Tri-Color Grill Badge
Discussion in '5th Gen 4Runners (2010-2024)' started by Vito Corleone, Oct 22, 2020.
  1. May 18, 2021 at 6:07 AM
    stephencovar
    stephencovar New Member
    2021 4Runner TRD Pro Lunar Rock
    BFG KO2's 265/70/17 C Load
    I’ve installed on mine and love it. It adds a little something something to front. It is also nice to represent Toyotas heritage.
    TrailGuy2016 and DrewMan like this.
  2. May 18, 2021 at 6:21 AM
    Toyofan87
    Toyofan87 New Member
    Seth
    Blue & Grey Hwy Gburg
    1987 Toyota 4Runner SR5
  3. May 18, 2021 at 7:48 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Where did you order it from ? Thanks.
    Rick
  4. May 18, 2021 at 12:47 PM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Never mind. I found it. Thanks.
    Rick
  5. May 18, 2021 at 3:08 PM
    ironmonk9
    ironmonk9 New Member
    2021 4runner pro
    They're well made and I think they're a nice homage to the classic version
  6. May 19, 2021 at 10:20 AM
    BeavertonCommuter
    BeavertonCommuter New Member
    What do you guys do with the super long screws that come with these badges off of Amazon? I havent been to find short replacements at the local Ace or Home Depot...
  7. May 19, 2021 at 1:07 PM
    stephencovar
    I just left it alone, once installed , it isn’t too bad.
  8. May 23, 2021 at 12:29 PM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Guys: Maybe I'm a bit naive, but how do you attach this to the grill ? No way to reach behind with a wrench. And no access top or bottom. HELP!!
    LOL
    Rick
  9. May 23, 2021 at 12:32 PM
    ironmonk9
    2021 4runner pro
    Lift the hood and pop the shroud off above the radiator. Just gotta pull the little plastic tabs off. It's easy and quick.
    DrewMan likes this.
  10. May 23, 2021 at 12:45 PM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Duh. I feel really dumb. LOL Thanks.
    Rick
    A&P likes this.
  11. May 23, 2021 at 12:55 PM
    ironmonk9
    2021 4runner pro
    Just make sure you pull the middle section of each tab up first. If you just shove a flat head screwdriver under the entire tab it will break.
    rickystl[QUOTED] likes this.
  12. May 23, 2021 at 12:58 PM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Yes, good point. I'm buying the correct pry tool for that. Thought I had one. But can't find it. Thanks again.
    Rick
  13. May 23, 2021 at 1:06 PM
    ironmonk9
    2021 4runner pro
    Its a solid tool to have, but I just used the blade of a box cutter. ‍♂️ Popped them all right up.
  14. Jun 2, 2021 at 12:03 AM
    uda4021
    uda4021 New Member
    2020 Army Green TRD Pro 4Runner
    Check out 4runnerlifestyle.com, they have some chrome delete sets for the front!
  15. Jun 2, 2021 at 6:55 AM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    I cut mine off to the needed length.
    Jason
    A&P likes this.
  16. Jun 2, 2021 at 8:23 AM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    You should not need any tools to remove the shroud above the radiator. You push the center section of the fastener in to loosen it, which is the opposite action to most types of plastic fasteners. Once the fastener is loose it can be removed by hand, don't drop any of the back ones down over the engine/skid plates.
    toomanytacos and rickystl like this.
  17. Jun 2, 2021 at 8:44 AM
    Wrong. As stated above, you don't pull up the middle section of each tab, you push it down, then pull out the plastic pin. They come right out after you push in the middle of each pin.
    toomanytacos, 4Paw, rickystl and 3 others like this.
  18. Jun 2, 2021 at 10:06 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Yep. You and @DRH are correct. Push down the center. After you pull out the whole clip push the center tab up using a flat surface like a tabletop. After re-installing them push that elevated center tab half way down to be level with the rest of the clip, so it expands and grips the sheet metal.
    Very ingenious device. You can re-use them many times.
  19. Jun 2, 2021 at 11:24 AM
    #49
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    I like it
    rickystl and Marchy[QUOTED] like this.
  20. Jun 2, 2021 at 11:36 AM
    #50
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    I got me one of these badges. Love it!
  21. Jun 2, 2021 at 5:08 PM
    #51
    BeavertonCommuter
    What'd you use to cut it?
  22. Jun 3, 2021 at 8:55 AM
    #52
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    I managed to get the badge on my grill without removing the shroud or anything else. It just takes a little ingenuity and nimble fingers.
    rickystl likes this.
  23. Jun 3, 2021 at 9:01 AM
    #53
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Well, thanks again guys for the info. ref pins/clips. Super helpful. Plan on installing it this weekend.
    Rick
  24. Jun 3, 2021 at 9:42 AM
    #54
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Angle grinder with a cut-off wheel.
    Best tool ever if you don't already have one.
    The fasteners are made out of very soft metal so you could easily just use a hack saw.
    Jason
  25. Jun 4, 2021 at 10:48 AM
    #55
    TrailGuy2016
    Yep, and get the cheap tool and a couple bags of replacement plastic rivets and save yourself a TON of time.
    Especially if you have Raptor lights and they decide to begin going bad one at a time a year after installation............:(
  26. Jun 5, 2021 at 1:21 PM
    #56
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Well, I just finished installing the badge. Couldn't have been easier. I guessed the tiny threads, nuts, and washers are not stainless, so I applied a thin coat of black wheel bearing grease after snugging the nuts. Those push-pins on the radiator shroud really are a clever item. Thanks again guys.
    Rick
  27. Jul 18, 2021 at 8:28 AM
    #57
    VentureTRD
    VentureTRD New Member
    Blowing Rock, North Carolina
    Blue Tri-Color Grille Badge and Chrome Strips Blacked Out.
    Someone needs to manufacture some LED strips to replace the 2 Chrome Strips.
    lbostons likes this.
