UCA recommendations
Discussion in 'Suspension' started by 4RunnerGuy916, May 1, 2023.
  1. May 3, 2023 at 10:00 AM
    Accelerator
    Accelerator New Member
    Chris
    Satellite Beach, Fla
    2022 SR5 Super White 4Runner #3
    Something I would like to add regarding the Dobinsons UCA's, they come with machined balljoint caps standard. I know for Dirt King you pay extra for the caps. I thought that this was great after I received mine since I did not know that they were included.
    Dhbldr, raimieb and Crikeymike like this.
  2. May 3, 2023 at 11:38 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Ill be the odd duck and say Icon tubulars have been great... with upgraded bushings and Delta Joints
    Justkelvin likes this.
  3. May 3, 2023 at 12:08 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Dobinsons Billet are a dream!
    hossler1788 likes this.
  4. May 3, 2023 at 12:43 PM
    blksubykid
    blksubykid New Member
    surprised no one mentioned SPC yet. Over 25K on mine, but I just replaced the ball joints as a preventative. No issues. Just grease every ~5K
  5. May 3, 2023 at 12:48 PM
    4RunnerGuy916
    4RunnerGuy916 [OP] New Member
    I like spc also but a little confuse on adjusting the ball joint
  6. May 3, 2023 at 1:44 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Yes, I saw people were having that issue with jba. When I installed the struts I had to turn them so they wouldn't hit. I believe my issue is the bushings, maybe their worn out. But the jba arms do add a good bit of extra down travel.
  7. May 5, 2023 at 7:21 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    2.5" Fox Suspension
  8. May 20, 2023 at 11:09 AM
    Jcastro2584
    Jcastro2584 New Member
    Jose
    I was gonna go with dobinson but decided to change my mind, so they’re up for sale if anyone wants them
  9. May 20, 2023 at 11:37 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Why not the Dob's. They're brilliant once installed!
  10. May 20, 2023 at 11:39 AM
    Jcastro2584
    Jose
    I won’t be needing them for my set up, they’ll just be overkill
  11. May 20, 2023 at 12:36 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Damn those are beautiful. Put them on!
  12. May 20, 2023 at 8:31 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Y’all make great products. I just didn’t want the heim joints. I prefer the rubber bushings for my daily driver and sometimes off road application. Appreciate you though.
  13. May 22, 2023 at 7:43 AM
    AccuTune Offroad
    2.5" Fox Suspension
    No problem. These wont wear out or squeak like a uniball on the spindle pivot will, if thats a concern.
    more info on that here
  14. May 22, 2023 at 6:41 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    But you already have them? What's overkill? What about them chabged your mind?
  15. May 22, 2023 at 8:30 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    totally agree. Maybe you save 300$ by using another brand. Those billets are amazing and durable in every way.
  16. May 22, 2023 at 8:34 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    confused by the article. It says both heim and the other type wear out quicker. My main concern was the joints that mount to the frame. So went with the oem style rubber.
  17. May 23, 2023 at 7:13 AM
    AccuTune Offroad
    2.5" Fox Suspension
    No worries. Some see the heim at the frame and think its the same as a uniball at the spindle. Spindle pivot has a lot more movement in the joint than the frame side does which can cause premature noise etc. Most will see that joint wear our much sooner than the frame side pivot. Just wanted to make sure you were aware. For simplicity and affordability OEM rubber works.
  18. Jun 4, 2023 at 6:55 AM
    TrailSpecial22 New Member
    PA
    OME or Camburg
  19. Jun 15, 2023 at 12:31 PM
    #49
    Brookieguy
    Brookieguy New Member
    2021 Venture Edition
    Mike-you have been very helpful for me thus far, and when I pull the trigger on my new suspension, I will be buying from Exit Offroad! More questions will probably be coming your way too. haha
  20. Sep 17, 2023 at 12:39 PM
    #50
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Is there a tubular, low maintenance that has adjustable castor and camber?
    Dobinsons looks sweet but castor doesn't look adjustable.
  21. Sep 17, 2023 at 12:43 PM
    #51
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
  22. Sep 17, 2023 at 1:56 PM
    #52
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I'm seeing it has castor built in and not adjustable
  23. Sep 17, 2023 at 2:11 PM
    #53
    Charlievee
    Charlievee Not new member.
    Running the JBA's seriously thinking of going back to stock.
  24. Sep 17, 2023 at 2:13 PM
    #54
    Crikeymike
    Crikeymike Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    SPC is a combination of tubular and cast steel
  25. Sep 17, 2023 at 3:08 PM
    #55
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Why?
  26. Sep 17, 2023 at 3:22 PM
    #56
    Charlievee
    Tired of them pissing grease everywhere. I just installed their upgraded ball joints and they leak worse then the old ones.
  27. Sep 17, 2023 at 3:27 PM
    #57
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I've had jbas for over 2 years now. I know what you mean about the grease getting everywhere. Makes a mess, unless you keep pressure washing or wiping the old grease away everytime you grease them. I had to install new ball joint boots a year ago after that my boots are tight and don't leak.
  28. Sep 17, 2023 at 3:49 PM
    #58
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Dobs billet 4 degrees of caster built in. Perfect alignment. No grease issues.
    Charlievee likes this.
  29. Sep 17, 2023 at 4:34 PM
    #59
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That pushes the wheel forward, correct?
  30. Sep 17, 2023 at 7:57 PM
    #60
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Yes
