TRD Pro vs Off road with KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by kane22, Jan 15, 2024.
  1. Jan 29, 2024 at 9:06 PM
    #211
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Sure man, why not at that point. Especially since plastidip is removable with patience. Of course, you would chip and scratch plastidip as well, maybe can do small touch ups ?
    Yotaholic[QUOTED] likes this.
  2. Jan 30, 2024 at 2:15 AM
    #212
    kane22
    kane22 [OP] New Member
    Well it was sold. My only options now are a ORP without KDSS, or just keep what I have.
  3. Jan 30, 2024 at 4:16 AM
    #213
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    That sucks. Hoping you’ll find one with KDSS. I took a look and the dealer I bought mine from shows to have 2 TRD Pro and 2 ORP in stock.
  4. Jan 30, 2024 at 4:40 AM
    #214
    kane22
    Where did you get yours from? I live outside of Gettysburg.
    ToyotFan[QUOTED] likes this.
  5. Jan 30, 2024 at 4:42 AM
    #215
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    Faulkner Toyota in Harrisburg
  6. Jan 30, 2024 at 4:46 AM
    #216
    kane22
    I've never shopped there, maybe it would be worth running over. I check York, Hanover, Chambersburg, and Mechanicsbugh
  7. Jan 30, 2024 at 6:41 AM
    #217
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    I was impressed with my deal. Before I even stepped foot into the dealership the sales guy I worked with had discounted my ORP by $6k and we had the financing approved. I went up there twice after; once to go look at it and validate what he sent me pictures wise, and the second was to test drive and then do the paperwork. My ORP was in their showroom. Also there were no dealer addons which was a plus. I would recommend them.
  8. Jan 30, 2024 at 6:47 AM
    #218
    kane22
    OK, thanks! I checked on the Pro's, the one they have is sold and the other isn't there yet.
  9. Jan 30, 2024 at 7:04 AM
    #219
    COL4Runner
    COL4Runner New Member
    I never said they sucked I actually like them! I put a set of FSW copies on our 22' Taco and the 17x8.5 with 0 offset and 285's looks and rides really nice, would have done another set of those but they were out of stock so had to do OEM's
  10. Jan 30, 2024 at 7:55 AM
    #220
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    Hopefully they can get you one. If not the ORP with KDSS is great in my opinion. :)
  11. Jan 30, 2024 at 11:55 AM
    #221
    kane22
    I still don't know what I want. A ORP with a decent discount will be hard to pass on compared to a PRO at sticker price. I'd like to find a dealer that had both, so I could drive them back to back on the same roads.
  12. Jan 30, 2024 at 12:07 PM
    #222
    Lucky for me in Denver we have both KDSS and Pro on the lot. Even as of last weekend, Saturday.
    Other trims was also on the lot; SR5, Non KDSS ORP, TRD Sport, Limited.
    kolter45 likes this.
  13. Jan 30, 2024 at 12:55 PM
    #223
    kolter45
    Denver
    Inferno Pro & BRM Sport
    I went with the pro to avoid the KDSS for longevity. That's why I bought a used 2015 pro. No sunroof, no kdss, no tss, no xreas.:transformer:
  14. Jan 30, 2024 at 1:28 PM
    #224
    And no sweat equity :p:p
    BC Hunter and kolter45[QUOTED] like this.
  15. Jan 30, 2024 at 1:42 PM
    #225
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Toyota's obsession with sunroof is a bit much. I don't know if it is due to buyers wanting it or if they have too many roofs in a pile that need installing, but having them on EVERY. LAST. ORP. that got shipped to the west coast was a real bummer when I was buying mine.
  16. Jan 30, 2024 at 1:46 PM
    #226
    Amen
    If I could do it over I'd probably lose the sunroof as well. Because of the head clearance. I joke with my family that our 4runner was designed for short little Japanese folks and children :D
  17. Jan 30, 2024 at 1:48 PM
    #227
    kane22
    Same on the east coast. I'd rather have it without too. Do they do theses in batches, will there be ones built latter in the year without sunroofs, maybe???
