure copper in electronics?
    Blue Sea
    https://www.amazon.ca/dp/B000THQ0CQ?ref=emc_b_5_mob_i
    Blue Fire
    https://www.amazon.ca/dp/B07FZ27Z9J?ie=UTF8&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9kZXRhaWwp13NParams
  21. Jan 25, 2024 at 7:49 PM
    #51
    bronzestar1
    Two 12" long LED light strips shouldn't need an inline fuse, right? The wires are pretty thin, don't think they're going to draw all that much power from the battery. Couldn't hurt I suppose, but shouldn't need anything bigger than 10A (or smaller)? I don't plan on running anything else off this power wire except for the two LED strips.
  22. Jan 25, 2024 at 8:16 PM
    #52
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    you would want nickel clad copper for stuff like that where its bare metal exposed because copper would oxidize and gunk up. different than wires that are protected from the weather.
    djwantke[QUOTED] likes this.
  23. Jan 25, 2024 at 9:14 PM
    #53
    Final answer
    I think I'ma save money where I can, guna keep the Blue Life knock off it will be satisfactory for my loads. My circuit with the largest draw is only 96W/8A.
    But I did opt to just Buy Now: Bellingham built Blue Sea Systems 100A breaker, on sale as luck would have it.
    That's cool they're out of Bellingham, only 40 miles from me
  24. Jan 26, 2024 at 11:52 AM
    #54
    No sir, not the breaker.
    Eaton's Bussmann Series 285100F-121-S Hi-Amp Circuit Breaker, Type III Reset, 100A, 48VDC
    Waytek #:46692
    Mfr. #:285100F-121-S
  25. Jan 26, 2024 at 11:54 AM
    #55
    Ahh I see, thank you sir.
    Looks very similar
    I tried to find one of the Eaton's for sale in Canadian channels, but failed to find them. Blue Sea, and some other Canadian Auto store brands will suffice
  26. Jan 26, 2024 at 11:58 AM
    #56
    I fuse it with the lowest fuse possible dependent on the amp draw of the item. If the item shorts out, the fuse will burn and not your T4R!
  27. Jan 26, 2024 at 12:00 PM
    #57
    bronzestar1
    I have to go to the local auto parts store and get a toggle switch, so I'll look for an inline fuse as well...
  28. Jan 27, 2024 at 12:09 PM
    #58
    bronzestar1
    Installed the LED light strips, hooked to a small toggle switch on the side trim piece by the battery. Everything went pretty easy, tested the switch to make sure I connected the wires in the right direction to match the markings on the switch, then started installing the light strips, routing the wires, and hooking up the switch. Angle of the light strips shouldn't blind me when I open the hood and turn them on.
    After this pic was taken, I wrapped the two wires in electrical tape for a cleaner look:
    This pic was taken with a digital camera, no flash, LED strips put out a good amount of light:
    wingo likes this.
  29. Apr 17, 2024 at 8:35 AM
    #59
    wingo
    wingo *****
    2020 Venture
    Like the idea to have light under the hood if I need to work on it at night. So I added the strip like yours and a waterproof switch so I can turn it on when I need it and not come on when the hood is open. Here are some pics of my install.
  30. Apr 17, 2024 at 9:21 AM
    #60
    Powerstroke
    Powerstroke New Member
    Joe
    Spring Hill, SC
    2023 TRD Off Road Premium
    Very functional. This something I need to do, thanks for your posts
    wingo likes this.