  18. Jan 30, 2024 at 1:48 PM
    #228
    FourBelugas
    23 white ORP
    And the sunglasses holder. I open the roof maybe once a month if that, I use my sunglasses every time I drive when there is daylight. :/
    djwantke[QUOTED] likes this.
  19. Jan 30, 2024 at 1:51 PM
    #229
    FourBelugas
    23 white ORP
    My guess it is just due to the 5th's run coming to its end and they want to clear out all the parts inventory and make the build as similar as possible to speed things up.
    I doubt '24 4Rs will have many ORPs and Pros without sunroofs if at all.
  20. Jan 30, 2024 at 1:51 PM
    #230
    LOL you just reminded me I have a sunglasses holder. Pretty sure that things collecting dust. Oops.
    Every time my sunroof sun visor is open my toddlers complain instantly. Every time I tried to put my toddlers in their car seats I hit their heads and they're not even 3 years old.
  21. Jan 30, 2024 at 1:53 PM
    #231
    FourBelugas
    23 white ORP
    I like having a holder so I leave a pair in there in case I forget mine so I always have a back up.
    two things from my 99 camry that are missing and I really miss in my 23 ORP are the sunglass holders and the dusk sensing headlights. Don't get me wrong, I love the 4R, but damn it Toyota, lol.
  22. Jan 30, 2024 at 2:12 PM
    #232
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    I had a hard time finding a TRD OR, with KDSS but no moonroof. When I starting looking there were zero in North America and zero in allocation. Since I wasn't in a hurry I told my dealer that I'd wait and see what happens. A couple weeks later Toyota built one. Yes, only one. And it was in my color. Find a salesman that's willing to search the allocation list periodically until the 4R configured how you want it is built. Hopefully you will get lucky like I did.
  23. Jan 30, 2024 at 2:20 PM
    #233
    FourBelugas
    23 white ORP
    Thanks, after waiting for a while I ended up buying a white ORP with a sunroof, the dealers in my area I talked to either didn't know the process and was just forwarding me everything they had coming, or were selling theirs so fast it was not worth their time. Mine does have the sunroof and it is what it is, I'll live with it.
  24. Jan 30, 2024 at 2:33 PM
    #234
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    Bummer. Had I settled for a ORP I certainly could have gotten a better deal. I'm so glad I didn't even though I was stuck paying MSRP. Between absolutely hating the SoftTek interior and really not wanting the moonroof limited my options greatly. I expect to have this for the long run so I wanted what I wanted. Fortunately I had a dealer willing to help me (inventory manager has worked for Toyota for 30 plus years). I definitely got lucky because it had everything I wanted (exterior color, cloth, KDSS, no moonroof and upgraded audio). It's crazy that Toyota decided to build one! I don't know why they did and I'm definitely loving my first 4R!!!
    FourBelugas likes this.
  25. Jan 30, 2024 at 3:39 PM
    #235
    kolter45
    Denver
    This is why all the new pros get the SEMA wheels…:bananadead:
  26. Jan 30, 2024 at 3:42 PM
    #236
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    You got an ORP with JBL audio??
  27. Jan 30, 2024 at 4:28 PM
    #237
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    I wish! No, the better of the options available for the TRD OR's.
  28. Jan 30, 2024 at 4:31 PM
    #238
    https://www.4runners.com/threads/wh...-about-your-5th-gen-besides-mpg.35797/page-10
    That's funny, your aren't wrong, Toyota skimps.
    Regarding sunglasses holder, the wife and I have literally been dumping shades into the center console junk for as long as I can remember. Maybe one of us have a pair of shades we thought we lost that's in the sunglass holder
  29. Jan 30, 2024 at 4:59 PM
    #239
    I passed a nice new clean white TRD Pro on my way home from work just now. Please can somebody explain to me how in the hell do you put anything on the PRO roof rack how do you even use it LOL. I'll take my Amazon roof basket everyday of the week.
  30. Jan 30, 2024 at 5:13 PM
    #240
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I agree! The pro rack was the only thing I really hated about the Pro (and the crappy front camera) before I bought it. Thankfully it’s super easy to remove and I got a bunch of money for it since I sold it fairly early after I got the truck. But still, I wish they put something usable. Oh well, I really like my Gobi so I can’t complain too much but I expect better from Toyota
